Up-pipe donut replacement - PowerStrokeNation : Ford Powerstroke Diesel Forum
Thread Tools Display Modes
  #1
Old 04-04-2011, 07:05 PM
Effreem
Offline
Member's Gallery
Hey,
Just curious about how long the up-pipe donuts take to replace? One of mine is leaking. Also, what is the actual part name for those up-pipe and donuts?
Any tips to make it easier would also be appreciated!
Thanks!
__________________
2001 7.3l F-250 Extended Cab Short Bed
Old 04-04-2011, 08:27 PM
kilapapipa's Avatar
kilapapipa
Offline
Old Yeller, REBORN
Member's Gallery
Re: Up-pipe donut replacement
Getting it off is the hard part, replacing them is easy but getting to all the bolts is a PITA with the motor in the truck. Spray the bolts a ton a day before even attempting to remove them to loosen them up a bit.
Swamps has them on their site I think.
__________________
REBORN 20 Over on 3/2/11- Pics in gallery- 2000 F250, Auto, 38r, Full Force 238cc/100%, TE 17* hpop, DP F5,HI,60T,80E,120R,140A, Studs and 910's with DI PR's, JW VB, Walbro 392, Bellowed, In-Tank, Pre-Pump, boost fooler, and RR. Air Dog, SS cover, 6.0 TOC,4" straight piped and guages, 6637, coolant filter, 4" Lift on 33's.
  #3
Old 04-04-2011, 09:28 PM
Arisley's Avatar
Arisley
Offline
All done now
Member's Gallery
Pull the trans out. You will save time, bruised ribs, and a call by the neigbors for the obscene language and thrown tools.
__________________
  #4
Old 04-04-2011, 10:30 PM
CTC DEEZUL's Avatar
CTC DEEZUL
Offline
Hood Rich
Member's Gallery
Send a message via AIM to CTC DEEZUL
dont even bother to spray them or loosen them, just cut them with a Dremel
__________________
NWI Coal Rollers Association
Local 444- Rolling Coal Teamsters
via Beans Toonz
DI SS Up-Pipe
GTP38R
  #5
Old 04-04-2011, 11:11 PM
wooner's Avatar
wooner
Offline
Construction Babysitter
Member's Gallery
I just did this project this weekend, but I replaced the old with IH bellowed up pipes. I sprayed the bolts down a few times over the past 2 weeks in preparation. Took me about 6 hours. It was one of the more memorable projects I have taken on with the truck
__________________
Dave
99.5 F250 Lariat : 6" lift on 37" Toyo MT's, DP Tunes, Built Transmission, Airbags, AIH Delete, 38R, Banks Big Head, CCV Mod, Sinister Regulated Return, IH bellowed up pipes, AFE Stage II, ISSPro Performax gauges, Scan Gauge, Casserly Stage I's, T-500 HPOP, Swamp's IDM
  #6
Old 04-05-2011, 03:46 AM
Arisley's Avatar
Arisley
Offline
All done now
Member's Gallery
I could have had the tranny out in an hour. Uppies replaced in twenty minutes. Tranny reinstalled in an hour. And been drunk and watching you finish.
Been there and done that. If my tranny comes out. The motor is getting uppies removed inspected and new donuts. Even if I had my tranny out day before yesterday.
  #7
Old 04-05-2011, 03:49 AM
CTC DEEZUL's Avatar
CTC DEEZUL
Offline
Hood Rich
Member's Gallery
Lol... thats impressive, but honestly, I would never pull a trans for this job. Now if we were talking about a LBZ or LLY, than yes.....
  #8
Old 04-05-2011, 04:31 AM
Arisley's Avatar
Arisley
Offline
All done now
Member's Gallery
Pulling a tranny is simple, first time I did it, it took me 90 minutes. I had to keep crawling out from under the truck for wrenches. Second time was only 45 minutes, I crawled under there with the right wrenches. A tranny jack is a must.
  #9
Old 04-05-2011, 06:23 AM
OUTLAW-OFFROAD's Avatar
OUTLAW-OFFROAD
Offline
mroutlawoffroad
Member's Gallery
Do u have to replace the pipes or can you get away with doughnut gaskets.
__________________
96 cclb 10" lift 38" tires.
6 pos custom tuned chip, AD injectors, hoodstack, fpr shim,isspro gauges, electric fans, Built trannismission.
OUTLAW OFFROAD traction bars.
  #10
Old 04-05-2011, 08:02 AM
Homesteader's Avatar
Homesteader
Offline
Member's Gallery
If you havent done it before it will be fun. I like the tranny idea to,gotta try it.
(View-All Members who have read this thread : 195
01REDSTROKER, 01strokin, 02bestroked, 03Excursion, 1badz, 2006powerleaker, 2stangs8689, 4BigGreen, 4duggan, 4wydnr, 5pattys, 97rattlebox, 99 SD PSD, 99oilburner, airmail96, ajfetterman, Arisley, AZStang, BACDRAFT, badford350, Bamboo, Big Calo, BIG01RIG, bigjake0524, bigwheel, billmoody1, birdog, boostaddict, bosssuperduty, Bowen Morris, bracketracer, Brian918, browning1, bryan.d, Bushwakd, ByrdDog, casher0010, Chadahootchie, CHevDog1, cheysays7.3!, chief055, choots, chris 0., cj45lc, co04cobra, Codydiesel, coldhanz, conan, Critical, crossent, CTC DEEZUL, Cumminsatya, Cundiff, David N, deathwishracer, Delox, deweuy, DHTD, DIESEL DAN, DieselBrad, Dieseltron, doublej112, doubleshot, drh4250, dsltech83, duncan351, duner405, Dvarhol, ebrow21, Effreem, eric96ford, Ford3544, fordnut, friskyjake, FSJPat, glovemeister, Goodbar419, Gotti2k7, greenbeast, GreenMachine, GreenScrew, Hamstn, hawkeye, hienergy557, Homesteader, Honeyshucks4, iceberg, IEBahner, jake2far, jamisgood, jc82chevyman, JD3020, joedaddy, johnday, Jolo170, ju015dd, K5383, Kampy, kilapapipa, kruser02, KYcopespitter7.3, Lee, loudmouth, markt, markyt, mars1952, mazdaparts, mbruce, mckeddie, micky_blue, Mike97f350, moremph, mrdoug, mrit, mrwalters, mstadler13, mttrucker, mykaos, n20, nchappy, NE-STROKE, northid710, OBSBoysel, oby, offroader101, oldwood, olyaee, ontwowheels, opieg01, OUTLAW-OFFROAD, PETERC, pilot4life, Pinky, pooter, Powerstatement, Powerstoke_Fan, powerstrokedkid87, PowerStrokingMachine, procomp, Psyched, radcustoms, raptor, ready81, Redline7.3L, Repper, richh789, rocketron, Rockyardjo, rollingthunder, Rollncoal7.3, Rosko18, rusty1161, Satan's chariot, Scerb, shanev10, sho669, shoaboat, simpleman, Sinisalo425, slayer7712, slowduty80, Sndwrkr, sniper_101, stlhdfishr, stoneykegonsa, str00ker, stroke99, strokepower, SWVa, t4050nh, taterthedog, tbolt, tch.280, TennesseeCoalRloller00, theCOYfish, tholt34, Torque37, tree trimmer, treyloco, TruckeePSD, truckguy, ttford07, TwiceStroked, Twisty, TxFire, UNDER PRESSURE, Vdryv, Wardy70, webb06, wooner, Zai Luke ll, zx800x
You may not post new threads
You may not post replies
Forum Jump
