1995 F250 PSD 4x4 5-speed, 148,000 miles
We just picked up the truck last week, and noticed the aft edge of the serpentine belt is fraying. Actually, I think possibly one whole "groove" of the belt is frayed right off, because the belt rides toward the front of all the pulleys, and leaves a slight gap on the aft side of all the pulleys. All except one -- the water pump. Just tonight I discovered that it's doing just the opposite; it's riding the aft edge of the water pump pulley, with a gap on the front edge. This leads me to think that when the belt was first put in place, the aft edge of the belt interfered with the aft edge of the water pump pulley, and that's what frayed that edge of the belt.
The belt isn't squealing or deflecting, and it appears to be turning all the pulleys just fine. A/C is cold, P/S is good, alt is charging. Fortunately, none of them are out of the "plane" of the belt (angled).
So I'm wondering if there's a way to make that water pump pulley sit further aft, relative to the other pulleys, so that it lines up better with them. Are there shims or spacers behind the pulley? If it were the other way 'round, I could always ADD a shim, or some spacers/washers behind the pulley, but it would have the opposite effect of what I need.
Pics -- Water pump, A/C, Alternator, Crankshaft, lower idler (near the tensioner):
Do I maybe need a different pulley, with more offset?
