FICM 7 pin - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.0L Power Stroke Technical Info
Thread Tools Display Modes
  #1
Old 12-09-2010, 03:39 PM
toolmangary's Avatar
toolmangary
Offline
Fixing Broken Stuff
Member's Gallery
FICM 7 pin
I'm trying to find out if the 7 pin and 4 pin FICM have the same repair procedure. Everything I have found is for the 4 pin. Also I'm a little confused about which screw to check for 48 volts on the seven pin. Thanks Guys
__________________
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
Old 01-21-2011, 08:50 PM
iceman89m's Avatar
iceman89m
Offline
Member's Gallery
Re: FICM 7 pin
On the 7 screw it is the top row of 4 screws all the way to the left...
On the 4 screw it is the screw all the way to the right...
__________________
03 6.0 8" Dick Cepek suspension,PJ Dirt Grip 37X14.50X16 mounted on Polished DC-1, 3 1/2" exhaust with 4" core glasspack,Frantz TP Bypass,Bullydog Triple with outlook and AEM Brute Force intake
RIP Will Iott
http://www.MikesDieselPerformance.com/
  #3
Old 01-21-2011, 09:01 PM
bdavidsontexas
Offline
Member's Gallery
Re: FICM 7 pin
Repairing the circuit board will be the same procedure.
__________________
Ford Certified POWERSTROKE TECH....
F250-550 Everything....
  #4
Old 01-22-2011, 12:19 AM
Fasttimez's Avatar
Fasttimez
Offline
Word
Member's Gallery
Re: FICM 7 pin
I believe the resistors on the 7 pin FICM are in a different place on the board vs the 4 pin FICM, everything else should be the same.
__________________
Don't tell me what your gonna do, come back and tell me what you did !!!
(View-All Members who have read this thread : 58
03-blue-Powerstroke, 04MT, 06bigbluestroker, 123rday68, 2006powerleaker, 6.0wyattj, alwil, bad moose, Barnbuster, BBowden73, bdavidsontexas, BigDeal21, bismic1, blackstax250, bondsman, BPR83, buc1096, buggut, bustednuckles, coldhanz, DBM, djanzen, F-250-Owner, Fasttimez, Fever, Fordfreak4life, FordSuperDuty05, FX4 F2-Fifty, Goose, HeavyAssault, Hillz, iceman89m, id: 5520, irontx25, jagular7, joostmee, jwfrauts, kfletcher, kip4234, lefeaux, legionxxii, LILGSX, MColeman, MrOneEyedBoh, pro350hydro, RAYCO, rentstdi, seanmesaeh, sga6.0l, skippy, sly1types, spindrift, Strokin304, toolmangary, TWEETER, Wff250, yellow 6.0
You may not post new threads
You may not post replies
Forum Jump
