Help with fuel pump shut off switch - PowerStrokeNation : Ford Powerstroke Diesel Forum
Thread Tools Display Modes
  #1
Old 01-13-2011, 02:26 PM
whytry's Avatar
whytry
Offline
Black Stroker
Member's Gallery
I know kinda where it is at but I can't see it. What do I need to remove to rest it?
__________________
Matts tunes
Exhaust
K&N
Nozzles
A1000 fuel system
Old 01-13-2011, 02:47 PM
Barnbuilder
Offline
Member's Gallery
Send a message via AIM to Barnbuilder
Re: Help with fuel pump shut off switch
Think its behind the passenger kick panel. Should be a hole you can stick your finger through.
__________________
1999 F350 CC XLT 4x4 6spd
2006 F350 CC KR 4x4
  #3
Old 01-13-2011, 03:40 PM
whytry's Avatar
whytry
Offline
Black Stroker
Member's Gallery
I toke the glove box out and foun nothing I will try to find that hole.
  #4
Old 01-13-2011, 03:43 PM
tekemp's Avatar
tekemp
Offline
Member's Gallery
it should be somewhere around the passenger side kick panel and it will have a little button on the top of it, just push it in, like resetting a breaker.
  #5
Old 01-13-2011, 03:47 PM
gottagofast's Avatar
gottagofast
Offline
Freak'n know it all
Member's Gallery
mmmmmmmmmmmmm culvers.................
yeah should be behind the hole..... I never actually looked on my truck but that's ferd's way
__________________
99.5 350 crewcab dually 4x4
stage 1 singles, PHP tunes, banks bighead, autometer gauges, F-650 dash mod, 4r100 to ZF-6 SWAP, South Bend OFE-K clutch, Gen 2 wicked wheel,
  #6
Old 01-13-2011, 04:42 PM
whytry's Avatar
whytry
Offline
Black Stroker
Member's Gallery
Yea we do need to go to culvers sometime. And I will go look again in about an hour it is windy and cold right now.
  #7
Old 01-13-2011, 07:40 PM
whytry's Avatar
whytry
Offline
Black Stroker
Member's Gallery
Well it isn't the fuel shut off switch my pump isn't getting power, I don't know what fuse to check all the wires look good.
  #8
Old 01-13-2011, 08:13 PM
Arisley's Avatar
Arisley
Offline
All done now
Member's Gallery
Links in this thread to download an owners manual:
Re: owners manuals - PowerStrokeNation
__________________
  #9
Old 01-14-2011, 01:40 AM
randyo156
Offline
Member's Gallery
i checked mine today, passenger side, foot panel, has hole in it and says fuel pump shot off on it. You can reset it without opening the panel
  #10
Old 01-14-2011, 01:51 PM
whytry's Avatar
whytry
Offline
Black Stroker
Member's Gallery
I found it but now I keep blowing fuses? I don know what causes a fuse to blow other than to many amps going across it.
  #11
Old 01-14-2011, 02:28 PM
Arisley's Avatar
Arisley
Offline
All done now
Member's Gallery
Pump seized up?
  #12
Old 01-14-2011, 04:12 PM
gottagofast
Offline
Freak'n know it all
Member's Gallery
nothing
which fuse is blowing? it's not the fuel heater fuse is it? if so unplug the fuel bowl plug and try again
  #13
Old 01-14-2011, 05:25 PM
BigRed97's Avatar
BigRed97
Offline
The Oracle
Member's Gallery
Send a message via AIM to BigRed97
are you still running the A1000 on the STOCK wiring ?????????????????????
__________________
CCLB with some stuff done .....
  #14
Old 01-14-2011, 05:32 PM
whytry's Avatar
whytry
Offline
Black Stroker
Member's Gallery
Yeah is that what i need to change? and it is fuse number 19 in the engine bay.
  #15
Old 01-14-2011, 05:39 PM
BigRed97's Avatar
BigRed97
Offline
The Oracle
Member's Gallery
yup the stock wiring does not handle a pump that big....pretty sure a few people told you that already....
  #16
Old 01-14-2011, 05:42 PM
whytry's Avatar
whytry
Offline
Black Stroker
Member's Gallery
Yes they did, it has been cold out and i have been busy so i didn't even think about it. Thank you for reminding me i will be changing it this weekend.
  #17
Old 01-15-2011, 03:03 AM
20007.3stroker's Avatar
20007.3stroker
Offline
Member's Gallery
also check the wiring down by the pump, make sure it didnt rub through. i had that happen to me.
__________________
2000 7.3 f-250 4X4 CCSB
Mickey Thompson rims
Cooper Discoverer S/T tires
f350 front springs, add leaf and added overload in rear
Warn manual front hubs
Straight piped
AFE stage 1 kit
more power mods starting as $$ allows
  #18
Old 01-15-2011, 03:13 AM
whytry's Avatar
whytry
Offline
Black Stroker
Member's Gallery
nope didnt changing wiring tomorrow
(View-All Members who have read this thread : 66
02f300, 20007.3stroker, 2000f350v10, 2000XLifted, 6.0 p-stroke, 7.3SuperDuty, akquad1, Arisley, Barnbuilder, Bartlett99, Big Jim 54, BigRed97, Bushwakd, cement porkchop, Chillin, COFG-28, Coltaine, deathwishracer, DieselBrad, double-s-diesel, excavator, F-127, F-350, fdny136, Firewalker76, glovemeister, gottagofast, Greg373, Honeyshucks4, isky1843, Jables92, jcmagone, jefhuf, jvencius, Lazlo, mandkole, mike61, milobie, morefuel, moremph, Mtack, notch86, oldcootonascoot, pdizzleinmt, PHPDiesel, ponypusher58, POWERED SPARKLESS, Powerstrokinit328, quicktimeinc, randyo156, riverjet, rtc0360, Rumsey01-7.3, SBR_GUY, Southern.girl, Tampa450, tdrracing, tekemp, TxFire, UNDER PRESSURE, vader's fury, white7.3, whitjo, whytry, wrenchturner250, wsigo
You may not post new threads
You may not post replies
Forum Jump
