theft light/PATS Programming - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > Power Stroke Excursions
Thread Tools Display Modes
  #1
Old 12-11-2010, 11:58 PM
The Oiler's Avatar
The Oiler
Offline
Oil anyone?
Member's Gallery
Hi all, just bought an 01' ex with a 7.3. Completely stock with 157k on the odometer. Sometimes when i go to start it it will just crank and the theft light will flash really fast. I will shut it off and wait a second then try again and it will start. Is this something i can fix or do i need to take it to the stealership and let them take a look at it.
Thanks.
Nathan.
__________________
Pull truck:
96' F-250 ex-cab
Swamps oil and fuel
T-bars,airbags, 5in stacks
getting back on the road soon.
Now have a s366 from Swamps now.
01' xlt excursion with a 7.3
all stock for now and gets 18mpg
Old 12-11-2010, 11:59 PM
CDP's Avatar
CDP
Offline
^^ Not Cobbs
Member's Gallery
Send a message via Skype™ to CDP
Re: theft light
It is the PATS system the only way around this is to unplug it or reprogram it. it involes turning the ignition a few times I cant find the link to it maybe someone else will chime in
  #3
Old 12-12-2010, 12:02 AM
The Oiler's Avatar
The Oiler
Offline
Oil anyone?
Member's Gallery
Re: theft light
No tuner unless it was flashed before i got it. What is the PATS system?
  #4
Old 12-12-2010, 12:05 AM
OldschoolPSD's Avatar
OldschoolPSD
Offline
all ur OBS r belong to me
Member's Gallery
Send a message via MSN to OldschoolPSD
Re: theft light
Its the factory Passive Anti-Theft System... pretty much a joke as far as anti-theft stuff goes. I'm not sure how to turn it off but anyone in the business of stealing super duty's can get around it easily so it's not really worth keeping.
__________________
Ford stopped building trucks in 1997
Beck's Welding and Fabrication, Inc.
  #5
Old 12-12-2010, 03:19 AM
The Oiler's Avatar
The Oiler
Offline
Oil anyone?
Member's Gallery
Re: theft light
Anyone know where this thing is located so i can make it a weee part into the trash can?
  #6
Old 12-12-2010, 03:25 AM
96 stroker's Avatar
96 stroker
Offline
Old But Sexy
Member's Gallery
Re: theft light
no but turn the key on for 45 sec or soo until it slows down..than turn key back than turn if forward and wts light to go out and start it
__________________
96 F-350 CCLB ,auto with a couple 6 inch black aussie stacks, A Dp-tuner and AD injectors 66mm turbo and BD t.c...
Dads-01 7.3 4x4 Excursion..stock as could be
  #7
Old 12-12-2010, 08:03 AM
TARM's Avatar
TARM
Offline
Member's Gallery
Re: theft light
When you have a stock X ( meaning no Chip) If your theft light blinks fast your PATs system and PCM ( vehicle's computer) are no longer in sync/ not recognizing each other. You will need to reset the PATS system.
* THEFT LIGHT (on Excursions) - If the theft light flashes rapidly and the vehicle won't start, the Passive Anti-theft system (PATS) will need to be reset. To reset the PATS, perform the following steps:
  • Turn the key on, but do not attempt to start the vehicle.
  • Wait for the theft light to quit flashing rapidly. This should take about 45 seconds, after which the THEFT light will flash multiple times about every 3 seconds.
  • Turn the key off and remove the key from the ignition for 30 seconds.
  • Insert the key and turn the ignition to the ON position.
  • The THEFT light should illuminate for about 5 seconds and then go out.
  • PATS System should now be reset
  • You should be able to start your vehicle normally
try the above and you should be squared away.
For those with chips it can be normal for the theft light to flash AFTER starting for a few mins but should cut off after that while driving. It should never cause a no start issue. If the later does happen follow the above instructions to see if that fixes it first.
Hope this helps
  #8
Old 12-12-2010, 01:25 PM
Arisley's Avatar
Arisley
Offline
All done now
Member's Gallery
Re: theft light
I know a tuner that can disable PATS.
__________________
  #9
Old 12-12-2010, 04:03 PM
The Oiler's Avatar
The Oiler
Offline
Oil anyone?
Member's Gallery
Re: theft light
Ok, thanks for the info guys. What tuner will diable this pats system?
  #10
Old 12-13-2010, 03:19 AM
TARM's Avatar
TARM
Offline
Member's Gallery
Re: theft light
No real need to disable pats unless you are having some type of issue. Where PATS disabling started to be used IIRC is when tuners tunes some how conflicted with PATS and created a no start issue. I think most of that could have been addressed with this simple reset. Other than that I do not see a flashing light for a min at start up a big deal.
I think there likely is a way you can just unplug the PATS module somehow. I need to look at a diagram when I get a chance and see
We need to get some stickies up on this sight with the various HOW TO things that so many peoepl get stuck with:
How to find your door unlock code for the push button pad and how to program it to a new number. ( $100 @ dealer)
How to reset PATs ( $100 @ dealer)
How to reset you Environmental climate control ( for those with the digital panels) when it goes completely dead. (Up to $1500)
How to program your seat belt warning bell ( PITA to listen to)
How to program new microchip keys to your vehicle ( $75 per key plus $100)
I am sure countless others.
(View-All Members who have read this thread : 273
00EXCURSION7.3, 00X7.3PSD, 02EXCURSION, 03ex, 04psdexcursion, 07plower, 1950gmcelc, 1baddually, 1BAMF, 2000unlimited, 2000XLifted, 2006.1f250, 2dedge, 6.9turbocharged, 60POWERSTROKE73, 7.3 X, 7.3EX, 88 gtu, 96 stroker, 97F-SD, 99-350, ABQDIESEL, ACFarmer, ajennings, AK1, aklim, Alberta 7.3, AngryLepercon, Anyonebutme, AR Aggie, Arisley, ayrn, AZCrazian, baller9409, Balthasar, Barnbuilder, bassanglerbob, BB540C2, bbmxandfmx, Big K, BigBearDoinThangs, BigDeal21, BigMike, bigo, blackstrokeracing, blaze42069, bondsman, bracketracer, brandon_7, Breacher, Brew_WY, BWillard, CALADASH, Capricious, catsnw, CDP, CFoster, chelada, chevelless414, Chicagostroker, chopperboy, Chris6.0, Chuck B, Chuck B., chuckels, CLAC, co04cobra, Coachscott, codykthekilla, copracr, Cory_S, CrewCab95, CSIPSD, CTShoaf, d-selpowereddiebauer, dbunyip, dcshoes686, ddillenger, DieselG, Dieselpop, dieseltrail, DieselX, dixieland-diesels, Dogdare, Dorito, double-s-diesel, DP-Tuner, DRT1359, drunk on diesel, dzlsmok, ExcursionConversion, ExToy, farmerguy, fatfender, fearthat2001, fordboy424, fordman2121, Fordpowered, fordtuff08, Fro_911, Fullsize7.3L, Gecko, getsum, Gibrid4x4, golfer, gracing, GRNDNL, GS247, Hamstn, harleyf250, haucks, helsel_182, hendricksbus, highboost, HOLMES, Ignorant1, imelmo, IndianaDiesel, itsnunya, Jason.Horath, jawsfx4, jaybuller, jdexcursion, Jeff Watts, Jeremy, Jetblack, Jimbo*, jjmills, Jngreen, Johnboy3, johnrhodes, JoJo, jones184, Joshs4x4toyz, Jquillz, jr_backdaddy, JSchuricht, jth4570, JustDiesel, JustEZNAlong, juxtoposed, kasey200, kcbillb2, kdsf350, KJS1820, knoxville, Kodiax, Kohrnholio, KOOOPSD, LaMoparPower, leoneo01, li'l tugger, Lohe, LTORRES, Lyrch75, Madisdaddy0505, manureman, manvan, mattmankow, mghay, MikeZR-1, MilehighEX, Moroney167, Mr02kota, NC7.3, NEVRNF, Newman, nitroteam, njneer1, nm351, nokes43, North Pro diesel, northeastgeorgiadiesel, o4ep3civ, OBS F350, OBSWIZ, OldschoolPSD, olyaee, ONE BAD EXCURSION, papadelogan, Picanins, pickit, portillo, powerstroke02, PowerSub, prheitz, PSD POWER007, Quadsteerxl, rafaelwmendes, RazorsEDGE, rdr99, RedSS2331, RexLG, Rhino16, rich, rickvm, RIDETHE, rkocurek, RocKrawler, Ron's power stroke, ronaldjamesh, roughneck0913, rpenner54, rsbhunter, Samson, Satan's chariot, ScaldedDog, scottKP99, SeeYa, seg_97, semomotorsports, Shanediggler, Shaw, showtimesolon, silent64, Skew12, slimmpd, sloburban, smoketune, speeddemon31176, StickerMonster, stonecoldrn, Stonepusher, superbad, Super_Hauler, survivalsquid, swimage, TARM, tazjeepman, The Butcher, The Oiler, thedivineguy, thompson238, thoroughbred, tkdbf350, TNScrambler, Tom S, TrainWreck, trimacwest, tsteates, tuckman, twiisted71, Twisted Excursion, twisthappyr6, Tygen1, Vcv, vr4tune, w4racing, wakeupluis, wampaku, washingtoncoastie, wayno, wetnsloppy4x, WhiskeyTangoFoxtrot, White Buffalo, WHPSExcursiom, wildmanben, Willem, WSStucker, wtstang, x-curse-ion, xbox73, ybnrml55, YohanSegaBowser, zbigbig19th, ZBrooks, Zmann, zx800x, z_racing14
You may not post new threads
You may not post replies
Forum Jump
