97 7.3; crank no start - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > F-250 & F-350 1986-1997 & Other Ford Trucks > 1994-1997 Power Stroke Technical Info
Thread Tools Display Modes
  #1
Old 12-05-2010, 05:53 PM
Tater50
Offline
Member's Gallery
Thought I posted this yesterday, but can't find it.
Bought a 97; 7.3;auto 4x4 for parts; it is a complete truck, just has been sitting for 3 years. So, I said heck, I'll try to start it; might make a great truck for my farm. I am not real familiar w/diesels. Batteries fully charged; block heater on for many hours. Wait to start light works; clicks off after about 5 secs; full of fuel.
Scenario:
1. Cranks but will not hit "at all" w/o depressing the pedal
2. Cranks but will hit & attempt to start while depressing pedal half way
Any suggestions on what procedures that I should take?
Old 12-05-2010, 06:13 PM
madpogue
Offline
Member's Gallery
Re: 97 7.3; crank no start
Does the tach move when the engine's cranking?
  #3
Old 12-05-2010, 07:56 PM
Tater50
Offline
Member's Gallery
Tack moves; unplugged the ICP & it started instantly; runs rough; old fuel, I guess; Only could get 20 MPH; Is there any solution to mix with the fuel to help unclogged the injectors; or maybe a spray to use thru the air intake?
Thanks
  #4
Old 12-05-2010, 08:37 PM
countryboyrob
Offline
Member's Gallery
Maybe the icp sensor is bad?
__________________
02 f250
  #5
Old 12-05-2010, 11:47 PM
madpogue
Offline
Member's Gallery
Power Service Diesel-911, maybe?
  #6
Old 12-07-2010, 11:39 PM
Tater50
Offline
Member's Gallery
Re: 97 7.3; crank no start: Sequence Update
*Fully Charged Batteries
*Block heater on for 3+ hours
*Scanned:
P0344 CMP Sensor Circuit Intermittent
P0603 Internal Control Module KAM Error
P1280 ICP Circuit Out of Range Low
*GPR checked OK
*Drained Fuel Filter
*Removed Fuel Filter (booger to get off) Tried a 1/2" drive; no go. Took a pair of huge pliers; inserted the grip part vertically; held handles w/one hand; other hand put a long screwdriver horizonally between the grips & slowly twisted it off (caution: wear gloves so you won't bust your knuckles)
*Added Diesel Kleen & replaced fuel filter
*Disconnected ICP & blew out oil with air (plug & sensor)
*Tried to start, no start, disconnected ICP; Started up; ran rough
*Replugged ICP
*Put in 4X4 range; Low & drove it for 45 minutes on my farm
3200 RPM was the max out; seems to be running on about 4-6 cylinders
*Placed in 2WD; 20MPH was all I could get across my field; more distance would have gotten 30MPH
*Shut it down: tried a restart, chug a lug; no start.
*Disconnected ICP: slow start, but restarted 3 more times
Proposed future format: will learn more about the P0344 CMP sensor & the P1280 ICP; see if I can purchase those from a recycled place & proceed.
Am I wasting my time on recycled parts?
PS You guys have been great; would have taken me forever to find all this info otherwise.
Later/Tater
  #7
Old 12-08-2010, 12:16 PM
toolmangary's Avatar
toolmangary
Offline
Fixing Broken Stuff
Member's Gallery
The P1280 is your problem, with out 500 psi it is not going to start. I would start with the IPR valve.
__________________
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
  #8
Old 12-08-2010, 09:49 PM
Tater50
Offline
Member's Gallery
IPR Location is on the Driver's side of the HPOP, correct; description?? Plug sensor with wires, I presume??
Thanks
Later/Tater
  #9
Old 12-08-2010, 11:50 PM
Patrick Feeley's Avatar
Patrick Feeley
Offline
Member's Gallery
IPR is mounted on the back of the HPOP. Two-wire plug that is just like the injector plug. IPR is a solenoid-operated valve (the ICP sensor is on the driver's side head). Cheers!
__________________
  #10
Old 12-11-2010, 12:37 PM
toolmangary
Offline
Fixing Broken Stuff
Member's Gallery
Just remember the IPR valve is open with NO voltage, you have to put 12v to it to close it and test it.
(View-All Members who have read this thread : 148
01str88, 01stroke, 1964f250, 1978psd, 2stick, 505yam, 7.3 Strokin, 73smoker, 89 Stroker, 94strokeher, 94_PSD, 95powersmoker, 95smoker, 96strokerbp, 97crewcab, 97F250 HD, aklefty, BambiBasher, bfr44, blackbetty13, br9050, brooksbronco17, BTDESTROYER350, buckey, buckingbrutus, Burg460, Buttermaker, Chad Edwards, COFG-28, Coolrs, coysdieselspecialties, crosswired2, cummins250, Darkhollow, dave96psd, David Kennedy, DcMoore999, Denver, Desert Rancher, dieselsmoke, dieseltec192008, Dogmountain, dsinderson, dubswyoming, F-127, farmall16, farmboy93, FL-R, Flatlander, flicker, FordTech570, fordtough82, ford_guy_t444e, freddie, Gibrid4x4, Goodbar419, greaseballcreeper, hehman250, hwhizbang, ibestrokin97, jc1029, jhedemark, joedaddy, John_DeereGreen, joness, JRod, Kampy, kramarj, larryb, LT313, lubeowner, macgyver5150, MadMax'97PSD, madpogue, madtired1469, mandkole, markt, mdacton, morefuel, Mudbrother, Mustang Jim, nashvillebill, NEBR99.5 OIL BURNER, nolting81, nossliw, Nuttin up, NWPAStroker, Obspsd7.3, ol'white027.3, old Smokey, oldschool, osumrall, Patrick Feeley, Patrolman, pff250hd, Pops, portlandareae28, powerstrokedan96, powerstrokefarmboy, powerstrokeracing, procomp, PS1995, psd444, PSDEng, pstroke96, psu927, purple_heart_350, racefan68, ramkiller97, RC4WD, rmkking6, Rut, SD70M, semomotorsports, shaynep, silverpsd_06, slammed83mazda, sofaking, SouthFlstrokin', southmike, spectreblazer, speeddemon31176, st8flexin, steve burris, strokerfan, StrokinAces1973, strokingkid1392, swamp_ratt, TacticalMonk, Tater50, tdrracing, thebolt, theoldgirl1990, Tom S, toolmangary, TravisT, Twisted Addiction, village idiot, Welder1, wfstell, whytry, wrongway, x-redefined-x, Zapper, zkurtz
You may not post new threads
You may not post replies
Forum Jump
