Cheap EGR delete method? - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.0L Power Stroke Technical Info
Thread Tools Display Modes
  #1
Old 03-28-2011, 12:51 AM
powerstroker66's Avatar
powerstroker66
Offline
Member's Gallery
I am doing some research for my old man and he wants me to find a way to bypass/delete/solve the EGR problem in the 6.ohs. Looking for the cheapest kit to delete it. I have herd of people unplugging them and having no problems? I am not too familiar with the 6.0s so that is why i am asking. Any advice would be nice thanks!!! (i'm not the one that made the mistake in buying a 6.0)
Old 03-28-2011, 04:30 AM
RickF350's Avatar
RickF350
Offline
Member's Gallery
Re: Cheap EGR delete method?
Not the best choice of words to use in a 6.0 forum. Anyways, Egr Delete Kit Economy Custom Diesel is the least expensive kit that I have found.
  #3
Old 03-28-2011, 04:40 AM
coalroller3x's Avatar
coalroller3x
Offline
<-•DEISEL CRAFT•
Member's Gallery
I worked on a truck that had a pipe threaded into the oil cooler and taped int the coolant line to the heater core. They cut a piece of rear egr cooler off and made a custom exhaust cap. I'm not real sure what they did to the front cover water port to the intake. That's the most redneck one iv seen
__________________
05 f250
Cass 190cc injectors with 100 over nozzles
tsd fuel sump, fuel lab=Custom, sinister reg return, MPD headers/up pipes, arp studs,JGS wastegate, egr delete, banks CAC, ram air and techni cooler,S&B cold air,TurboNetics dual ball bearing 64/65 .83AR, twisted diesel trans stage 2,phantom 2=egt,trans,boost,fuel psi
  #4
Old 03-28-2011, 01:02 PM
lenzhotrod
Offline
Member's Gallery
Pull your EGR cooler and plug both ends. Leave EGR valve installed and plugged in. Some vehicles will require an SCT to turn off an engine light. We all know this is for off road use only. This will pass any visual inspection,not give you a problem if your EGR cooler cracks, and will keep your intake and heads clean!!
  #5
Old 03-28-2011, 01:32 PM
powerstroker66
Offline
Member's Gallery
ok thanks you guys i am just trying to eyeball some preventive maintenance hear. I will probably look into a cheap delete kit but i have to talk to my dealer first about warranty, i herd it voids it..thanks!
  #6
Old 03-29-2011, 01:20 AM
offroadinginaz's Avatar
offroadinginaz
Offline
It wasn't me
Member's Gallery
Why are you deleting it? Is it puking? Are you monitoring EOT and ECT?
__________________
Newman
A few Fords
Special Thanks to:
Bullet Proof Diesel
Strictly Diesel
Arizona Powerstroke Group
  #7
Old 03-29-2011, 02:05 AM
smokersteve
Offline
Member's Gallery
I unpluged mine and welded a plug on the up-pipe side tube that feeds the egr cooler. I have no issues form the codes.
__________________
FICM Testing Videos
FICM Testing Videos
Trans Flush
How To Get More Than 8 To 7 Quarts
Stock Truck, CA, DTC, Smog Safe EGR Modification.
Up pipe - Ford Powerstroke Diesel Forum
  #8
Old 03-29-2011, 02:34 PM
lenzhotrod
Offline
Member's Gallery
smokersteve has a easir way than mine except if his EGR cooler were to leak it eventually will make it thru the EGR valve. With my way if the EGR cooler has an internal leak the plugs will hold it!
  #9
Old 03-29-2011, 05:42 PM
Lubbockguy1979's Avatar
Lubbockguy1979
Offline
Power Junky
Member's Gallery
Weld it up. Its stainless but other than that not a big deal. Cost a few bucks for welding supplies or probably less that $100 bucks to have it done. Looks stock and should pass a visual inspection.
__________________
Randy
2006 f250 4x4 lariat cc swb 6.0psd torqueshift elec tcase soon to have isspro gauges air/fire/tranny/ fuel pretty much stock
  #10
Old 03-29-2011, 11:41 PM
powerstroker66
Offline
Member's Gallery
so let me get this straight..if you unplug it, it doesn't do any harm but it will throw a code so you have to block off or by pass it in order to get it to work properly? sorry you guys i am not too familiar with 6.0 systems thanks for your help!
(View-All Members who have read this thread : 233
01REDSTROKER, 04La4iat, 04MT, 04psdexcursion, 04stroker, 05white6.0, 06powerstroke, 06sixstroke, 07_powerstroke, 08STROKE, 100%lemonhead, 1bad306, 1Knight, 2005F350, 4duggan, 50gstroked, 530farmboy, 550ss, 60POWERSTROKE73, 7.3D, 7.3Stroker96, 94Matt, 96powerstroke7.3, 97crewcab, 99oilburner, A.D.R, Abbott, airtech, ajennings, All Stroked OUT, amdriven2liv, AR Aggie, autowork7456, avm112, babs2972, bad moose, bboteler, BCS, bennyboy, BigBlack03, BIGBLUE08, BigBoy6.0, bigdaddy60, BigDeal21, Bigdog, Bigfordguy07, bigrngyj, birddog55, black7.3, blacksmokingplumber, blownpickup, bufasion, bustednuckles, Canadian6L, co04cobra, coalroller3x, Countryboy07, cullinfish, Currey, dalpilot, ddillenger, deercreekstroker, Deerezilla, dexleo2, dhuff2005, dieseljosh07, DieselStroke, dirtydieselsixoh, dits145, dtarver1985, dukhtr3, dvlishdan, East County stroker, Echo, ed3196499, Edroe, EPDP99, Evans720, F-117HWK, F-250-Owner, F350F351, farmall99, Flippincgfighter, fmrdieseltech, FMXMAFIA, football3295, Force2354, Ford Powerstroke, fordboy11, Fordfreak4life, Fox'sFord, Frank'daTank, giantred, gjoski515, greenecj, Grey6.0, gtmustang00, gunfreak25, guydiver12, harley-kid, hawgdoctor, Hayes0620, HeavyAssault, hemicbx, hill_billiez, Humo, iceman89m, isimar, J HO 22, jamcconnell2, jasonbrown99, Jeremy, jetboatrich, jg6.0, Johnboy3, Johnny77Mutt, Jomull55, JonnyB, jorris83, jrcoogs, JS98, jtlane, jweber6.0L, jzamluk, kenny7231, Krisco, kyle882, Lage350, lancer, legionxxii, lilredrocket, Loonatic, Low Key, Lubbockguy1979, lubeowner, Lyrch75, madmantc, MarkEB250, markt, mason93, medicman88, mikeb01453, Mikeh1725, mjcolemn, mosborn, Motownfire, mouse4x4, MT Pockets, mttrucker, namerritt, nastystroke04, Neof250, nielsencc86, njjeep, NoahA, Nolat14, nos487, nrook, nutsnboltsjp, Nutz, offroadinginaz, orrwhat, paranoidredneck, perwin24, Petro, pjerrn, powerstroker66, raftert63t7, rbunk350, rcfarm, redhors66, RickF350, ringmaster66, RobsF350, rugbymachine, RW'sSTROKER, SaNnDnSurF, SDER1, SickStroke6.0, SLAMDS10, smokeem, smokersteve, smokey05, smokin250, smokinford07, smokinstroker, Smut, Sneezy Beltran, squirellchaser, Staggs02, steveatxtreme, stevv, str8wkd, straightaxle, striker05, Stroked2004, StrokerTurbo7.3, sup, superdutyfarmer, superstack, svorob, TAMU_PSD, Taylor0369, techteacher, texascadillac42, thathoustonkid, The Dude, theoldpoop, Tom_Brown, toycrawler, toyfarm, travis6363, trevorjohn23, tsedsell, turbie, TWJ, TX-4-NRA, TxFireman1972, tyman, utripin, wezol5484, WichitaF250, WickedAddiction, Z. Baker, ZaneD, zx800x
You may not post new threads
You may not post replies
Forum Jump
