P1670 - PowerStrokeNation : Ford Powerstroke Diesel Forum
Register Members List Timeslips Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 12-16-2010, 02:21 AM
'99 stroker's Avatar
'99 stroker
Offline
<--501cc,should b 540 : /
Member's Gallery
P1670
My truck wouldn't start earlier, it was cranking like mad as it had been running 15min before, however it didnt fuel,so I poped the hood did a quick check, all looked good. I pulled codes at home and go a P1670 Which was something about a sensor not sending a signal or something generic. However it didn't mention which one, how do I figure out what sensor is giving me trouble?
__________________
Early '99 ccsb 7.3l 4x4 6spd
All Stock Except
Air tank rear bumper
Brush guard w/ fog and driving lights
seat covers
after market floor mats
Fancy Halogen headlight bulbs
Rear license plate light is out
Originally Posted by erikclaw View Post
Those hairy bastards are scary up close!
with all the smoke, power and wheelie popping you might accidently park on a honda
Old 12-16-2010, 02:28 AM
Super_Hauler's Avatar
Super_Hauler
Offline
Super Hauler!
Member's Gallery
Re: P1670
P1670 EF Feedback Signal Not Detected
__________________
MINE:08 F-250 CCSB king ranch erics tunes livewire
99: sclb 6 speed, 4" lift,4" exhaust, EB
99 F-450: ccfb Boss v plow. 6 speed 5" ex,EB
HERS:2001 F-350 ccsb notta stock!
  #3
Old 12-16-2010, 02:37 AM
PSDEng's Avatar
PSDEng
Offline
Busted Knuckles
Member's Gallery
Re: P1670
DTC P1668 and P1670 indicates that a communication error has occurred between the PCM and the IDM.
Possible causes:
Open fuse, IDM relay, Open or shorted IDM enable circuit, IDM powering circuit, PCM
Check for other codes. Key on, engine off.
l Perform KOEO On-Demand Self Test and retrieve Continuous DTCs.
If DTC P1298 is also present, REPLACE the IDM.
__________________
'97 Powerstroke SCLB: http://www.carsonstaufferdiesel.com
http://www.beansdieselperformance.com
i have a couple friends that went balls deep in wyotech and when they got out they couldn't poor piss out of a boot if you put the directions on the sole
  #4
Old 12-16-2010, 03:34 AM
'99 stroker
Offline
Member's Gallery
Re: P1670
Possible causes:
Thanks guys!
I did the IDM mod a few months back, I wonder if this is related. This must be why it wasn't getting fuel and starting earlier. After a minute or so it worked for the hr or so it took to get me home, so maybe a sporadicly loose connection?
  #5
Old 12-16-2010, 04:40 AM
SouthFlstrokin''s Avatar
SouthFlstrokin'
Offline
Member's Gallery
Re: P1670
I just had the same issue, check your batts, batt connections, idm connections. My issue was i had 1 dead battery, i was throwing codes p1668 and p1670. Since i changed my batts i haven't gotten those codes. Good luck
__________________
Early 99 7.3 2wd
Old truck with all the bells and whistles....
Originally Posted by Thuglike View Post
Anyone who stands to pee drives a 7.3.
(View-All Members who have read this thread : 57
'99 stroker, 4wydnr, 7.3FisherFord, 700,000 powerstroke, 907superduty, aklim, bknight187, Blowby, Blown95svt, bsosnoski, CALADASH, chris584, Dsycutter, ElkBowHuntR, ESR62, fastedy, fatfender, FCR10, fordman2121, Gibrid4x4, Highstyles_john, isky1843, Jeepermc, JerseyJim, Jonathanrayce, jth4570, Luke909, machete31, Marty, Mekanik, middlemanjw, Millerfarms, mprobst, Mtack, Mx_racer_36, nielsencc86, nine54, okiebindernut, PDEMICH, Powerstroke Man 6.4, PSDEng, RMPowerstroke, simpleman, Sinisalo425, smokeyoak, SouthFlstrokin', sparks427, Specializeddieselnw, Stringer Driver, stroker2, Super_Hauler, tgf, thecabinetguy, thobui, weals, wicked_four_play, wrongway
You may not post new threads
You may not post replies
Forum Jump
