| Register | Members List | Timeslips | Calendar | Sponsors | Becoming a Sponsor | Mark Forums Read | Auto Escrow | Auto Loans | Insurance |
Thread Tools | Display Modes |
#1
Going Synth back to Rotella15-40
So give me some honest hands on techinical proof this is a bad idea.. I don't care fo rhe long interval changes and to be honest never notice a damn thing over my past two trucks that it ran any better or worse with oils. I have Amsoil syn in it now and its noicy as could be which I don't mind but, just like any oil change is it runs best when its new. So changing oil every 3-5k miles will always give me that and help clean stuff out rather than going 8-10+k miles on syn and having the last half of the run be loud. Be a lot cheaper and I can get very easy whenever I need to instead of chasing down amsoil. Before I got truck was told they ran mobile 1300 Delvac. Only did 8K on amsoil and I need to change it I have been towing and plowing and its winter so I like to do more often.
So input please?!
__________________
Jim
'08 F-250 CCSB S&B - Spartan - 5" 2.5" Leveled - 20x10 ATX 35" BF AT's |
| Sponsored Links | |
Advertisement |
#2
Re: Going Synth back to Rotella15-40
edit: Here is a better link to the diesel oil forum: Heavy Duty Engine Oil (HDEO) - Diesel/Gas Pickups/Trucks/Vans - Bob Is The Oil Guy
__________________
2003 F250, Wildman tunes, Faubion trns, Swamps 175/146 SS,van turbo/WW, DI Intercooler, oilguard bypass, intank & pre-pump, reg return, Firestone air bags, Bilsteins, 350 HP/692 TQ 2000 Excursion- Pwrd by: T Wildman 6 pos chip, CT Performance Suspension, Riffraff Diesel Performance, J&M Tranny, 4" MBRP, 6637 filter, intank/prepump mods Last edited by White Buffalo; 01-20-2011 at 06:37 PM. Reason: update link |
#3
I ran the regular rotella and had no problems. When I would do an oil change at 5,000 miles the truck would run alot better. I switched to the rotella synthetic and it seemed to start and run alot better and even get a little better milage ( better than a fresh regular oil change). I still change the synthetic oil at 5,000 miles. The synthetic oil change doesnt seem to make as big of differance as the regular oil change did. So I would say the sythetic is a better oil. at $20 a gallon, I'll stick with the rotella brand.
__________________
Wink Fab - cnc machining and fabrication97 f350 4x4 410 gears 37 BFG, 4" exhaust, dyi, tw chip, IDM mod, .427 sonnex valve, rsk w/sd springs, greasable 4x4 lever,Rosewood stage 2, T-500 hpop,1.0 ex housing These trucks are like crack, you just can't leave it alone. |
#4
i noticed when i switced to syn. from dino that the oil went black with in a couple hundred mile. is the syn just cleaning out the engine? also seen a very noticeable cold weather starts improvement.
__________________
1996 F-250,Ext.cab,LB,4x4 stock tires 170K,6 pos chip,Open air filter, 3'' down pipe,fpr mod,ccv mod 4.10s gears! Boost, Pryo and transmission gauges sonnax shift improver kit bronco tank mod hayden cooler for transmission |
#5
I use Motorcraft HD 10W30 in the winter and Motorcraft 15W40 in the spring summer here in Maine and my 6.0 loves it.. I change it at no more than 4K.. The oil is cheap and easy to get (Wal-Mart).. I know what your saying, I don't think it's worth useing the syn oil.. I just go by my manual and it has served me well.. |
#6
Moroney167, u might not see the difference in how the truck runs like these others. u have a 6.4, they have 7.3's and 6.0's that use the oil to drive the injectors and shear the oil down..
also, without UOA, i wouldn't run extended interval on any oil.
__________________
2002 F-250 ccsb, 7.3, Auto, 4x4, BDP Tunes, Stealth Drop In, 4" MBRP, 6637, Van turbo WW ATS, Frantz Bypass,Drilled & Slotted Rotors |
#7
If finding the synthetic is a big issue, just run Rotella T6 from Wal-Mart....it'll be better than regualar Rotella for your motor...
__________________
-08 F350 CC/SB -S475 Billet turbo with .90AR housing @49PSI -Elite custom aged Head studs -Elite Valvetrain upgrade W/ Colt Cam (stage2) -Black Maxx with MCC custom tuning -SUNCOAST BILLET transmission W/ Precision TC -Air Dog DF165 -Caltracs traction bars -Detroit Locker -Amsoil bumber to bumper -BIG THANKS TO REIFF DIESEL!! |
#8
__________________
2002 F-350 ECLB SRW 7.3 4R100 6637 203* t-stat 08 diff cover Stancor HPX 6.0 trans cooler Sold: 2004.5 Ram 2500 w/ 5.9 CTD, Reg Cab 48re |
#9
ok here's my .02 I have a 7.3 with 158K on it . I have used Motorcraft,Rotella and Valvoline Premium Blue Synthetic.
Motor was pulled at 142K for bad front cover so my motor was flushed with new oil every 2k for 6K and changed every 5k after that. Rotella 15/40 makes the motor run sluggish and impossible to start in the winter even plugged in and Romps like hell. I just dont like it . Motorcraft15/40 seems to start fine even cold but the engine "sound" is at it's best and just sounds strong to me Valvoline 5/40 synthetic I hate . The engine smokes like crazy when it's cold and the smoke is like a mist you can't get off you. The engine sounds like a ticking BOMB . I will never put synthetic back in my motor. I will run and change my Motorcraft 15/40 every 5K until I get rid of it. We all know when our engines sound best. I would get that oil outta there . Just my thoughts and give Motorcraft a try . |
#10
Did I tell ya I don't like synthetic LOl
| Thread Tools | |
| Display Modes | |
