Rivnut for Lund visor? - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 1999-2010 Super Duty General Aftermarket
Thread Tools Display Modes
  #1
Old 03-22-2011, 12:24 AM
Bryrylan's Avatar
Bryrylan
Offline
Member's Gallery
Has anyone on here used a riv nut to mount a lund visor? I have gone threw so many windshields that the holes are junk I want to install Nutcerts (rivnuts) whatever to it can be alittle more serviceable.
__________________
2002 F-250
Kw w900B with a smaller stack than most pick ups
Originally Posted by yogi7615 View Post
look the word dodge up in any dictionary. it means "to avoid."
Old 03-22-2011, 10:36 PM
Bryrylan's Avatar
Bryrylan
Offline
Member's Gallery
Re: Rivnut for Lund visor?
well I ordered the rivnut kit today so I will post how it comes out
  #3
Old 03-22-2011, 10:53 PM
diesel_brad's Avatar
diesel_brad
Offline
STILL LEARNING
Member's Gallery
Yes. That is how they are mounted on a BIG truck. Just make sure you seal the nutsert to the roof and also seal the bolt to the nutsert
__________________
I am probably the most hated person on here, and I don't care
97 CCSB 4WD DRW 7.3 5spd DP Tuner, 6637, Flo-Pro SS Exhaust, 99 I/C, T500, Autometer gauges, Valair Organic clutch, PFM 2.25" RSK, SD springs Front/rear 315/75/16s,
Bunch of other trucks
  #4
Old 03-23-2011, 01:20 AM
Bryrylan's Avatar
Bryrylan
Offline
Member's Gallery
thats kinda were i got the idea was big trucks. 10-4 on the sealant i'm going to never seez the hell out of the bolts to so the nutcert doesn't spin in the roof
  #5
Old 03-23-2011, 04:36 PM
diesel_brad
Offline
STILL LEARNING
Member's Gallery
Also a very good idea
  #6
Old 03-26-2011, 02:51 AM
Bryrylan's Avatar
Bryrylan
Offline
Member's Gallery
FAIL. that is all....
  #7
Old 03-26-2011, 11:26 AM
diesel_brad
Offline
STILL LEARNING
Member's Gallery
What happened?
  #8
Old 03-26-2011, 11:58 AM
Bryrylan's Avatar
Bryrylan
Offline
Member's Gallery
idk if the holes were messed up from the screws or what but I drilled the holes per the instructions installed the rivnuts and they pulled threw on 2 and ones spinning in the hole with the bolt half in... it pissed me off so much I walked out and have been driving my dump truck all week.
  #9
Old 03-26-2011, 02:50 PM
CSIPSD's Avatar
CSIPSD
Offline
<<< THE GAUGE WHORE...
Member's Gallery
I had a visor on my 97, the holes pulled out due to winds, so I put bigger screws in, which also pulled out, then I got some elevator bolts and nuts. Removed the head liner and drilled clean thru, installed the flush nuts with some JB weld to keep them from spinning. It held for as long as I owned the truck from that point.
Not sure if the superdutys are set up the same with the double walled metal around that area, but it worked for the OBS.
__________________
01 F-250 SC PSD,260k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, P.I.S 230/100, Studs, 910 springs, Forged rods, Water injection,Swamps Tuning, MBRP 4" dual's, Aero, 6" tip's, 100 axl tank, 4" Revtek lift, 37-12.50-16.5 MT's
Joe
ISSPRO PERFORMAX GAUGES
  #10
Old 03-26-2011, 04:19 PM
Doodah's Avatar
Doodah
Offline
Member's Gallery
id take headliner out and fanangle something from the back side, with a tig welder, or JB weld and nuts to some sort, im not a big visor fan, but if there was a visor on the truck I owned, and I wasnt gonna spend the money on having holes filled, this is what I would do, just please dont go as far as leaving visor off and lug holes with something just to keep water out, crap just looks too noticable!
__________________
07 cummins mega cab 2500 4x4 dark gray metalic 35s 17x10 diamo 17karot rims ranchhand. triple disc precision converter.built trans 282k and counting...
2001 250 superduty 4x4 CC SB dark blue met. 3"lift 35s
(View-All Members who have read this thread : 84
02 CCSB, 03-blue-Powerstroke, 08powerstroke22, 1978psd, 24vCRtoAStroker, 4duggan, 500pilot, 7.3 King Ranch, 83f350, 907DAVE, 91turbogsx, 96'BigBlue, Bamboo, Big Papa 03 dually, big white7.3, BIG01RIG, BigJeremy, BMac, Bobus, brian350x, Bryrylan, BUFF, Bushwakd, captzach, Cincinnati Guy, cj45lc, ckozak10, codykthekilla, CSIPSD, cyclesico, deiter5262, Diesel81, DieselFreak92, diesel_brad, dmoffat, Doodah, doubleshot, Duratys, Dustin F2504x4, Ewilly, farmall99, ford7.3sd, hill_billiez, jdc753, Jeremy, jimhall_az, LILGSX, longlivepowerstrokes, LOSTCAUSEPOWERSTROKE, LukeDM, Matt_P, monstered, Nascar_fan28, nelsonar, O2ShootTheJ, OldSchool101, opieg01, powerstrokedkid87, procomp, PwRsTrKe8907, rat49f6, rdr99, Roberts450, rocketron, Roz, rtm038, scro, semmens21, Snake, Steve321, stoney126, strokingkid1392, strokinthe6L, superdutyfarmer, TAMU_PSD, Tom S, TxFire, UNBROKEN, vcassens, white7.3, WikedLizard, xrxmxcx, zaairman
You may not post new threads
You may not post replies
Forum Jump
