| Register | Members List | Timeslips | Calendar | Sponsors | Becoming a Sponsor | Mark Forums Read | Auto Escrow | Auto Loans | Insurance |
Thread Tools | Display Modes |
#1
Hi, there all, I am needing some help with my first 6.0. Truck has very long crank time and runs like missing until engine gets up over 175 deg. was diag at empty your pocket local shop as having 2 bad injectors and egr cooler bad. Is this possible or should I be looking at something else.
| Sponsored Links | |
Advertisement |
#2
Re: 6.0 runs bad cold but good hot
Alot of people have had good luck with Rev-x additive to help with injetor stiction. REV-X Oil Additive | Diesel Fuel Additive | High Performance Oil If you are using 15w40, you can try using a lighter oil such as rotella t5 10w30 or synthetic 5w40. As far as the EGR cooler, that will have to be deleted or replaced with the bullet proof model. Also, you should rebuild your oil cooler while you are in there. Blocked oil cooler is more than likely the couse of your EGR cooler failure. If you do the work yourself, your pocket will not be as empty.
__________________
'03 F350 6.0 DRW lariat 4x4
Autometer Gauges: Pyro, boost, fuel pressure Scangauge II Bulletproof EGR cooler (blocked off) Coolant filter Delvac EC-1 ELC Exhaust: MBRP 4" cat back with delete pipe SCTx3 Tunes by Innovative and Gearhead Swamps 58v FICM High idle mod SRW front wheel conversion ARP head studs |
#3
A FICM update would be the first place I'd go with an issue like that, along with some Rev-X.
__________________
Ford Master Diesel Certified 6.7 6.4 6.0 certified DPFDeleteKits.com RudysDiesel.com (919) 383-9300 OR Toll-Free # 1-866-757-6537 |
#4
yep, check ficm
engine oil and fuel additives delete egr |
#5
^^^ All good advise up there. Do you know what the codes were?? It will have some codes if it has bad injectors.
__________________
1997 F350 4X4 CCLB PSD 1986 F350 CC Dually 6.9 ATS turbo lowered 1984 Mark VII 2.4 BMW Turbo Diesel 1970 Roadrunner 383 4sp 1970 Cuda 426 4sp Dana 60 1956 F100 Then the wife has a car It's all just nuts and bolts and a few wires. ex·pe·ri·ence [ik-speer-ee-uhns] noun, verb, What you get when you don't get what you want |
#6
Not always. I've seen plenty of trucks run rough due to injector issues and not throw injector codes, however, sometimes a code does pop up when a concern in present.
#7
I had a 450 flatbed with 168k same symptoms. I changed the oil to rotella T6 with motorcraft filters (helped some), had the FICM reflashed (helped more), and then added some REV-X (Runs GREAT!!!)
#8
5w40 moblie1 with 2 bottles of Rev-x is were i would start, the FICM is the next thing to check, as for the oil and egr coolers they are sources of problems on these engines but i dont think that is what your problem is
#9
2 bottles of rev-x will take care of that just fine.
__________________
Built With Blood!! |
#10
I run valvoline premium blue 5w-40 synthetic. The 6.0 injectors really seem to like it. I would check the FICM voltage, either with a computer or with a voltmeter, anything under 46 and its crap. Just upgraded my FICM to a 58v model. Haven't tried any Rev-X but if they were willing to let me test a few bottles for them Tim
, i would try it. Also another way to see if your cooler is blown is to park your truck on an incline nose down and pull the EGR valve and check for wetness.
__________________
06 F250 Lariat CC SB FX4 6.0, EGR Delete by FCDP , 58v FICM by Quick Tricks, Autometer Gauges (Boost, Pyrometer, Trans. Temp), SCT X3 W/ IDT, 4" TB Straight Pipe, S&B CAI, ZOODAD, Retro-Solutions HID Kit (4300k), CCV Mod, Coolant Filter |
| Thread Tools | |
| Display Modes | |
