Starter solenoid wiring diagram? - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > F-250 & F-350 1986-1997 & Other Ford Trucks > 1994-1997 Power Stroke Technical Info
Register Members List Timeslips Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 12-27-2010, 09:58 PM
AMMO STROKER
Offline
Member's Gallery
I searched for this and found alink that no longer works. Anyone got something?
Reply With Quote Quick reply to this message Go to the top
Old 12-27-2010, 10:07 PM
countryboyrob
Offline
Member's Gallery
Re: Starter solenoid wiring diagram?
What are you trying to figure out?
__________________
02 f250
  #3
Old 12-27-2010, 10:31 PM
AMMO STROKER
Offline
Member's Gallery
I don't the previous owner had this wired right. Just wanted to know if someone had a pic
  #4
Old 12-28-2010, 12:24 AM
timfinnegan
Offline
Member's Gallery
To dark to take a picture so Ill describe the best I can.
When you stand next to the passenger fender and look down on the solenoid the large left post 1 red wire that goes to the starter should be a 10 gauge. on the right post everything else, power to the glow plugs, amps, etc. There should only be two left and they are the push on posts, the one with two wires is on the bottom and single on top.
  #5
Old 08-02-2013, 02:05 AM
needen$77
Offline
Member's Gallery
what if you wire this wrong and it run. will it burn something up
If you do not want to register, fill this field only and the name will be used as user name for your post.
Human Verification
(View-All Members who have read this thread : 56
1TonStroker, 444-4D, 95smoker, AMMO STROKER, biggreen96, Blowby, buckmsj, Buddy B, Bugman, cowboy_dan, CRASHJT, cyko47, dblake, Dieslnevan2009, dogmaticus, dzlj 50, eleventhtruck, EverettWV, fordfanatic, foxman, Francesco, GASMAN6674, halbig7, Hijo202, IBESTROKEN, Jcam88, Kampy, kb2red, klos, lep, m j, madpogue, Mike97f350, moesmokebbq, mojoman, Mr.Powerstroke, mtblanca, nashvillebill, needen$77, neverkickn, ngtstk3r, nujef12, obs'r, old man dave, rdstroke, salprofish, smerleau, steve phillips, timfinnegan, toolmangary, tubes92, WhiteStroke13, WidowMaker, ZIPPY
Forum Jump
