Dragging brakes - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Other Diesel Topics > MPG - Fuel Economy Discussion
Register Members List Timeslips Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 01-11-2011, 08:50 PM
Highbeam
Offline
Member's Gallery
Dragging brakes
A few weeks ago I noticed that one brake was dragging on the front of my pickup. Enough to make it difficult to turn the wheel but not enough to generate heat at the wheel after driving. Obviously a mpg thief.
I have new balljoints and bearings so they are fine. I have recently, like 6 months ago changed the pads on this daily driven truck. I don't believe in turning rotors, brakes work great.
So first thing I did was pull the wheel and then caliper. My slide pins were totally free and and the pads were evenly, slightly, worn. Not wedge shaped like a sticky pin would cause.I did not look for swollen pad edges but the caliper was difficult to remove from the rotor. Seeing no apparent issues I suspected a sticky caliper piston so I compressed the pads into their bores and put everything back together. Everything spun nicely so I forgot about it.
I had my tires replaced last night and while it was lifted I tried to spin that wheel and it was stuck again. I read on this site about the swollen pad edges. Never heard of that but I am willing to take a look again plus relube the slide pins with my big jar of fancy official caliper slide pin grease.
What am I looking for? Is the center not swollen but the edges are swollen? Is the pad puckered? Why doesn't this push the piston back in just like the rest of the pad? My pads were regular parts store cheapies.
Any other ideas? The pistons retracted with normal pressure from C-clamp, I've not bled these brakes yet.
__________________
2000 F350 SRW, 4wd, CCSB, PSD
Lowered rear end to F250 height, 4" exhaust w/ muff, foil delete, AIH delete, Ford AIS intake, tru-cool trans cooler, autometer under dash pod and gauges, Mile Marker hubs, 04 headlights, soft tonneau
18' 10k rated PJ car hauler
26' 7500# Creekside RV Trailer
Kioti CK30 tractor
Old 01-11-2011, 11:38 PM
SD26's Avatar
SD26
Offline
Member's Gallery
Re: Dragging brakes
Well, for racing, that could cause a sticky caliper...
If there's some debris in the fluid, then it's all pushed back up the line and through various passages, that debris might cause the piston not to retract. Sometimes, when pushing the pistons in, we'd open up the bleed valve to force that fluid out of the system rather than causing a problem.
I'd go for the bleed.
__________________
Dave
2005 E350 6.0PSD
2003 Excursion Limited 4WD 7.3PSD - Sold
1996 E350SD dually 7.3PSD - Gone!
1998 VW Jetta TDI - stock
1999 Kaw KLR650 - 17/42 gearing
  #3
Old 01-13-2011, 03:41 PM
Highbeam
Offline
Member's Gallery
Re: Dragging brakes
I'll be replacing the caliper, it's not worth the chance of failure and the cause for failure is surely some sort of corrosion on the piston or piston bore. I don't see how bleeding the system could free up a sticky piston. At the same time, the system will get a complete flush because I do believe that the old watery fluid contributed to the sticky caliper in the first place.
Apparently the whole swollen pad edge thing is a myth but I'll inspect the pads for any odd pattern. I'll just be moving the old pads to the new caliper.
  #4
Old 01-14-2011, 12:29 AM
Dave Whitmer's Avatar
Dave Whitmer
Offline
MPG Moderator
Member's Gallery
Re: Dragging brakes
If you can get the pads off, get a die grinder and grind a eighth-inch by 45 chamfer around the edges and the problem will go away.
It is best to chamfer the pads before you first install them.
__________________
2000 F-350 SC 4x2 6 speed
Slammed 4"
A.R.E. Hard Tonneau and Rugged Air Dam
MPG Pending
  #5
Old 01-14-2011, 10:38 PM
CamTom12's Avatar
CamTom12
Offline
Member's Gallery
Re: Dragging brakes
Yup, I chamfer the pads on every brake job I do.
Keeps brake squeal down, too
__________________
2008 F250 CCSB FX4
DPF/DOC Delete, Spartan, Banks (previous owner installed crap) Intake and Cat-back, OUO Traction Bars, 40gal TFI Tank/Toolbox, EDE Studs, HG's, and EGR Delete w/ wastegate
1969 F250 RCLB Highboy
360/4-speed
  #6
Old 01-15-2011, 11:35 PM
Highbeam
Offline
Member's Gallery
Re: Dragging brakes
Okay, so I flushed the whole system with 2.5 quarts of fluid. Then removed and lubed every single caliper slide pin with actual offcial slide pin lube, replaced the sticky caliper, and all the front pads were removed and chamfered on the bench grinder. I can't see how it will help anything but it can't hurt.
The front wheels both spin freely now and I have a tiny bit of travel before I get a hard brake pedal which should correspond with the pads retracting properly. At first I thought I misbled but it is a firm pedal.
I have the OEM limited slip rear end. When I had the rear end up in the air I had a very hard time rotating the wheels. The rear brakes were not dragging but I did not inspect the parking brake. Is the limited slip that good? I know it isn't worth a darn when trying to get traction.
(View-All Members who have read this thread : 107
01str88, 02POWERSTROKE7.3, 06strokin, 20007.3stroker, 250turbo, 6.0_psd, 70torinocobra, 91turbogsx, 95gasser, 96'BigBlue, abbottfarms, acasey7.3, apollyon9515, baggedbug, bazdog1, bboteler, bcangelo, Beekford, biggreen96, BigRed97, blujay96, bulletproof7.3, C&A fish, CamTom12, catch22, cedarcove smoker, coldhanz, Coltaine, cowboy_dan, Cutty72, Darkhollow, Dave Whitmer, Diesel Mack, diesel veins, diesel_707, Dirtyboy82, double-s-diesel, dspowerstroke, e.hoffrogge, eleventhtruck, Ewilly, F250 Fever, f350jim, Flatlander, ford7.3sd, fordfan30, gnxtc2, gottagofast, HeadHunter, Highbeam, hillbilly123, ibleeddiesel, isimar, jesserrr99, jjreagan, joediesle, joedown, JonFord, JSchuricht, Kentuckydiesel, Khemosabe, kpasichnyk, MADMAN36, mandkole, Matt-F350, Mudbrother, MustangMatt96GT, Myles_S, NickBud, NoahA, oldbluef250, orrwhat, Ouch, P-nut, papamac, Patrolman, POWERED SPARKLESS, prostreet67, pstroke96, RazorbackF350x2, rmkking6, Rockyardjo, rusty1161, Scram, SD08, SD26, Seth Wilson, Sinisalo425, smokin_fast, SnuffCityBoy88, srmurphy, tensixniner, The Don, thinmint, tholt34, Tinstar36, tisbister, tjl, toolmangary, topshelf7.3l, Toreador250, tpull3, TruckeePSD, vanislejimmy, wicked027.3, wild67, winkfab
You may not post new threads
You may not post replies
Forum Jump
