7.3 Head gaskets - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > F-250 & F-350 1986-1997 & Other Ford Trucks > 1994-1997 OBS Power Stroke - Aftermarket & Performance
Register Members List Timeslips Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 04-02-2011, 04:26 AM
Chrisf97305's Avatar
Chrisf97305
Offline
Member's Gallery
Send a message via Yahoo to Chrisf97305
7.3 Head gaskets
I am going to remove my heads to install new valve springs and to inspect the top end of the engine.
Here is my question Which head gaskets are the best.
Ford, they want $120 each for them
International, they want $95 each
Then I went to the local parts store and asked for Fle-Pro and they were only $28 a set.
What gives, With pushing between 60 to 70 PSI of boost which head gasket do I want to run?? Don't much care how much as long as they last.
Can any one shed any light on this??
__________________
Black Magic Motorsports
1997F350
Mods: Stage 2 Injectors, DP Tunner, Intercooler, 4" Exhaust and a Custom Filter assy.
http://www.youtube.com/user/chrisf97305
Black Magic Motor Sports, 97 Ford F350
Reply With Quote Quick reply to this message Go to the top
Old 04-02-2011, 04:34 AM
TerminatorEngineering's Avatar
Offline
Sponsor
Member's Gallery
Re: 7.3 Head gaskets
You will want Fire Rings. Call Wide Open. At 70 lbs, I doubt stock gaskets will hold. 801-233-1111.
__________________
Visit us at: www.TerminatorEngineering.com for all your Big Oil needs.
SDRCM #7
  #3
Old 04-02-2011, 05:24 AM
Chrisf97305
Offline
Member's Gallery
This year I will be wastgating it to 55 to 60psi. I may hit the 70 with laughing gas
  #4
Old 04-02-2011, 07:29 AM
speeddemon31176's Avatar
speeddemon31176
Offline
Demon Dually
Member's Gallery
You better stud it and fire ring it or you are likely to launch a head right off the engine.
__________________
  #5
Old 04-02-2011, 12:38 PM
96strokerbp's Avatar
96strokerbp
Offline
Member's Gallery
I've run fel pro for about 3,000 miles havent had a problem, replaced head bolts and at 28 a side cant beat them.
__________________
Jimmy, 19, 96 f-350 7.3 RCLB
5 speed 151000 miles, sitting on goodyear duratracs, AFE Intake, 5 in. Straight pipe to 5 in stacks, Ts 6 pos chip wildman tuned, rds stage 2's 38r turbo with wicked wheel
  #6
Old 04-02-2011, 12:59 PM
neverkickn's Avatar
neverkickn
Offline
Member's Gallery
For a stock to near stock truck you are correct.
__________________
01 f250 scsb Work Truck
  #7
Old 04-02-2011, 03:14 PM
Short Bus
Offline
Member's Gallery
FYI there's absolutely no reason to pull the heads off for valve springs! Throw some H-11 studs on it and go.
__________________
2013 ccsb 4x4-stock
99 ccsb 4x4- built to the hilt, wife's DD!
  #8
Old 04-02-2011, 04:01 PM
strokeorcroak's Avatar
strokeorcroak
Offline
Member's Gallery
Id say go with the international ones.... But if you have the heads off, there is no reason not to fire ring it just to save yourself in the future
__________________
1996 with 35s
615hp/1258tq on 9/19
  #9
Old 04-02-2011, 08:15 PM
Chrisf97305
Offline
Member's Gallery
I know I don't have to remove the heads to install the springs. I just want to inspect everything before I start the pulling season.
  #10
Old 04-02-2011, 08:39 PM
Marty's Avatar
Marty
Offline
Busy Busy
Member's Gallery
I'd say don't. Different thickness of gasket.
Agree whole heartedly.
I would not pull the heads to do this. If you have to though... use advice below.
Stock gaskets will hold as long as they are aged. However they will not hold if they are new.
__________________
443.553.9234 - 410.392.3262
Elkton, Maryland
2001 F250 - 11.62 @ 115.76
S475, Irate Gated T4, H11, Crower Springs, Smith Bros, My Fuel, Swamps Tuning, Gen3, 400/400's, Forged Rods.
2003 F350 CCLB DRW
Converted to F450 stuff, EGR Delete, stockish...
If you do not want to register, fill this field only and the name will be used as user name for your post.
Human Verification
(View-All Members who have read this thread : 215
00 ford f250, 01REDSTROKER, 02BigD, 03sub4wstr, 04yfzkid, 1990 Scorpion, 1995stroker, 2006nytro, 440skidoo, 4duggan, 7.3-StRoKeR, 91turbogsx, 94Stroke, 94youngturbo, 95powersmoker, 95powerstroke, 95rdstroke, 96centurion, 96strokerbp, 97F250 HD, 97SLPR, 97stroker_08, Aaron Berk, addison, Ausm7499, bad12jr, BadDogPSD, biggreen96, bigjake0524, billmoody1, black974door, blackbetty13, BlindViper, Blowby, bmxrdneck, boost4life, Brian Cox, bryan213, btomassacci, buckey, Bulldog, Bushwakd, Bustedknuckles, CALADASH, ccf350stroker, ccslive, Centxdiesel, Chrisf97305, cj45lc, Clouse2411, co04cobra, Codydiesel, cota, CUMMINS_KILLA99, d-selpowereddiebauer, damons250, dave jr, dave186, Deerezilla, Denver, Desert Rancher, diesel.daddy, Dieselfever, Dirt_99, donzimama, drh4250, drwoodchopper, DZL JIM, enemyofgore, EverettWV, farmall16, fast408, fatsix, fordnut, ford_trck, fwbkent, gborgh, ghohouston, ghostang93, golfer, grantw1221, GreenMachine, gsxr1216, Guyton520, Harl, haulin99sdp, highfive, House, HunterD, Ithumpwheniwalk, itsallinthestroke, jake2far, jdneis, JesterPgh, jff987, JFURNER77, JHill, jkidd_39, Joeyd61, Johnboy3, JonFord, ju015dd, Jwagoner15, Kampy, KB3MMX, kbmkviii, kip4234, kramarj, Krause, krisx125, kystroker7.3, Lildiup, LOSTCAUSEPOWERSTROKE, loudmouth, louisvanwilker, Ltr 450, m j, M4K3H808, madmaxz, mandkole, markyt, Marty, matts, Michael97, mikes95powerstroke, mikesuperduty, Mini-Stroke..., morefuel, MustangMatt96GT, neverkickn, Newman, njjeep, nm50, Nodge, no_pistons7, np205, OBSWIZ, oldbluef250, ol_blue97, Otter70, Ouch, Owengilpin6, ParkerFly, pc97f350, Petro, pmasterson, PMS14, PokinDaPower, poon, powerstroke095, powerstroke14, PowerstrokeJunkie, powerstrokeU2, procomp, PSD 2004, PSDEng, pullinstroker97, pwrstrk01, radcustoms, Rambler, reid134, Reubine, rickvm, rideracelivemx7, RLSCOAL, Rmartin-97, roadsaw, rollingthunder, Ross01, RubberDuck, salprofish, SAYiWONT8, shookme, silent64, sled hauler, Smoker00, SouthJerseyStroker, sparksf250, speeddemon31176, stackedandtuned, Stang07, star73, stoneykegonsa, strokeorcroak, strokernine6, Strokin96, superm, t4050nh, t444epsd, tank23, TerminatorEngineering, the black, Thomas7.3psd, TinyF350, Tom S, TravisT, turbodiesel_02, tyunick, umpalumpa1985, usnavyad, va94cobra, vanderchevy18, vick97psd, wanagofaster73, washingtoncoastie, Wazincow, whytry, WINK, wrenchturner250, wyocountryboy, yotee, ytee
Forum Jump
