Idi manual to replace Powerstroke Auto
2 reading
12K views 21 replies 11 participants last post by  Bradbilt
#1 ·
Will an IDI 5 speed bolt up and work behind a powerstroke? I searched and only found stuff about the auto and you have to switch computers. So if anyone has any input let me know
#2 ·
I'm doing this exact swap right now. From what I have learned and can confirm next week is that the transmission itself will bolt right up, however the clutch will not. Apparently the flywheel mounts are different from an IDI to a powerstroke as well as the diameter. The powerstoke has a 13" flywheel and the IDI has a 12.75" flywheel, each having different bolt spacing where they mount on the crank.
Also make sure the tranny you have is for a 2x4 or 4x4, whichever your truck is as they are different from 2x4 to 4x4.
#14 ·
im not sure what spacer your talking about,thought i had everything gathered for my swap,now im not sure:confused:
#16 ·
and its not used with an auto?so i have to find 1
