What coolant to use in 6.0? - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.0L Power Stroke Technical Info
Thread Tools Display Modes
  #1
Old 01-19-2011, 09:43 PM
Abbott
Offline
Member's Gallery
Going to flush my system here soon. What coolant should i use in the 6.0?
Also diesel site or dfuser coolant filter kit?
Old 01-19-2011, 10:10 PM
Matt07
Offline
Member's Gallery
Re: What coolant to use in 6.0?
use motocraft gold antifreeze. and either filter kit, just as long as theres a good filter on it.
  #3
Old 01-19-2011, 10:15 PM
Offline
Member's Gallery
Don't use Motorcraft Gold coolant.. Use International ELC coolant.. The Gold coolant is what was recommended but there has been some proof that it clogs the oil cooler.. I did notice my local Ford garage is now reccomending the ELC for the 6.0..
  #4
Old 01-19-2011, 10:17 PM
Matt07
Offline
Member's Gallery
damn, i didnt know that.
  #5
Old 01-19-2011, 10:32 PM
Abbott
Offline
Member's Gallery
Where can i get the International ELC coolant?
I just ordered the dfuser coolant filter kit. 150.00 to my door, with three filters. i liked the dfusers T's better than the Diesel Site. It also came with 3 filters instead of just one.
  #6
Old 01-19-2011, 10:42 PM
Offline
Member's Gallery
Check your local Ford dealership.. My has it right on the shelf.. International dealer.. I'm sure someone else will chime in and post another ELC dealer location..
  #7
Old 01-19-2011, 10:44 PM
dieselmac
Offline
Member's Gallery
International's a good coolant but may be hard to find depending on where you live. Several other manufacturers make ELC's (extended life coolants). Just look for one that meets the CAT EC-1 specification.
Search on here for 6.0 gold coolant problems if you want an education in the problems with the Ford Gold junk.
__________________
2006 6.0L, Lariat, 2WD, SWB, 3.73's
  #8
Old 01-19-2011, 11:42 PM
bdavidsontexas
Offline
Member's Gallery
Evans coolant
__________________
Ford Certified POWERSTROKE TECH....
F250-550 Everything....
  #9
Old 01-20-2011, 02:54 AM
Abbott
Offline
Member's Gallery
Does any place like AutoZone, Wal-Mart, O'Riley's, or NAPA carry the coolant that is ELC recommended for the 6.0? I live in a small town and have these stores close by. Again thanks for all the help guys.
  #10
Old 01-20-2011, 02:58 AM
Fordfreak4life's Avatar
Fordfreak4life
Offline
Haters Gonna Hate
Member's Gallery
ZEREX G05, you can pick it up at any napa in the nation
__________________
  #11
Old 01-20-2011, 03:02 AM
PTSUPERD's Avatar
PTSUPERD
Offline
Banning Smut
Member's Gallery
This is what I run too....along with a Dieselsite coolant filter setup.
  #12
Old 01-20-2011, 03:03 AM
Fordfreak4life
Offline
Haters Gonna Hate
Member's Gallery
i bet it was recommended by the same guy hes an evil genius
  #13
Old 01-20-2011, 03:06 AM
dieselmac
Offline
Member's Gallery
Zerex G05 is OEM coolant. A.k.a Ford Gold Crap
Zerex does make an extended life coolant. I believe it's in a black bottle, says extended life and cat ec-1 on the front.
  #14
Old 01-20-2011, 03:09 AM
PTSUPERD's Avatar
PTSUPERD
Offline
Banning Smut
Member's Gallery
. Yep it was indeed. Twinkies are what makes him so smart so I hear.
  #15
Old 01-20-2011, 03:10 AM
Fordfreak4life
Offline
Haters Gonna Hate
Member's Gallery
werd brother werd
  #16
Old 01-20-2011, 03:11 AM
Fordfreak4life
Offline
Haters Gonna Hate
Member's Gallery
could you give Doug a call @ GOGO diesel and explain that to him? i geuss he doesn't know after being a ford master certified tech, maybe he can enlighten you and explain how the cow eats the cabbage eh?
  #17
Old 01-20-2011, 03:18 AM
dieselmac
Offline
Member's Gallery
Huh? G05 coolants are precharged with an SCA package. Same as the gold coolant.
  #18
Old 01-20-2011, 05:22 AM
2 Stroker
Offline
Member's Gallery
The 6.0 is known to blow head gaskets. This is why it happens. The Ford Gold coolant contains silicates. The silicates are not able to handle high EGT's generated by a good load or relatively high boost when run through the EGR cooler. They break down into a jell like sludge and fall out of suspension. This crud gets caught up in the tiny coolant passageways of the oil cooler. As the cooler clogs up it restricts coolant flow to the egr cooler. Now the egr cooler doesn't have enough coolant to carry off the heat generated by high EGT's. The limited amount of coolant in the egr cooler flash boils causing high pressure in the cooling system and the truck pukes coolant from the degas bottle due to the pressure. (it has to go somewhere)
Your uninformed Powerstroke owner is not monitoring his coolant temps and oil temps so he doesn't know whats going on and he keeps driving it this way. The problem get worse, the pressure causes the egr cooler to rupture. Now the egr cooler is leaking coolant into the intake manifold which then runs into the cylinders. Again the high combustion temps cause the coolant to vaporize. This causes unacceptably high cylinder pressure, the TTY head bolts stretch due to the additional pressure and there go your head gaskets.
Ok now you know the problem. Here's the cure. Get a good engine monitoring solution like the Edge Insight so that you can monitor your ECT and EOT. If those temps get more than 15* apart at normal cruising when at normal operating temperature your oil cooler is clogging up. Rebuild it now to prevent all that down stream damage from occurring. Flush that Ford Gold coolant cxxp out of your engine with a couple bottles of Restore. This is made specifically to clean out that silicate residue. Now refill it with a silicate free Cat EC-1 rated ELC coolant. This removes the silicates that clog the oil cooler from the equation. If you live in an area where you don't have smog inspections delete the egr system. If you can't delete it replace the egr cooler with the cooler manufactured by Bulletproof Diesel. This is vastly superior to the Ford oem egr cooler and it will not fail on you. If you find that you need to replace head gaskets replace the TTY head bolts with ARP studs and use black onyx (Victor Reinz) head gaskets. If you have to replace the egr cooler always replace the oil cooler. That is the source of the problem.
Here is the fix
ELC is the coolant recommended and used by International for this engine. .
Coolant Flush for changing to ELC
Drain coolant by removing lower radiator hose. Drain block from plug on drivers side of the block. Remove the thermostat. Replace plug in block and put lower hose back on. Put thermostat housing back on without thermostat. Fill with distilled water. run for 5 minutes then drain as above..Fill and run 5 more minutes drain. Put in 3/4 to 1 gallon of Restore an top with distilled water. Drive it for an 60-90 minutes then drain. Flush 2 times with distilled water or whatever it takes to come clear. Put 2 qts of VC-9 or 3/4 to 1 gallon of Restore+ cost less and fill with distilled water. Drive it for about 60-90 minutes. Drain and flush after. Flush 3 more times with distilled water untill it come out clean. Replace thermostat or put in a new one. Put hose back, make sure block plug is tight. Add 3.5 gallons of ELC concentrate and top off with distilled water. Make sure to run engine for 5 minutes between flushes to circulate the water good. Have heater on set to hi while doing this to flush the heater core too. new t/stat from Ford it should all come together (housing-t/stat-o-ring) in a box. The part number is RT-1169
If you like pictures have a look here.
Replaced oil cooler still difference in temps - Page 21 - Ford Powerstroke Diesel Forum
2 stroker
__________________
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS-Expandable Pyro
AutoMeter Fuel Pressure Gauge
Fuel Reg. Kit 3C3Z-9T517-AG
Amsoil By-Pass(Amsoil 5w40)
Delo ELC-coolant Filter
pulling 14,000 lb Alpenlite 5er
97 F350 4x4 PSD CC LB
PacBrake&ATS converter lockup
3" dp 4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
EGT,Boost,Trans
  #19
Old 01-20-2011, 05:40 AM
Motownfire's Avatar
Motownfire
Offline
<----My last CT scan
Member's Gallery
I use Fleetrite elc coolant and distilled water. I got the coolant from the international dealer in Houston.
__________________
  #20
Old 01-20-2011, 05:56 AM
PSDPlayer's Avatar
PSDPlayer
Offline
Captain Negativity!
Member's Gallery
Send a message via AIM to PSDPlayer
So it's the silicates that are killing oil coolers.
You do realize that even your precious Cat ELC needs its coolant package extended at 3K hours, 3 years or 300k miles, BASED ON CAPACITY.
The correct amount of Cat Extender to add is also dependent on system capacity. The addition of Cat Extender is based on ELC additive depletion data in the same manner that standard coolant SCA additions were determined. Due to the extremely slow depletion rate of ELC’s additives, Extender is only required once at the life of the coolant, (300K miles, 3K hours or three years, whichever comes first) and routine testing for inhibitor levels is not required. Best maintenance practices would include an annual Level 2 SOS analysis.
Your capacity is what compared to the CAT engine it was designed to go in? Half? A Third?
So Cat calls them a life extender. And Ford calls it system additive. One has carboxylates. One has 225-250 ppm silicates.
Silicates form in places where coolant doesn't flow. So trucks that don't see alot of heater core use tend to build up deposits.
For people that have repeat oil cooler failures. You know you are supposed to pull the thermostat a run about 2 gallons of the Purple Simple Green through the motor. NOT PURPLE POWER. Purple simple green is aluminum safe. PurplePower is not. This takes some time. Most people don't do it correctly. And they get to do it over again.
Then you get the people that don't check the EGR cooler flow. So they get to do it over and over again.
Better put that distilled water in there.
Both use nitrite and molybdate in them. So you have traded one for another. And the ELC stuff was designed to run in a system with a coolant filter. So if you have a filter on it, how are you going to say one is crap and the other is sooo much better.
__________________
Website:www.gogodiesel.com Forums:forums.gogodiesel.com Facebook: www.facebook.com/GoGoDiesel
Email: Doug@GoGoDiesel.com
Phone:954-275-6801 Leave me a message. I can't always answer.
05 CC LB DRW Lariat 4x2 Dropped 3/6.
  #21
Old 01-20-2011, 10:47 AM
b5dart70's Avatar
b5dart70
Offline
Member's Gallery
Originally Posted by bdavidsontexas View Post
Evans coolant
x2 great stuff.
__________________
2003 F250 CC SB 4X4 6.0 Auto
Current Mods:
Updated Ford Injectors, Air Raid Intake, Evans Coolant, High idle switch (1200RPM), no muffler (straight stock pipe from turbo), Auto-Start, HPOP, ICP sensor replaced, EGR disconnected, Tekonsha Odyssey brake controller.
Future Mods:
ARP Heads Studs w/new gaskets
SCT x3 via Innovative sitting in box
  #22
Old 01-20-2011, 12:47 PM
Abbott
Offline
Member's Gallery
Will any ELC work or does it have to be one of them brands?
  #23
Old 01-20-2011, 01:12 PM
FTG-05
Offline
Member's Gallery
There's a number of Cat EC-1 spec'd ELC coolants, Fleetrite, Cat, Shell Rotella, several more I don't recall the names to. Any good diesel shop should be able to get it or order it for you. I got my Shell Rotella from the local International dealer, but my understanding is that they no longer carry the concentrate, only the 50/50 mix.
Once you do a good flush with distilled water, you'll need about 3.5-4 gallons of ELC coolant, topping off with distilled water, to get the proper 50/50 mix. You can't get all the distilled water out when you do a flush, hence the need for the concentrate.
Good luck.
Al
  #24
Old 01-20-2011, 04:41 PM
PSDPlayer's Avatar
PSDPlayer
Offline
Captain Negativity!
Member's Gallery
Originally Posted by b5dart70 View Post
x2 great stuff.
The only trucks that I have ever seen to dissolve the brass coolant temp sensors were running Evans coolant.
  #25
Old 01-20-2011, 04:43 PM
Fordfreak4life
Offline
Haters Gonna Hate
Member's Gallery
hey boss, bout time you make a damn appearance in here
  #26
Old 01-20-2011, 08:32 PM
jonnysteals
Offline
Member's Gallery
guess you missed this entire post on page 2
__________________
TT
Zoodad mod, high idle mod, blue winshield washer fluid, cat delete mod, tinted windows
  #27
Old 01-20-2011, 09:16 PM
Fordfreak4life
Offline
Haters Gonna Hate
Member's Gallery
geuss so
  #28
Old 01-22-2011, 02:09 PM
buc1096's Avatar
buc1096
Offline
Member's Gallery
I use the Cat ELC with no issues, I did however have problems with Ford Gold with the gunky silicates. It may not be the definitive answer, but IMO better than the Gold.
  #29
Old 01-22-2011, 02:43 PM
444-4D's Avatar
444-4D
Online
Caption This
Member's Gallery
If I was changing mine today, I'd try to find some Shell Ultra ELC.
__________________
If only those who knew what they were talking about replied, this thread would still be on page one.
2000 F-250 CC 4x4 PSD Auto
  #30
Old 01-28-2011, 01:59 AM
Abbott
Offline
Member's Gallery
K going to try to find some around the area. I live out in the middle of no where. San Antonio is 2 hrs away maybe the only place i can find some.
  #31
Old 08-27-2012, 06:57 PM
5150lariat's Avatar
5150lariat
Offline
Member's Gallery
Ok I put in the egr delete and I know I messed up by not doing the oil cooler at the same time but I'm waiting for it to get here, so can I for now just flush out the system and add the cat ec1 coolant or should I use the restore and restore plus with distilled water then when I get my new oil cooler install it. What do you think.
  #32
Old 08-27-2012, 09:08 PM
5150lariat's Avatar
5150lariat
Offline
Member's Gallery
And also I had my wife go to caterpillar to get me some coolant, the one she got me says cat ec1 elc coolant but then it says premixed is that the wrong one or do they not have a concentrated or can I use that for a while till I can go get the right stuff.
  #33
Old 08-28-2012, 08:04 AM
fordguy61mi
Offline
Member's Gallery
I use Rotella ELC. It's CAT rated. It comes in a concentrate and also pre-mixed. Use the concentrate when changing over to ELC so you have the proper ratio and then use the pre-mixed stuff to top off level after you're changed over.
__________________
2006 Ford F250 Lariat Crew Cab FX4. Sinister EGR Delete, Sinister coolant filter, new OEM oil cooler, new HPOP, STC fitting upgrade, new dummy plugs and stand pipes, banjo bolts, coolant flush using Rotella ELC, 5W40 T6 Rotella synthetic oil with motorcraft filter, blue spring upgrade, Scangauge II, SCT X3 tuner with mild tunes from MKM Customs.
  #34
Old 08-28-2012, 12:47 PM
FTG-05
Offline
Member's Gallery
That's what we put in a friend's 6.0 about a year or so ago. The local International dealer had it instead of the CAT-1 ELC, said that's all they're selling now. 600k vs. 300k IRC.
  #35
Old 08-28-2012, 03:13 PM
444-4D's Avatar
444-4D
Online
Caption This
Member's Gallery
Ultra ELC meets Cat EC-1 specs.
  #36
Old 08-28-2012, 05:47 PM
Idahoser
Offline
Member's Gallery
you can't do it with premixed. You'll never get a 50/50 because there are several gallons of the distilled water still in there.
__________________
2005 F-250 XLT SuperCab long bed 125k. ScanGauge II. 3X Fumoto's. Dieselsite filter. BPD EGR cooler. Blue Spring. Rotella ELC. Rotella T6. Archoil 9100. Improved HFCM plug. Power Service every tank. 24" wipers. PIE. AutoEnginuity.
  #37
Old 08-28-2012, 05:48 PM
Idahoser
Offline
Member's Gallery
Here is the fix
2 stroker
except that Ford head gaskets are now recommended over the Black Onyx, this is all still good advice. F-108N Fumoto Valves will fit in the block drains, keep you from filling your starter with water and making the job overall much more pleasant
  #38
Old 08-31-2012, 01:42 PM
FTG-05
Offline
Member's Gallery
Correct; I was referring to the original ELC not imply that Ultra didn't meet it.
  #39
Old 08-31-2012, 03:47 PM
cfd f-350's Avatar
cfd f-350
Offline
Member's Gallery
delo red elc
  #40
Old 09-03-2012, 05:42 PM
bzy livn
Offline
Member's Gallery
Went by Napa today they Sell Zerex EC-1 coolant 13.95 approved for cummins, international, Detroit diesel and so on.
  #41
Old 09-14-2012, 04:34 PM
ford rules
Offline
Member's Gallery
So the zerex g05 is okay to use or no?
  #42
Old 09-15-2012, 10:20 PM
DieselDan73
Offline
6.0 Guru
Member's Gallery
It is not ELC. Don't use it. That is what Napa tried to sell me first. Same stuff as Ford Gold.
  #43
Old 09-16-2012, 12:53 AM
ford rules
Offline
Member's Gallery
Ended up using rotella elc that's cat ec1 rated. Just gonna return the zerex.
(View-All Members who have read this thread : 400
004stroker, 03-6.0whistler, 03F250 6.0, 03strokin, 04 oilburner, 046.0, 05powerstroke38/24s, 06 f250 man, 06_WhiteBull, 07-OUTLAW, 07plower, 07_powerstroke, 123rday68, 1bad306, 1bad4x4, 1snowcat, 2 Stroker, 2003ford, 2004Stroker6.0, 2005Harley6.0, 2005stroker, 2006.1f250, 2006Duty, 2008 f350, 250strokin, 2wheeljohn, 444-4D, 4d4life, 501outlaw, 5150lariat, 6.0.downlow, 6liternole, 6pointOHHH, 6speedSD, 760 psd, 79puller, 96blowncobra, 96F350Kid, Abbott, Ajdelhomme, ajennings, amdriven2liv, Antennaman, AR Aggie, Arctic Fox, b5dart70, Backwoods Electric, BackwoodsPowerstroke, bad moose, BB6.0, bbmxandfmx, BBowden73, BCS, bdavidsontexas, bear1, Beef52751, Benito, BIG99, bigbadford01, BigD2623, BigDeal21, Bigdog, bigfords, BigKidTurbo, bigrngyj, BigSal, bigvela6.0, billc, birdrl, bismic1, blkbrd36, BlkWolfe, bluovldeezl, boobin, bootcamp, BOYER74, brute_mt, buc1096, buckshot63, bUDDY1, buggut, Bushwood_6.0, Bustedflush, bustednuckles, bzy livn, Cajunhunter67, caleb90, Capricious, captainharley6.0, Captyoda, cattlehauler, ccarter@philips, cfd f-350, Chall12, charlez, Chris's Dually, ChrisAU, cingram84, cjetcat, CLAC, Clifford0173, co04cobra, codykthekilla, coldhanz, colekym, coltonsommar, compgun, controlled choas, Cory2537, CTC DEEZUL, curb guy, CurlyDE, curt 2006, Custerpsd, custompainter99, Cuttintracks82, cwt, dadoffourgreatkids, dalpilot, Dangyo, Dano244, Dantheman, Darkhorse, dauntejoel, dave jr, Dave-pls, dave0642, daves02, davey99ps, daywalker, DBM, deadduckky, Denny B, DEZERTCHASE, diesel duane, DIESEL POWERED ROCKET, DieselDan73, Dieselfoot, dieselmac, Dirty outlaw, DirtyDave, dirtydieselsixoh, dissentary, dits145, djl95, dlewis355, doc millworm, Donnie1, doofpowerstroke, dturn64, dumptruck09, Duracrap, Eddy, eric walters, evansksa, F-250-Owner, f350plow, FarmRig, Fast_and_Furious, Fever, firefighter472, firemudder, FlossyB, fmrdieseltech, ford rules, ford4x4guy74, fordfanatic, Fordfreak4life, fordguy61mi, fordmanmike, fordpowerf450, FordSuperDuty05, Frank06f350, freddie, FTAJ, FTG-05, FTREE50, fuekear, FX4stroker, gaf350, galiv, gjoski515, Glavin, GO DIESEL, Goose, Griffin, HankyD, harley2envy, Harry Nadz, hawgdoctor, Hillz, hill_billiez, Hobo-Stew, hondo, horsehauler, hp325, huck2080, Hutch, Ian123, iceman89m, id: 5520, IdaGlyde, Idahoser, infantry032003, irish4, isimar, ITAcelica, J HO 22, jammin60, jbwaldrop88, JD F350, jef, jeffdschulz, jefhuf, JerDirte', jeremyshanemoore, jessduen1, JfmF250, jg6.0, jhunter14, JimmyO, Jingoist, Joedarr33, Joedog, jonnysteals, jratoms, JSchuricht, jsm180, Jsmitty0327, kaube01, king dinger, KingRanchSick.0, Kountryboy 6.0, KR69IDI, Krisco, kx450f, kyle43335, LadderDog, lancer, Lilbluewarchief, LILGSX, luv2camp, MADMAN36, majek5, Matt07, mc-integra111, McCrackin, mcdmn717, mdbroady, MDpowerstroke, Mhatlen, Mikeysford, mildot, miller45103, mjcolemn, MobileMiles89, Mooring Product, Morkable, morseranch, MOTO7.3, Motownfire, mrduberry, mrwoody66, MT Pockets, MTdiesel, muddynoll, mwaltersaleen, myronbilliot, nastys6.0, Natos, nelsonar, nickPSD, njchapin, NJStroker, NMPSK, NorCal997.3, nos487, nrook, Nutz, nwilson82, NYC F-350, nytfr8, offroadinginaz, oh-ate6.4PSD, Pat, in Maine, PatJ, patricku47, pc97f350, pccurr, perry, perwin24, pjerrn, pjnadon, Pooterosa, Powerstrokinfirefighter, PowerSub, powr2stroke, Proffitt, PSDPlayer, Rambo, Ranger5.0L, RazorsEDGE, rb12405, Relentless1, ringmaster66, ROADDOG21, Rob D, RocknRoll, romad99, Roush4_6, rswhitcomb, rusty1161, S&W 460 XVR, samlevin90, SaNnDnSurF, scott2001, scottrace1, sga6.0l, Shadow, shadow6.0, Shef, ShiftyCapone, sho669, shrtknif, SickStroke6.0, Sigster, slippydaman, Smoker00, smokie07, smokin04, smokin250, SmokinBlueOval, smoroz, smthstang, snorcr31, soapy, solrac06, sonnyy13n, Specializeddieselnw, spence_08, spruill242, Ssg MAJ, STAX, Sti470, StillStrokin 7.3, Stlyidklr, Stroked95, strokerta, Strokin 35s, Strokin304, superduty6.0, SUPERIOR OFFROAD INC., suprdzlduty, tankersrule, tatertot, Taylor0369, Taylor27, Tazer15, The Butcher, The Gray Mule, TheFinalStroke, thestrokin6.0, Tj561CO, tl1000r, toolmangary, topdwg, tpridgenusmc, truckshop, turbodiesel_02, turboluke, TWJ, TX-4-NRA, uga33, UNCLE DWAYNE, Under Dog, UNRULEE, upsidedown2, warthog, Weatherlite, webb06, West C4, Wheelhop, WhitePowerStroke, whodathought, WHPSExcursiom, Whstln, wildcat922, Willem, woodstar168, yz250rdr, Zane-03 King Ranch, zdot500, zgcain, Zmann, zoega
You may not post new threads
You may not post replies
Forum Jump
