2001 ford F250 Auto Transmission - PowerStrokeNation : Ford Powerstroke Diesel Forum
Thread Tools Display Modes
  #1
Old 02-27-2011, 03:59 AM
corbin9191
Offline
Member's Gallery
Hey everyone I am new to this site and I have a question for you. We have a 2001 Ford F250 SD with the 7.3 liter, The problem that I am having is this morning I was moving my trailer and went to shut the truck off because I needed the keys for the tailgate. So I go and shut the truck off and it is shut off for about 10 min's, then I go and start the truck up again and let it run for a few minutes. When I went to put the truck in drive I pushed on the pedal and nothing happened, it is like the truck was in neutral. I had the rev the engine while in drive up to around 2700 rpms just to get the truck to even barely move. But the truck will work in reverse. I have checked the linkage and is was tight. I changed the fluid and there was no metal shavings or nothing. I am thinking that it may be the Tranny pump? What do you think? thank you
Old 02-27-2011, 04:54 AM
speeddemon31176's Avatar
speeddemon31176
Offline
Demon Dually
Member's Gallery
Re: 2001 ford F250 Auto Transmission
It isn't the pump. You wouldn't have reverse either if it was the pump. Your transmission range sensor may have gone bad or have been knocked out of adjustment. That is the sensor that is on the driver side of the transmission behind the shift lever. There are two small hash marks that need to be aligned perfectly or it will throw the transmission into OD instead of first gear.
__________________
  #3
Old 02-27-2011, 04:59 AM
corbin9191
Offline
Member's Gallery
I will check that in the morning when we do more work to it. I have also been reading about a mechanical diode. Would that do it as well?
  #4
Old 02-27-2011, 05:26 AM
speeddemon31176
Offline
Demon Dually
Member's Gallery
Ah crap. I missed that it is an 01. Yep you probably exploded the dam diode. Your going to have to rebuild it then. Sorry bud.
  #5
Old 02-27-2011, 02:55 PM
corbin9191
Offline
Member's Gallery
I just found a tranny with 44,000 miles on if for a good price. it came out of a 2003 and it says it will fit a 2001 with the 5.4 liter. My question is will this tranny still fit in the 7.3 liter diesel and still be string enough? This is exactley wha is says (FORD F250SD PICKUP 01 A.T.; (4R100), 8-330 (5.4L), 4x4, ID 1C3P-BC)
  #6
Old 02-27-2011, 02:59 PM
black7.3's Avatar
black7.3
Offline
Member's Gallery
No a gasser trans. will not fit behind a diesel.
__________________
03 F-250 all black CCSB 4x4 7.3, 4" straight pipe, DIY Intake, Boost, Pyro, and Trans. gauges, 07 harley headlights. 4" lift, 35" bfg's
79 F-150 351M, 4x4 headers and some other goodies, The camo truck
  #7
Old 02-27-2011, 03:13 PM
corbin9191
Offline
Member's Gallery
Ok, I didn't think so but I thought I would just check to make sure.
  #8
Old 02-27-2011, 05:18 PM
speeddemon31176
Offline
Demon Dually
Member's Gallery
Only a diesel trans fits a diesel, a bb trans fits a bb, and a small block fits a small block.
  #9
Old 02-27-2011, 05:32 PM
corbin9191
Offline
Member's Gallery
Ok, I found a tranny for a 7.3 liter but it is for a 4X2 and we have the 4X4. Can we unbolt the back part of the tranny and bolt the transfercase on to it? or does the tranny have to be for the 4X4 also? I also found a new tranny for a 00-05 ford excursion with the 7.3 liter, will it work in it or is just a little bit different? Because the price it $100 dollar difference between the too. But this one is for a 4X4.
  #10
Old 02-27-2011, 05:47 PM
speeddemon31176
Offline
Demon Dually
Member's Gallery
Nope the output shaft on the 2 wheel trans is longer and will not work on a 4 wheel. If you find one from an f superduty which is the obs body you can pull the brake assembly off the trans and it will work.
  #11
Old 02-27-2011, 06:11 PM
black7.3's Avatar
black7.3
Offline
Member's Gallery
I wouldn't waste the money on a used one bite the bullet and get yours rebuilt or get a ford reman. The odds of getting a "good" used one is not very good. And you will most likely end up with a broken truck again in 6 months.
  #12
Old 02-27-2011, 06:22 PM
corbin9191
Offline
Member's Gallery
Ok, this tranny from the 00-05 excursion is re manufactured with 0 miles on it as well as the F250 tranny. 0 Miles on it to. I just didnt know if we could save to $100 dollars between the excursion tranny and the tranny for the F250 sd. But We are going to get the tranny rebuilt or get the Re manufactured tranny.
  #13
Old 02-27-2011, 08:44 PM
gottagofast's Avatar
gottagofast
Offline
Freak'n know it all
Member's Gallery
my .02.........................
go ahead and 86 the rebuilt trans unless it is from bts or john woods
reman from FORD only or built by bts or john woods should be considered the only choices
__________________
99.5 350 crewcab dually 4x4
stage 1 singles, PHP tunes, banks bighead, autometer gauges, F-650 dash mod, 4r100 to ZF-6 SWAP, South Bend OFE-K clutch, Gen 2 wicked wheel,
  #14
Old 02-27-2011, 09:41 PM
dmd's Avatar
dmd
Offline
Member
Member's Gallery
A BTS or JW is a new trans, not really a rebuild.. everything is new and is
way overbuilt for anything you will put at it unless you put $15K in the engine.
It will be the last transmission you buy. I plan on keeping my truck for many
years so I dropped in a BTS when mine started slipping. Done, no more
trans problems..
__________________
'00 F350 Supercrewzer Lariet, PSD, Auto, 3.73, CC, 4x4, SWB, SRW, F250, 6 position chip, 6637, 4-inch turbo back exhaust, 38r w/ high flow turbine outlet, Adrenaline HPOP, BTS Trans, Swamps IDM, AIH delete, in-tank/pre-pump mod, heater/AC mod, Harvest Gold and Black / Packages: Trailer Tow, Camper, Off-Road. Overhead monitor DVD/TV/VCR
  #15
Old 02-28-2011, 08:32 PM
aklim's Avatar
aklim
Offline
Member's Gallery
You might have something rare on your hands if I understand you correctly. After mid 03, they went to the 6.0L truck so how will your trans fit?
__________________
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U front and A Rear.
  #16
Old 03-01-2011, 05:49 AM
corbin9191
Offline
Member's Gallery
I never thought of that. I called some of the local shops around here and they have the best feedback in the whole state. They are going to charge $1150 for a full re manufactured tranny with the updates.
  #17
Old 03-01-2011, 06:28 AM
speeddemon31176
Offline
Demon Dually
Member's Gallery
Tell them you want the z-pak clutch kit and the updated 6 pinion sprag and the tricumulator update and if you want firmer shift and better tc lockup then you want to have them do a .427 or .500 valve and the tcc valve modified.
  #18
Old 03-01-2011, 01:48 PM
aklim's Avatar
aklim
Offline
Member's Gallery
That is pretty cheap and in the Jasper or Aamco range. I would be highly suspicious of what you get with that. You can ask Franko72 on FTE what he went thru for a "cheap" build from a guy with good feedback. $1100 is VERY light. It barely will cover my TC
truck is FINALLY back from the trans shop... - Ford Truck Enthusiasts Forums
  #19
Old 03-02-2011, 10:04 PM
corbin9191
Offline
Member's Gallery
Well We have the local shop going to re manufacturer a tranny for us with all the new updates. We have delt with this shop before and the transmissions we got from them before are great quality. I do appreciate all the help from everyone!
  #20
Old 03-03-2011, 12:41 AM
gottagofast
Offline
Freak'n know it all
Member's Gallery
may the force be with you.
  #21
Old 02-08-2013, 07:23 AM
fordcowboy2000
Offline
Member's Gallery
I have a 2001 F-250 Power Stroke with an Automatic transmission. When I pull out from a stop, the transmission winds up until i let off the gas peddle. Once I let off, then it shifts gears and runs normal through the rest of the gears till i have to stop or slow down again. Does anyone happen to know what the problem may be? I just changed the filter and fluid which had the burned fluid smell to it.
  #22
Old 02-08-2013, 03:03 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Offline
Former Ford Trans Engr.
Member's Gallery
Yes, I know what the problem is. Your transmission needs to be rebuilt or replaced.
In 2001 Ford installed a new type of one way clutch called a Mechanical Diode. They were VERY prone to failure, so they went out of production towards the end of the 2001 model year. When they fail the symptom is a delayed or non-existent 1-2 shift. All other shifts are normal.
__________________
Mark
  #23
Old 02-10-2013, 09:07 AM
fordcowboy2000
Offline
Member's Gallery
That is exactly how it is shifting. RPM's go up to 3,000+ and then it shifts, or sometimes, i have to let off the pedal to get it to shift. once it shifts into 2nd, everything else shifts fine.
Also, is there any easier way of looking to see which transmission I need, without dropping mine to look?
Thanks for any and all help.
Brian
  #24
Old 02-10-2013, 01:28 PM
Mark Kovalsky
Offline
Member's Gallery
You need a diesel version of a 4R100.
  #25
Old 02-11-2013, 06:21 AM
fordcowboy2000
Offline
Member's Gallery
Thank You again for your assistance..
  #26
Old 02-11-2013, 02:03 PM
7.3lifteddiesel's Avatar
7.3lifteddiesel
Offline
go big or gooo home!!!
Member's Gallery
ohhhhhhhh the 01 4r100 ive rebuild mine 2 times and i hate this tranny from what ive learned do it once a do it right the first time here how u gotta to it if u have lotsa money switch to a six speed rate away second choice bts transmission 5k tork converter lockup switch for 2nd gear lock also the most important of all is a 6.0 transmission cooler that for the guys that have a heavy foot like mee
  #27
Old 02-11-2013, 05:47 PM
PlatinumStroker's Avatar
PlatinumStroker
Offline
Member's Gallery
Wish I would have listened to the guys on here the first time and went with BTS! I have an 01 and took mine to a reputable shop around here and I'm still having problems! Cost me $1300 and still have to come out of pocket more! If you have the resources go with BTS!
Sent from AutoGuide.com App
  #28
Old 02-16-2013, 01:53 AM
fordcowboy2000
Offline
Member's Gallery
As i was leaving my shop the other day from having my brother look at the tranny tag for me, i noticed I can not put my truck all the way down into 1st gear. The shift lever on the column will not allowe me to drop past 2nd. it sits tight against the plastic. Any thoughts?
Thanks in advance.
Brian
  #29
Old 02-16-2013, 03:31 AM
Mark Kovalsky
Offline
Member's Gallery
I have a lot of thoughts. I'll even give you one about this problem.
I've seen this problem several times. Either rocks or ice collect around the trans where the shift cable attaches on the driver's side, blocking the shift lever from moving all the way.
  #30
Old 02-17-2013, 08:43 AM
fordcowboy2000
Offline
Member's Gallery
We crawled under the truck again, and all the linkage is clear from any rocks, salt, mud or heck anything at all. however, I seen in a previous post on here that there are notches on the shift selector that are suppose to be aligned. They are not. My brother believes that may be leading to the problem as well as the shaft in the steering column not being installed correctly. And like i said, the actual shift lever, is against the plastic housing when i put it into 2nd gear. Not enough space for it to drop to the next gear down. I am just so frustrated right now with everything going wrong in such a short time.
  #31
Old 02-28-2013, 04:24 AM
fordcowboy2000
Offline
Member's Gallery
OK Everyone... Scratching my head again. The last few days driving the truck, for like the first 15 miles or so the truck is now shifting perfectly fine. After that, it starts not shifting on it's own. Since I changed the filter and fluid, The fluid is not moving on the dipstick at all. Running or cold, its the same level. No one in my area is able to rebuild the transmission for at least another 6-8 weeks. Unless of course I drop my whole savings and take it to a major shop and have a jasper put in. (Never had luck with Jasper). Could anyone offer any advice on which direction to take now.
  #32
Old 02-28-2013, 08:50 PM
Mark Kovalsky
Offline
Member's Gallery
Find someone with a scan tool that can read live data. See what the PCM is telling the trans to do. I'd hate to see you rebuild the trans and still have the same problem.
(View-All Members who have read this thread : 246
'01STROKER250, 00 ford f250, 00 stroker, 01grnstroker, 01REDSTROKER, 01strokin, 02 CCSB, 02EXCURSION, 02redpwrstroke, 06 f250 man, 2006nytro, 250turbo, 444-4D, 450ciPSD, 4BigGreen, 7.3 Ford, 7.3 superior duty, 7.3lifteddiesel, 76scout, 82crawler, 91turbogsx, 94strokeher, 95powersmoker, 96PSD, 99liftedstroker, 99redf350, ADubDiesel, aklim, Andytheman24, Arisley, arkayem, ArmyGuy45, AzPsd55, bcherry39, beyondlogic, Bice, bigblue01, bigdogf350, Bigs88, Biscayne, black7.3, Blackbullet73, Blake Williford, bldanddrive, bob98247, boggerr, Boost96, boostaddict, BradleyStuart, Brasquatch, Breacher, Brian918, brianb7.3, brick, brobrad, bruce51d, bryan.d, bubz37, Buford-61, burger318, C&A fish, cadd, camaroicoc, CGMKCM, chadder1313, chrismartin2, chunkdunker, clem1226, cnoecker, co04cobra, Cody48, COFG-28, ColeTrain45, corbin9191, Cowboyup, crawla, CTC DEEZUL, Cutty72, cvhs0254, Cypriss32, dalejrfan88, darklcdfeller, David N, dbcampbell, DcMoore999, Decooder, Dgriffith, Dieselpop, dirtboy25, ditch_dawg, dmd, doc millworm, dogtooth, Doodah, doublej112, Driles85, duncan351, dunnc89, dustinz85, Dusty Roads, dws1230, erniesshop, erskine_e, F250 Fever, farmer09, fastedy, firedude26, Fischer, FleetMan, flip2spin23, fordboy424, fordcowboy2000, forddieselkicksass, FordPower, fr0stbytten, FuturePharmD, fwbkent, gary02psd, Gbdjunior, gold7dot3, goosyboy, gottagofast, grecoface, hammer249, haulin2000, hofiveo, Honeyshucks4, hughj555@comcast.net, I B STROKIN, iamnonstop, Illinois7.3, Ithumpwheniwalk, jcotton, Jellyroll22, jetdok2r, jkelly3919, JMF350, Joefish, johnday, juniort444e, justin 01, juvenile9, k2xp, KDM, kilapapipa, klapka, kstone2020, kystanger, La7.3, LCOwner, Local399, lord7, lovemytruck37, lovesdunes, lyrch, MACK8592, Mamps, Mark Kovalsky, markt, Matt-X, mesjr69, metalphd, milehighstroker, MontanaPSD, Montgomery P-Stroke, mprobst, mstadler13, Muledude, NE-STROKE, nine54, Northcountrywood, northwest stroker, no_pistons7, Okieboy32, opieg01, Optimuscrime, outlaw13d, Platinum Crew, PowaStroka, powelce, Powerstatement, powr2stroke, procomp, PSFAN, Racer72, ralph, Randysrollincoal, RC4WD, retiredsparky, rich, RichD, rsbhunter, rsfvscott1, RT8541, Ruslgu3, sargentdan, savvy1, sbrofford, skank, SledDogg, smallsgotmoxey, smith7.3, smokin99stroke, smutwagon, snortweeze, snowman600, sokdaddy444, SouthFlstrokin', speeddemon31176, steve phillips, SteveD, str00ker, stroked2000, Stroked383, strokeman, stroker2, StrokerTurbo7.3, Strokin96, t.land, TARM, tbolt, teamorange7, thediyguy, theron1128, Thomas7.3psd, Tinstar36, Tmac21, Tomygun, Tonysabo, towsurfer, Tprov, travis182008, truckguy, twisthappyr6, TxFire, vintage way, WA_PSD, Welpracing, white7.3, whitjo, yank50, zaairman, zx800x
You may not post new threads
You may not post replies
Forum Jump
