Headlight switch connector wiring diagram - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > F-250 & F-350 1986-1997 & Other Ford Trucks > 1994-1997 Power Stroke Technical Info
Thread Tools Display Modes
  #1
Old 02-21-2011, 11:41 PM
LiftedSuzuki's Avatar
LiftedSuzuki
Offline
Member's Gallery
Anyone have one for a OBS pickup? 94strokeher is installing gauges and I can't remember what wires I tapped into and Ford sent me on a wild goosechase trying to find a website. I could always take mine apart but I figure someone knows off hand. Thanks
Old 02-21-2011, 11:42 PM
Magnum PD's Avatar
Magnum PD
Offline
Dairy Mechanic
Member's Gallery
Re: Headlight switch connector wiring diagram
You need a wire to connect the lights for the gauges?
__________________
96 Ford F-350 200 cc's, Electric fuel system, TS chip, 17 oil pump, Banks intercooler, 3" intake manifolds, SNOW Water-Meth system, South Bend DxD 3600, Banks brake, 4" stacks. Tuff country ladder bars.
IH RULES Not a 6.0 fan, engine out right now.
  #3
Old 02-22-2011, 12:09 AM
LiftedSuzuki
Offline
Member's Gallery
Yeah for the power wire so they turn on when he turns on his running/head lights
  #4
Old 02-22-2011, 12:11 AM
Magnum PD's Avatar
Magnum PD
Offline
Dairy Mechanic
Member's Gallery
I would get the one that dims with the dash. Guess I kept testing to see witch one was the right one.
  #5
Old 02-22-2011, 12:25 AM
LiftedSuzuki
Offline
Member's Gallery
Yeah thats how I did mine
  #6
Old 02-22-2011, 12:51 AM
Bugman's Avatar
Bugman
Offline
Member's Gallery
Why not just tap into the #10 fuse. Or it could be #4 I dont remember just which one it is but it is labled on the cover. It is for the instrument panel.
__________________
  #7
Old 02-22-2011, 01:02 AM
LiftedSuzuki
Offline
Member's Gallery
That would be good for the constant power but he also needs a switched so the gauges light up when he turns on his dash lights.
  #8
Old 02-22-2011, 01:47 AM
Bugman's Avatar
Bugman
Offline
Member's Gallery
That fuse is only how when the lights are on and it is also on the dimmer
  #9
Old 02-22-2011, 02:02 AM
Patrick Feeley's Avatar
Patrick Feeley
Offline
Member's Gallery
As bugman mentioned, #10 fuse. If you do want to go off the light switch, it's a White wire with Light Blue trace (pin I, which goes to the #10 fuse in the fuse box and then onto the instrument cluster (Light Blue wire with Red trace). Cheers!
__________________
(View-All Members who have read this thread : 57
00stroker, 7.3-StRoKeR, 94strokeher, 95psd2, 96powersmoker, alazure1, biggreen96, BigSal, borncountry, Bugman, Chewii, cody#powerstroke, cowboyengel, danielzink, derteracing, desertred4, Diesel_Kidd222, dsinderson, Eightrac, eleventhtruck, eric96ford, flyboy41, Fordguy26, glovemeister, gtmustang00, guardian, hendricksbus, Irishredneck, jhaddox, JMWRIGHT335, JSchuricht, LiftedSuzuki, lineman13, louisvanwilker, madpogue, Magnum PD, My95stroker, ngtstk3r, NORCALOBS95, oneofakindSD, OverkillMotorsports, P714, Patrick Feeley, Powerstroke08, powerstroke095, Powerstroke_21, rob72, shmober, speeddemon31176, StandAlone, STILLKICKIN_F250, swamp_ratt, tdevinejr, teevo66, theoldgirl1990, tsanjose, Turbotoni
You may not post new threads
You may not post replies
Forum Jump
