2003 Super Duty rear end vibration - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Other Diesel Topics > Suspension and Drivetrain
Thread Tools Display Modes
  #1
Old 12-26-2010, 12:07 AM
RedHorseFarm
Offline
Member's Gallery
Question 2003 Super Duty rear end vibration
2003 f250 Super Duty has a bad vibration in the rear end at highway speeds (60 plus). We thought it was the new tires we had put on... but we are on a third set of tires now and still no change. The weird part is that the truck will shake bad for a few minutes and then smooth out for thirty seconds or so. It tends to smooth out around a bend on the highway. We thought maybe it had a bent rim, but if that was the case it wouldn't smooth out at all.?.? Any ideas on whats going on before we take it to the Ford stealership?
Old 12-26-2010, 12:24 AM
semomotorsports
Offline
Member's Gallery
Re: 2003 Super Duty rear end vibration
jack it up and check the ujoints and carrier. I bought a truck once from the local car auction that others didnt want because of a bad rear end. I drove it home vibrating and all. Jacked it up and found a bad ujoint. Problem sovled for me.
__________________
2011 6.7 F350 CCSB BLUE SWEET RIDE
1996 F350 BABY SWAMPS AND TS, FLAT DOWNPIPE
  #3
Old 12-26-2010, 02:38 AM
RedHorseFarm
Offline
Member's Gallery
Could it be a u-joint even if there's no clanking noise?
  #4
Old 12-26-2010, 03:46 PM
semomotorsports
Offline
Member's Gallery
yes all I had was a vibration, no noise. You cant tell if a ujoint is bad useally unless all the load is off the driveshaft so you have to jack it up.
  #5
Old 12-26-2010, 04:05 PM
scott2001's Avatar
scott2001
Offline
Member's Gallery
whle you under there go ahead and check all the joints, do the wheel trick.
__________________
2008 got a new flex pipe installed. S-b intake, 4in dp back exhaust, gear head tunes
1999 chevy malibu with 183,000 miles on the clock sold
2013 dodge charger
  #6
Old 12-27-2010, 02:24 AM
DEMON's Avatar
DEMON
Offline
Member's Gallery
a seized ujoint will do that. you have to drop the shaft to check for a seized joint though. there won't be any play. but seized caps will give you a weird vibration.
__________________
Luke
'06 Ford F450 CC DRW Lariate 24" Alcoas & Toyos
'98 Freightliner FLB C12 13spd 244"
'73 Chevy RS/Z-28
Originally Posted by swamp_ratt View Post
yeah its similar to that one but unfortunately not nearly as long or as cool
  #7
Old 01-02-2011, 01:33 AM
IL7.3 Powerstroker's Avatar
IL7.3 Powerstroker
Offline
Member's Gallery
Send a message via Yahoo to IL7.3 Powerstroker
center carrier bearing is probably shot
easy replace and reinstall new unit
__________________
2002 F-350 Supercab longbed
AFE intake Bully Dog 5" exhaust
Swamps sticks, DP tuned
  #8
Old 01-04-2011, 11:44 PM
RedHorseFarm
Offline
Member's Gallery
Would either of the above cause a vibration on just the one side?
  #9
Old 01-05-2011, 12:46 AM
DEMON's Avatar
DEMON
Offline
Member's Gallery
no it wouldn't.
  #10
Old 01-05-2011, 11:55 AM
OuchThatHurt's Avatar
OuchThatHurt
Offline
Aint Got Non
Member's Gallery
I asked a similar question for my truck the other day and this answer makes more sense. Mine vibrates (like a humming) at 60+ mph, but my jitters while taking off. The harder i mash it the harder and more fierce the jitter.
How can you tell if the center ujoint is bad? Mine seems a little loose without the truck being jacked up. Is that normal.
__________________
Donnie... 06 F350 Harley leveled ang exhaust. Does the job!
USCG "Sea life is the only life"
(View-All Members who have read this thread : 187
'01STROKER250, 007 JKX, 01powerstrokin, 02POWERSTROKE7.3, 03_PSD, 04king_stroker, 04La4iat, 1badz, 1sd, 2004Stroker6.0, 603powerstroke60, 6litrestroker, 7.3bogger, 7.3PWRSTR0KE, 79schaefer, 94strokeher, 98stratusryder, 99f-250, Aaron S, ab2625, Abek250, ackdog, AGV2006PSD, almostfinished, Anyonebutme, Backwoods Electric, badblack01gt, badluck_early99, Baker82, bazdog1, BBowden73, BCS, becareless06, Betaracer, big deal, big nasty, BigJake, bigton, Blackford, Blown284, boostintalon, brandon100887, bryan.d, bs3040, bscooter99, Burnin Coal, chopper, chunkdunker, cornfeddiesel, Dangyo, Dantheman, dbarnett42, dbart, dblaked, DEMON, dent-techs, Derek2001, desertwheeler, Dieselpop, diesel_84, Dirty outlaw, dlnw98, doublej112, douglasharwood, dukedrummer89, Dustin F2504x4, Dusty Roads, eib, Evil Diesel, F-250-Owner, Farmall66, farmall99, fastgnat, firemudder, flipper66, FloridaStroker, Forced382, ford4life76, FORDBLUE35, forddieselkicksass, fordman060, Frogman2, glovemeister, granite state destroyer, HeadHunter, hillbilly, honda313, hoss-06, hwhizbang, iaff284, ibestrokin97, IL7.3 Powerstroker, intense134, irontx25, j350_05, jclpowerstroke, Jeff Severe, jeremyleggett07, jipi99, jminardi, joe69ss, jpaitala, juniort444e, Krisco, kurttyson, leoneo01, lifted 250, LORDDiESEL, mainedieselbill, markgyver, Matt_P, Mbarrett, mbcdave, metalnova, milehighstroker, miller45103, MissyGean, Mooring Product, Motomez, mryanc, mustangmike, mx185sw, mytmousef350, NEVRNF, nhill2090, nicktb, NorCal997.3, Nutz, obs'r, Ohnny101, oldbluef250, OuchThatHurt, Pdt1081, PowerSub, powr2stroke, pr15, psduser1, RazorbackF350x2, RedHorseFarm, rickvm, rmkking6, rmoz, roughneck0913, rusty1161, SaNnDnSurF, scheidt27, Sciulli, scott2001, semomotorsports, seymore smoke, sgleshot, shadow6.0, Shep, Silverps, skipmitchell, slee22, sm23, smorris, Sparkymichigan, ssanders, Suber 7.3, superduty, suprhlr, swimage, t.land, TARM, tbolt, tensixniner, thecabinetguy, TommyT, TRX370r, tubular031, twelch3, TWIM, twodogs, VaTechPSD, WadeK, wayneswift, wcpresley, Wojo, workstroke, Wreckedwolf, xxxbrutusxxx, yamtodd, Zane-03 King Ranch, znunez72
You may not post new threads
You may not post replies
Forum Jump
