How much "blow-by" is normal - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > F-250 & F-350 1986-1997 & Other Ford Trucks > E-Series Power Stroke Vans
Thread Tools Display Modes
  #1
Old 04-29-2008, 11:41 AM
sixiron's Avatar
sixiron
Offline
settin on go
Member's Gallery
OK, got ccv mod with hose running down frame rail exiting just ahead of rear wheels...
I am noticing vapor & fumes more and more coming off extended runs of 3-10 hrs
cracking oil fill cap shows vapor trail coming out of crankcase but no "huffing"
I am just wondering at what point I should get concerned and have this checked more....I do not think its "dusted" but I want to keep a close check on this ..
Wondering what general signs of ring wear ,or dusting of engine are?
tks bill
__________________
2002 E-350
4"DP-exh.. reg return/bowl delete, BTS trans, DP tuned,, Hella, Timbren, Bilsteins,Wolverine, , TTw/C'Btr's,cryo rotors, gauges, Alum Baja's...dyno 335hp
04 VW Jetta S/W, TDI, RC1+, stage 2 cam, skidplate, euro's,koni's,TT susp, cat 2mic filter,tint.
Old 04-30-2008, 03:53 AM
bork
Offline
Member's Gallery
Re: How much "blow-by" is normal
Did you have the mod on your 98? How did it compare, if you did? I haven't done mine.(yet)
  #3
Old 04-30-2008, 05:01 PM
Madvan's Avatar
Madvan
Offline
Member's Gallery
Bill
I have to look up the spec. Dont have it here.
I only remove the CCV if it has an intercooler.
I just burn the oil in the combustion chamber.
May not be much but its in the intake draft (stock). If you look at some
race motors you will see the use of a vac pump to run the CC in a vac.
It promotes ring seal.
For now check for low spots in the line that can pool the oil.
The oil pool can act as a valve. It will have to build more pressure to pass the pool of oil.
The line has to be pitched like a sewer drain.
Bill
__________________
97 Quigley 4X4 PSD
  #4
Old 04-30-2008, 06:50 PM
Racer X's Avatar
Racer X
Offline
X Racer
Member's Gallery
A good bit is the best answer I know. Enough to oil the intake pre-turbo on many.
You could find a place to route the CCV into the exhaust and burn the vapors and drips. A little fabricating and plumbing needed. Someone makes a fitting--Moroso maybe...
__________________
97 F350 7.3L with Twin Turbos flowing 473cc of Diesel & Nitrous, Custom RACER X E4OD Tranny, 800 hp on video!
Contact Racer X USA for Fully Custom built transmissions, Torque Converters & Valve Bodies.
  #5
Old 05-01-2008, 03:52 PM
Madvan's Avatar
Madvan
Offline
Member's Gallery
Bill
Spec is 6in H2O or less is good.
This is hot motor, plugged CCV, WOT for 30 seconds.
Gauged from the oil fill.
The old swamp donkey way was to lay the oil fill cap on the hole unscrewed.
If it blows the cap off the pressure is to high. His test is dam close! Problem is on the van the oil fill is not flat on the VC.
Bill
  #6
Old 05-03-2008, 12:30 PM
sixiron's Avatar
sixiron
Offline
settin on go
Member's Gallery
Maybe I am trying to borrow trouble,
Its not pouring out steam like a teakettle
but the 98 van had less "blow-by" than this 02 does, and the 98 had a ton of hard miles on it to boot...
Thanks for heads up bill...
regards
bill
  #7
Old 05-05-2008, 01:28 AM
squeeks's Avatar
squeeks
Offline
Member's Gallery
Originally Posted by Madvan View Post
Bill
Bill
To do that test the swamp donkey way do you have to plug the CCV and Hold it at WOT for 30 sec?
__________________
1996 Ford F350 Regular Cab 5spd with the 7.3L PSD, 4x4, 35.5x12.5x16.5 All-Terrain T/A's, 3.73s', DIY Electric Reg Return Fuel Sys, 3" Downpipe, AFE Stg 2, 17* HPOP, IDM Mod, SB Con-O, Cat and Muffler Delete, AutoMeter NV Series Boost, Fuel Press. and Pyro, Autometer 3 Pod A-Pillar, TS Performance 6 Pos Chip. HPX Mod, 355,000 Miles
  #8
Old 05-07-2008, 01:44 AM
bork
Offline
Member's Gallery
regards
bill
OUCH! Maybe it needs to be broken in more.
  #9
Old 05-07-2008, 02:10 AM
Madvan's Avatar
Madvan
Offline
Member's Gallery
Bill
I would change the oil and send out a sample.
Maybe something simple like fuel diluted.
What brand oil are you using?
Bill
  #10
Old 05-07-2008, 11:29 AM
sixiron's Avatar
sixiron
Offline
settin on go
Member's Gallery
Bill
Bill
Oil is 5w40 Rotella Synthetic
I will checkkout the Blackstone sampling
later,bill
(View-All Members who have read this thread : 72
17degrees, 4wydnr, 96centurion, 99F250Smitty, aquatune, bert, Bigtimearcher, bork, cowboy_dan, crowz, Crunch, dalejrfan88, Dansk, DieselDan73, Doodah, drunk on diesel, dtott, Earl6788, fordlanefarmer, FULLAUTO, haulin99sdp, HondaTypeRk20, Imjosh, impostor, Ingeniero, JeepPuller, jetboat82, JHill, jlee, kts532, LarryM, Madvan, mattgw86, mattr66, mghay, NE-STROKE, nvydvrdude, oh8three50, old man dave, old Smokey, olyaee, Powersmoker, Powerstroke Racer, powerstrokenstang, psdmike, PWRstroke_smoke, Redfish, Riley250, rpm-inc, scheidt27, SIC-E, sixiron, slowleak, Soaggydogg, spock1996, squeeks, srmurphy, stever88, stray cat, Stroked Van, superdutyfarmer, troy, Tsunami, vanillagorilla, vapstroke, wooner, xracer, zvovchik
You may not post new threads
You may not post replies
Forum Jump
