1997 f350 DRW 4x2 to 4x4 conversion. - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > F-250 & F-350 1986-1997 & Other Ford Trucks > 1994-1997 OBS Power Stroke - Aftermarket & Performance
Register Members List Timeslips Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 03-30-2011, 02:25 AM
Quazieporno
Offline
Member's Gallery
I have been reading a lot of the threads. Maybe someone could point me in the right direction. I am just trying to gather as much info as i can about converting my 97 f350 psd DRW from 2 wheel drive to 4x4. I have purchased a 89 dana 60 with brakes, track bar and bracket, sway bar and steering linkage. No leaf springs but i was thinking about getting a tuff country 4" lift that comes with springs anyway. I know the conversion is posable but not much info about it. I guess my question is what info can you give me about this conversion. Like what parts that are on the truck that will work with this conversion. Also the axle i bought is off of SRW truck. Will changing over the hubs to DRW be hard to do. Thanks for your time for any info you can give me.
Old 03-30-2011, 05:12 AM
speeddemon31176's Avatar
speeddemon31176
Offline
Demon Dually
Member's Gallery
Re: 1997 f350 DRW 4x2 to 4x4 conversion.
Simply follow the threads on swapping in the d60 for a srw truck. The only difference is that you will have to swap over to a set of drw front hubs. I don't know your location but I can hook you up with a set of hubs my buddy has for sale. The other things you will need are a 4x4 trans, transfer case, front drive shaft, and a shorter rear drive shaft. You will also need the harness from a 4x4 truck if you want the light to work for the 4 wheel.
__________________
  #3
Old 03-30-2011, 05:33 AM
~NASTYSTROKER96~'s Avatar
~NASTYSTROKER96~
Offline
DIRT NASTY DIESEL!!
Member's Gallery
wont you need to figure out the position of the spring mounts since your goin from a coil spring set up to a leaf set up?
__________________
Michael ~96 Ford F250~
Diamond eye exhaust, Autometer Ultralite gauges, Rough Country leveling kit, Superchip Programmer
  #4
Old 03-30-2011, 05:40 AM
Quazieporno
Offline
Member's Gallery
how much for the drw front hubs. I haven't really priced them. The axle i am getting has srw hubs. I have been reading every thread i could find on dana 60 conversions and most of them or for 4x4 equip truck. The trans and t-case can wait. the big part is getting the axle under truck. I would like to do zf6 swap on the truck. But dont know if that would work or not. One thing at a time i guess.
  #5
Old 03-30-2011, 05:43 AM
Quazieporno
Offline
Member's Gallery
thats some of the questions i have. I was told it could be done. Just trying to find someone who has done one of these conversions
  #6
Old 03-30-2011, 07:09 AM
speeddemon31176
Offline
Demon Dually
Member's Gallery
I will call my buddy in the morning and get you a price on them. You would need to locate the spring hangers for a 4x4 for the rear of the front springs and you will need the shackles for the front. It is my understanding that some frames are drilled for the bolt for the shackles and some are not. You will need the shock bracket for a 4x4 as well. You will have to remove the coil spring perch on the frame from the 2wd. As far as using a zf6 goes you would need to clearance the floor hump as the zf6 is taller than a zf5.
  #7
Old 03-30-2011, 08:00 AM
Quazieporno
Offline
Member's Gallery
So it is posable to do zf6. This project will get out of hand quick. I will have to go to the junk yard and start getting the rest of the parts. Thanks for the help.
  #8
Old 03-30-2011, 11:42 PM
Quazieporno
Offline
Member's Gallery
Do you think there would be a place online that would sale everything i need to do this conversion.
  #9
Old 03-30-2011, 11:48 PM
t444epsd
Offline
Member's Gallery
Sky reverse shackle kit. We used one to convert a 4x2 to 4x4, makes life alot easier. And a nice upgrade to boot.
__________________
1994 F-350 4x4 RC 7.3 IDI Turbo, BTS E-4OD, ATS upgrades, BB injectors, Moose Pump, Holley Red.
1997 F-350 CC 4x4 7.3, E-4OD, 6" lift, 38" swampers, 160/80% RDS injectors, TDP tunes.
2001 F-250 RC 4x4 7.3, 4R-100, Straight piped, PHP tune, Western 8.5 MVP.
2003 E-350 7.3, 4R100, 3.55LS. Stock(For now)
  #10
Old 03-31-2011, 04:01 PM
cherrytr
Offline
Member's Gallery
i would do a shackel reverse kit on the truck that will get your leaf springs under the truck and then roll the axle under and bole it together will need to get the tuff country trac bar bracket to drop the trac bar. but just remeber that the shackle reverse kit will give you 3" more of lift
__________________
96 F-250 ext cab. straight axled 6" lift. intake, exhaust, ts with wide open performance tunes. torque converter, shift kit
(View-All Members who have read this thread : 128
02ST, 05Kfx400, 1978psd, 1995eddie, 1craneguy, 1SLO GT, 220Swift, 23stroker1997, 4duggan, 6speeddeere, 7.3-StRoKeR, 95powerstroke, 96strokerbp, 97CCLB410LS, 97f3504x4green, 97PowerJoker250HD, 97strokn&smokn, Adinas95, Al Mighty, Ausm7499, bg9707powerstroke, biggreen96, BlindViper, BMF7.3, boxwrenchesareslow, Bradbilt, BrianL62, Broken Wrench, cherrytr, ckbed, coalchurn97, cprinkey, CRASHJT, Denver, DieselFreak92, dont 7.3 drw, drthunder33, dswhite, DUESLER, dukedrummer89, Epd444, farmall16, farmallfarmer, fordnut, Four Paws, fowler, freddie, GAsootlife, gtmustang00, guitarjesus, helo1, Highstake, idtex, ironworker40, isky1843, jasiri, JCart, JDOliver, JesterPgh, Jjona5, jmiller9339, joedaddy, jokerstroker1995, Jomax, Josh2021, Kampy, kip4234, kramarj, Krause, Lifted250, lilcrowe, lossscause, loudmouth, louisvanwilker, mattscoke, merlinnilrem, MustangMatt96GT, Neal 97 250, njracer23, Nodge, NutFarmer97, pennsylvaniabo, pmasterson, PokinDaPower, psd444, pullinstroker97, Quazieporno, quesey, Rancherousa, rancherstroker6, redneckabbott, RMutz27, rob72, rpm-inc, semomotorsports, sharpmotors, slammed83mazda, SoGrand, speeddemon31176, stackedstroker, StandAlone, Sting_3, stroke7.3this, t444epsd, tcerohe, TERRCO, the great white, the7.3dude, thenephilm, timfinnegan, Tom S, tonka350, toolmangary, trenner101, u2slow, UNLIMITED_DIESEL, V97F350, vegas99, washingtoncoastie, WichitaF250, wildbillcody97, WPBarnes0693, xcessivebronco, yotee, ~NASTYSTROKER96~
You may not post new threads
You may not post replies
Forum Jump
