7.3 fuel leak - PowerStrokeNation : Ford Powerstroke Diesel Forum
Register Members List Timeslips Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 11-03-2010, 11:44 PM
lt.co.11
Offline
Member's Gallery
7.3 fuel leak
Hi, my boss has a 2002 f350 with a 7.3 in it, the prolbem is it is leaken fuel on top of the motor. Im not for sure what fuel issues they have or what uselly goes bad to cause it to leak. I dont know much about the 7.3, I have mailnly worked on my 6.0. Can someone shine some light on what direction to take so im not ripping the top half of the motor off for no reason. Thanks John
Old 11-04-2010, 12:31 AM
FordCowboy's Avatar
FordCowboy
Offline
Member's Gallery
Re: 7.3 fuel leak
Most likely the o-rings for the drain valve on the fuel bowl. Look at the back side of the fuel filter housing with the engine running or key on and look for drips. Other than that it could be any of the other fuel lines going into the fuel filter housing so look at them.
__________________
Early 99 Powerstroke
Crew Cab Short Bed Lariat 4x4
SCT Livewire w/ various custom tunes
Adrenaline
AFE stage 2
Super 66 Turbo
4" straight pipe
Modded IDM
Automatic trans: PI Converter, tugger kit
Leveling Kit w/ 35's
  #3
Old 11-04-2010, 12:52 AM
srswain
Offline
Member's Gallery
Re: 7.3 fuel leak
Just had to replace the fuel line that runs from the fuel bowl back to the rear of the head on the passenger side. It runs under the turbo and there is a metal clamp there that will rub a hole in the metal line. Good luck
  #4
Old 11-04-2010, 03:17 AM
lt.co.11
Offline
Member's Gallery
Re: 7.3 fuel leak
Ok, thanks at least thats a starting point.
  #5
Old 11-04-2010, 03:35 AM
fishyPSD's Avatar
fishyPSD
Offline
Member's Gallery
Re: 7.3 fuel leak
Dealing with the same issue on my 01. Looks like my leak was from the fuel bowl cap gasket. I changed the filter and orings yesterday and it looks like it has stopped. I'll be keeping an eye on it though.
  #6
Old 11-04-2010, 03:37 AM
20007.3stroker's Avatar
20007.3stroker
Offline
Member's Gallery
Re: 7.3 fuel leak
just had mine rub threw this spring, but it could also be orings. if its losing fuel fast id say line considering when mine wore threw you could almost follow where i went at about 25mph. slow id say orings.
__________________
2000 7.3 f-250 4X4 CCSB
Mickey Thompson rims
Cooper Discoverer S/T tires
f350 front springs, add leaf and added overload in rear
Warn manual front hubs
Straight piped
AFE stage 1 kit
more power mods starting as $$ allows
  #7
Old 11-04-2010, 01:16 PM
bill4d's Avatar
bill4d
Offline
Member's Gallery
Re: 7.3 fuel leak
Check the 2 lines on the passenger's side of the fuel bowl and 1 line on the driver's side of the fuel bowl. They have sleeves, not o-rings, that form the seal inside the line. Mine had rotted away and that's where my leaks were coming from. I believe they're referred to as Parker Fuel Sleeves.
__________________
2002 F-350 7.3L SRW SB
aFe Stage II Intake
Garrett 38r Turbo
Non-EPBV Pedestal
aFe Intake Manifold
AIH - DELETE
EPB Tube - DELETED
EBPS relocated to Intake Manifold
AMJ Intake Plenums
Headers (soon)
Up Pipes (soon)
MBRP 3" DP
MBRP 4" SS Exhaust
Melling LPOP
Fluidampr
  #8
Old 11-04-2010, 01:40 PM
JAKE
Offline
PSN nerd
Member's Gallery
Re: 7.3 fuel leak
Thats where mine was leaking
__________________
97 F250SC 4X4 4 LINKED ON AIR <- FOR SALE!!!!!!
00 F350CC 4x4 I NEED A FLATBED FOR IT!!!!! LET ME KNOW IF YALL KNOW ANYBODY THAT HAS ONE
TOTAL DIESEL PERFORMANCE
STOCK HORSE OF TEXAS ASSN
SOUTHWEST REINED COWHORSE
  #9
Old 11-04-2010, 01:54 PM
southmike's Avatar
southmike
Offline
Village Idiot
Member's Gallery
Re: 7.3 fuel leak
mine leaked there a few years ago..caught by dealer was a very expensive repair for the 2 orings..
do it yourself cheap.....and easy
__________________
  #10
Old 11-04-2010, 01:56 PM
03_PSD
Offline
Member's Gallery
Re: 7.3 fuel leak
i got a fuel bowl repair kit from guzzle, should be here today. sick of the leaking mess, thought my clutch was heading south, then i smelled fuel...lol
(View-All Members who have read this thread : 190
01stroke, 02-stroker, 02strokinhauler, 03_PSD, 04popo700, 07-OUTLAW, 20007.3stroker, 7.3FisherFord, 93 idi 2WD, 94powerstroke, 96Powerstrokin, 97crewstroke, 99f-250, 99STROKINSMOKIN, abbottfarms, altered65, Alvapowerchoke, Arisley, atlantis, BambiBasher, BDHABT, Big Green, big trucker, bigdaddy60, bignastyGS, Bill R, bill4d, birdog, Biscayne, BlackStroke, blakedunkley, Bobgilly, boostaddict, boxster7614, Boydog, bryan.d, Buckeye Rich, Buford-61, Bushwakd, C&A fish, ccambern, CDAStroker, Chewii, Chris Johnson, chris1978, Chrisp, CLASSICIDI, clay17701, Cmonster, cravin, critter011, Customs&Color, Cutty72, Cwillhite04, defective4x4, deuce-ski, dfordguy, Diesel X, dieselsmoke0204, Diverhardhat, duxpsd, E99Superduty, Elgin MGP, Erik_Lee, farmall99, farmboy73, Farmer89, fastring, fishyPSD, ford0220, ford7.3sd, FordCowboy, Fordguy26, fordpower2008, gaf350, goodie85, Greenman01, griz700rocket, hambony1, HARDTIMES, HeadHunter, Herb in Texas, HNTR22112, hotrodhoward, JAKE, JByrdWend, jerry k, Jerrybizzle, jetdok2r, jimiii, jlermann, jmguyas, Johnny77Mutt, kevin7459, KingRanchSick.0, ky powestroke, LANCE105010, Lazlo, leakingdieselturbo, Lee, lght1, long_n_white, lt.co.11, LTbrassballs, maloneydpm, maverik2711, mghay, Mike96ZJ, Millerfarms, mjp, MN_MountainMan, Mooseposse, mrgto, Mtack, mx929racer, nopainnofear, ol'red, oldschooliscool, Ole, one time, Orcus, otis_301, OUTLAW-OFFROAD, PanioloDuty, papamac, Petro, podirtfarmer, PowerstrokeMudder82, Powerstroker350, PSD-350, psduser1, QtrHorse, R.J., Rgd, RLB88, rndllquinn, robbs4525, Roots, Ross01, sacrifice, sambosque90, savvy1, scagle1, sdcham1, ServiceTech, Shaun Lindmark, shaynep, Shovel, siderbox, SJones505, slddnmatt, SledDogg, slinga, slow_strok'em, smokinstroker92, SouthFlstrokin', southmike, speeddemon31176, srswain, sschwindt, sslong, sticky, stroken97, strokin' n smokin', SWVa, tardymike, TBarrsTruck, TERRCO, The Struggler, thetonka, tjul1128, tpndrcn, travis182008, tree trimmer, trolling2, TRX370r, ttles714, turbodiesel_02, TxFire, tyler5904, UM Canes, umark56, vwenginebuilder, WarDamnEagle, white7.3, wyattearp21, yogi7615, Ziljin
You may not post new threads
You may not post replies
Forum Jump
