6.0 to 7.3 Conversion - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Other Diesel Topics > Engine & Transmission Conversion
Thread Tools Display Modes
  #1
Old 12-16-2010, 12:41 AM
Belairboy55
Offline
Member's Gallery
I have a 2003 F-250 with an auto trans and a sick 6.0. I also have a 2000 7.3 with an auto trans that is wrecked with 114,000 miles on it. I want to put the 7.3 out of the 2000 into the 2003 with the 6.0. Has any body ever done this? Can you give me some direction?
Old 12-20-2010, 09:17 PM
85yota350
Offline
Member's Gallery
Re: 6.0 to 7.3 Conversion
oh i'm sure its been done......just use all the wiring from 7.3 truck.
__________________
2008 F350 Lariat 6speed!
  #3
Old 12-30-2010, 05:23 AM
Countryboy07's Avatar
Countryboy07
Offline
WINNING
Member's Gallery
You'd be better off swapping in a cummins..... The 7.3L uses an entirely different harness and you'll have a lot of fun trying to graft the two together. Just my $.02
-French
__________________
1997 Ford F-350 CCLB 4x4 - Cummins Conversion Project
1994 Ram 2500 RCLB 4x4 - Donor Truck (Built Auto, 4K's, 6" stack)
2002 VW Jetta TDI - Will be for sale soon!
  #4
Old 12-30-2010, 05:58 AM
stroked99_1/2's Avatar
stroked99_1/2
Offline
Member's Gallery
It would be a pain... Unless you have all the wiring harness's from the 7.3, be plug and play then, swap it all over, piece of cake and go.
__________________
Renegade Diesel
  #5
Old 02-18-2011, 05:06 AM
Dieselfever's Avatar
Dieselfever
Offline
2010 BOB Points Runner up
Member's Gallery
Send a message via AIM to Dieselfever Send a message via Yahoo to Dieselfever Send a message via Skype™ to Dieselfever
I've got a guy wanting me to do a similar conversion. He has his '99 7.3L 6 speed that he totaled(That I just built an engine for with headstuds, swamps injectors, new clutch, etc) and wants to use the engine and transmission in an '03 6.0 auto truck he just bought.
Anyone have experience with this? Hope going to the 'dumb' transmission will make things go a little smoother but I know that the center 'hump' in the cab is different from an auto to a 6 speed.
-Michael
__________________
Michael
1997 F350: Regular cab XLT, 7.3L PSD, 5 speed, 4x4, 3.55 - Some Stuff
2000 F350: Crew Cab, Lariat, 7.3L PSD, 6 speed, 4x4, 3.73 - More Stuff
2001 VW Golf: 4 door, GLS, 1.9L TDi, 5 speed - Darn near makes fuel!
  #6
Old 02-19-2011, 12:47 PM
mwalsh9152's Avatar
mwalsh9152
Offline
BigRed97 is Dumb
Member's Gallery
As long as you have the complete donor it will be plug and play. On my Bronco I had to swap out the dash and engine harness along with both fuse box's, but the existing chassis harness and most of the interior plugs worked. Going from one diesel to the next you will probably have a lot less to swap than I did. Dash harness will likely be the same, you may just need to swap the engine harness, which is pretty simple.
As for the dumb transmission, I remember seeing one conversion where the guy cut the transmission hump out of the donor and grafted it into his truck.
__________________
1995 7.3 Bronco
  #7
Old 02-21-2011, 07:42 PM
GOSSteel's Avatar
GOSSteel
Offline
FUMMINS SPECIALISTS
Member's Gallery
The 03 is a split year for the 6.0 and 7.3, so everything will be fairly simple. Ford to Ford is still easier than Dodge to Ford, although we specialize in Fummins!
__________________
2006 F350 CR with Twins- 731 Ponies
2009 Polaris Turbo'd 800 Dragon 163- Winter Toy
Check out our website here
GOS Performance Facebook
  #8
Old 05-27-2011, 06:08 PM
truckpullin_75's Avatar
truckpullin_75
Offline
Member's Gallery
Looking to do the same thing with mine. Have a fully built 7.3 in a rolled truck, engine wasn't hurt and neither was I thank god. Looking at buying a like-bodied 03 or 04 king ranch or harley edition and swapping out the 6.0 and 5r100 for a 7.3 and bts 4r100. Kept the truck so I still have all the wiring harness, cluster, etc. Even if I end up buying another 7.3 the engine is going to come out for the built one so the labor part of it shouldn't be much more intensive....I hope. Exactly what all would have to be swapped over??
  #9
Old 05-27-2011, 06:56 PM
Cat_Rebel's Avatar
Cat_Rebel
Offline
OBS junkie
Member's Gallery
We're doing a 99 V10 gasser to 00 7.3L swap, we'll find out how everything works soon.
__________________
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
  #10
Old 05-28-2011, 03:33 AM
Alberta 7.3's Avatar
Alberta 7.3
Offline
Modded by a Chevy Express
Member's Gallery
In '02 they changed the instrument cluster, and the power distribution was all moved to one fuse panel under the dash. The 2000 harnesses/power distribution will be completely different from the '03. The 02 and later cluster needs an 02 and later 7.3 PCM/related wiring for the WTS/WIF lights to operate correctly. You'll be able to swap in the 7.3 but probably need a 02-03 7.3 engine harness and PCM to avoid having to rewire the entire truck.
__________________
Just a few 7.3's with a bunch of the usual bolt-on crap
(View-All Members who have read this thread : 258
!!!PainTrain!!!, 03_PSD, 04popo700, 05powerstroke38/24s, 0660perk, 16yrenthusiest, 1995f350, 1995stroker, 2004Stroker6.0, 2006powerleaker, 24Vford, 4wydnr, 6.0 six speed, 7.3PWRSTR0KE, 85yota350, 87jumpy, 89xj, 93 idi 2WD, 94idi, 96Powerstrokin, 96strokeme, 97_f250_7.3L, 997.3PSD, 99oilburner, 99STROKINSMOKIN, a5t1, abbottfarms, acasey7.3, Alberta 7.3, alwil, AMB, apollyon9515, Arctic Fox, as6.4stroke, AzPsd55, Baby_Phil, Bair, bassanglerbob, bazdog1, bboteler, BCS, Belairboy55, BFD99, BGIII, Big Papa 03 dually, Big Red 350, bigbadford01, bigern515, biggreen96, BIGSKI15, Bill R, Blue06crew, blueoval95, bluovldeezl, BlwnDezel, Bobus, boosted93cobra, bpb424, brandonorban, Bryrylan, Chad Edwards, chadow427, Chillin, cincinnatijeeper, colbev57, collins590, Countryboy07, cummins250, Cutting-Edge Diesel, cyberdiamond, DBM, ddillenger, DeereMan83, dego_red, Denver, Diesel Jay, Diesel Mack, Dieselfever, dits145, Doktor Rocket, dorton14, double-s-diesel, dukedrummer89, dumptruck09, Eddief250, Erle385, everclear4520, evol302, F-127, F-250-Owner, farmall99, fastlx, Fasttimez, florida 6.0, forcefed6.4ford, frogcookietater1, FuturePharmD, FX4 F2-Fifty, geared_low550, ghostrw, Goldknight, Goose, GOSSteel, Grenade, greyf350, GTPaul, halo, harley-kid, heinera, Highbeam, hiphopper, Hogan1369, huck65, hypersnyper694788, ibestrokin97, iceskatinuphill1, IGoneGreen, IHPowerstroke7.3, Jake N, jammin60, JD F350, jdc753, jeff7825, JerseyJim, jess, jkidd_39, Jngreen, John mckenzie, joshdc, Joshs4x4toyz, jpxj94, JRF, JRod, kaso76, KCDAXFACTOR, kempe's repair, KPSquared, KR69IDI, KVD7360, lasgambler, Layson, Lmgrcivic, lowbedriver, lrazer, LttleGreenRam, MARKIS, MATREDGT, mattfolkman, metalnova, middlemanjw, mike b, MobileMiles89, Monotalonawd, monster-energy-825, Motownfire, Mr. Bob, Mtack, Muledude, Muzz, mwalsh9152, my79f, namerritt, nastystroke04, ncovey, NDstroker, NEVRNF, Newman, NH OIL BURNER, not enoughsmoke, no_pistons7, np205, NutFarmer97, nyvp, oldbluef250, opieg01, orrwhat, OuchThatHurt, OUTLAW101, panther777, pat@osp, patrickke, PJB, Plumbnman, PowerPerformanceChainsaw, powerstroke095, Powerstroke_Kid, psd444, pullinstroker97, RA3PSD, RC4WD, Red assassin, RedBull_04, rich, Rmartin-97, Rocketnut, roo1113, RSP, Rumsey01-7.3, RW'sSTROKER, ryerle51, sandfarmer, SaNnDnSurF, sargepep56, sasquatch24, sbrofford, Sciulli, screagle07, screamin6.0, sdthoren, semmens21, Seven-Point-Three, sgoochds650, shocka04, Shockley6.0, silverf250, slee22, Smokin444, Smokin6-0, smorris, snoblade82, sparks427, splitshot, steve phillips, stickboyracing, Stites02psd, str00ker, stroke of luck, Stroke00, stroked99_1/2, StrokerSmoker01, super73, suprhlr, tank23, Taylor22, theGreenHornet, thorin, Toreador250, Towinearly99, truckpullin_75, tughill283, turbom700, Twisted Addiction, txpsd, Tycof250, tylan, tyroan70, u2slow, waltenbach, Wff250, wildjon, wint, wjamesm, XHRcustoms, ZaneD, Zebrastripe
You may not post new threads
You may not post replies
Forum Jump
