'05 F250 6.0 codes - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.0L Power Stroke Technical Info
Thread Tools Display Modes
  #1
Old 12-11-2010, 03:30 AM
fredwho
Offline
Member's Gallery
'05 F250 6.0 codes
My 05 6.0 king ranch has been no trouble until now. Three times in the last month I've stopped at a stop sign or signal light and the truck won't make any attempt to pull away. It just idles. Makes no difference how much the
accelerator pedal is pushed, it's as if the pedal is disconnected. After a minute or two it gradually accelerates and after a little sluggishness is okay.
There is no check engine light, but there are codes: U1900, B1352(IGN key-in circuit failure,B1483(Brake pedal input circuit failure) ,and P18769 (description unknown) The local dealer will replace parts until they find the right one,which
would be too costly. Hoping someone recognizes this condition. (127,000 mi)
Thanks in advance, Fred. (314)374-4530 Also !! I've felt the anti-lock vibration
in the brake pedal just prior to each episode - even though dry pavement, routine stop.
Old 12-11-2010, 07:31 AM
Smut's Avatar
Smut
Offline
Banned
Member's Gallery
Re: '05 F250 6.0 codes
My truck does this on occasion when i yank on something. I can usually move the gear selector up and down then to the gear i want and it'll work again. the previous owner of my truck replaced the whole pedal thing down there at one point. So thats all i got for you is the suggestion of it being the sensors in the pedal.
  #3
Old 12-14-2011, 04:27 AM
Mcfly89
Offline
Heavily Fordified
Member's Gallery
I talked to Doug at GoGo about this today and he mentioned that if one of the 5v reference wires has been pinched or rubbed, during an egr delete install or something like that...it could cause this.
__________________
2005 F350 RC Cab/Chassis dually- egr delete
  #4
Old 12-14-2011, 04:18 PM
lenzhotrod
Offline
Member's Gallery
Also your pedal is disconnected. Fly by wire.
  #5
Old 12-15-2011, 01:14 AM
toolmangary's Avatar
toolmangary
Online
Fixing Broken Stuff
Member's Gallery
It sounds like the ABS is going in to false activation, you need to hook up a scan tool and watch wheel speed and see which sensor is dropping out. IDK if that is causing the acc pedal problem, but if the acc pedal act up just after the ABS problem I'd fix the ABS and then see what happens.
__________________
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
(View-All Members who have read this thread : 46
06 f250 man, 1bad306, bad moose, bboteler, bobb267, Bockhold, buc1096, buggut, bustednuckles, cchoptank11, clp13294, doofpowerstroke, Doug800, F350POWERSTROKE, fredwho, Gibrid4x4, Greggenstein, gtmustang00, indiana lineman, irontx25, Jbstroker87, JimmyO, Johnboy3, jzamluk, ktoddford, lght1, matts05f250sd, Mcfly89, monkeymanstunna, MT Pockets, orrwhat, pats diesel shop, Shef, ShiftyCapone, Smut, sprayjock, stroked, toolmangary, toycrawler, TWEETER, WAMRACN, wiltface, wyoradcat, zs6.0
You may not post new threads
You may not post replies
Forum Jump
