wheel back spacing - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > F-250 & F-350 1986-1997 & Other Ford Trucks > 1994-1997 General Aftermarket
Thread Tools Display Modes
  #1
Old 03-10-2011, 10:38 PM
Orangeracer's Avatar
Orangeracer
Offline
Brian
Member's Gallery
Send a message via AIM to Orangeracer
wheel back spacing
i am going to order some wheels. the Micky Thompson classic 2;s 16in. What is the back spacing? and how wide should i go. I would like to get a set of tires that would look good. but was thinking 285 75 16 bfg. Just till i get it lifted then use the wheels for winter, or drag racing.
__________________
92 superduty cummins 5 speed dump
96 f250-550 cclb cummins 5 speed
97 f350 cclb 2wd cummins auto
Old 03-10-2011, 10:56 PM
Bradbilt's Avatar
Bradbilt
Offline
STILL LEARNING
Member's Gallery
Re: wheel back spacing
4.5" BS
__________________
97 CCSB 4WD 7.3 5spd DP Tuner, 6637, 4" Flo-Pro SS Exhaust(3" DP), 99 I/C, T500,Cali Truck w/120cc Split Shot Injectors, 1.0 exhaust housing/WW2, Irate Up-pipes, CCV Mod, Autometer gauges, Valair Organic clutch, PFM 2.25" RSK, PMF Traction bars, Rear Air bags,SD springs Front(V code)/rear(B code), 315/75/16s, 300HP/561TQ
  #3
Old 03-11-2011, 02:03 AM
Orangeracer
Offline
Brian
Member's Gallery
how wide wheel for a 285 75 16
  #4
Old 03-11-2011, 09:01 AM
Bradbilt's Avatar
Bradbilt
Offline
STILL LEARNING
Member's Gallery
7-8"
  #5
Old 03-11-2011, 12:45 PM
dbd181's Avatar
dbd181
Offline
FordDave
Member's Gallery
My MT Classic II's are 4" BS and 16x8. BTW, if I could come up with a stock set of Alcoas, I'd make you a deal on mine. Stainless centers too.
__________________
99.5 F-250 ECSB 4x4 auto.
Intake with Donaldson B085011, muffler delete
  #6
Old 03-11-2011, 09:03 PM
Orangeracer
Offline
Brian
Member's Gallery
do you not like them? could you post photos up with your truck and them. thanks
  #7
Old 03-12-2011, 01:05 AM
hendricksbus's Avatar
hendricksbus
Offline
Member's Gallery
which one is it? 4'' or 4.5'' for the back spacing?
__________________
1996 F-250,Ext.cab,LB,4x4
stock tires
180K,6 pos chip,Open air filter, 3'' down pipe,fpr mod,ccv mod
4.10s gears!
Boost, Pryo and transmission gauges
sonnax shift improver kit
bronco tank mod
hayden cooler for transmission
  #8
Old 03-12-2011, 01:48 AM
dbd181's Avatar
dbd181
Offline
FordDave
Member's Gallery
Part# Size Appx. Weight Bolt Circle Back Spacing Offset (mm) Load Capacity
368482 16x8 21 8-6.5 4 -13 3,100
Copied from the MT website.
  #9
Old 03-12-2011, 01:53 AM
dbd181's Avatar
dbd181
Offline
FordDave
Member's Gallery
I like em, I just want to run a 235/85 or 255/85 tall skinny tire and keep them tucked under the fenders more. Works better on a 7" rim. These are 8".
  #10
Old 03-13-2011, 05:40 AM
Orangeracer
Offline
Brian
Member's Gallery
what would be the benifit of under the fender more? fender flares?
(View-All Members who have read this thread : 96
02redpwrstroke, 08farmerstroke, 1990 Scorpion, 302bullitt, 550ss, 7.3_Stroker, 8inchstroker, 8nout, 96strokeme, 97F250 HD, AMB, apollyon9515, Ausm7499, BackRoad_Flyin', BadDogPSD, biggreen96, bigwhite7.3stroker, bolsen115, Bradbilt, Bradysmail1969, broodu, CJR, coalroller250, colombo97, Colt_FX4, CSXPAID, ctch1, danielzink, darknight, Darth_Stroker, dave_k96, dbd181, DieselFreak92, DMDP, Doctorsmack, Dusty Roads, dustytires, dwbierbach, eric96ford, foxman, fuekear, glovemeister, Got4wd, Greger96obs, gstang408, hendricksbus, Integracingsr, Jagshred, Jason.Horath, JCart, jimmiejet, Jngreen, John-Boy, JspecGarage, K5383, kip4234, Krause, LawnRanger, losrocket, Luda25, machete31, mgroshong, minidiesel, MustangMatt96GT, NRHX2009, oneton, Orangeracer, P714, powerstroke95, powerstrokin97, PSTORPEDO95, Rambler, RedBull_04, rpm-inc, samickguy15, silent64, slowngreen, SMOKE&STROKE, Smokin'nStrokin73, Smoninc, SouthFlstrokin', speeddemon31176, speedup, stroker2, Super Duty Dude, TacticalMonk, Thrilbilly97, Tom S, UniDub, washingtoncoastie, WolfTraxx, YoungFordAddict66, zabeard, ~NASTYSTROKER96~
You may not post new threads
You may not post replies
Forum Jump
