Rear disc brake converson? - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > F-250 & F-350 1986-1997 & Other Ford Trucks > 1994-1997 General Aftermarket
Register Members List Timeslips Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 10-26-2010, 05:32 PM
psdguy08's Avatar
psdguy08
Offline
psdguy97
Member's Gallery
Does anyone make a rear disc brake converson for the obs?
__________________
95 F-250 ECLB
6637 air intake, 3 inch dp to 4 inch exhaust, EBPV delete, ccv mod, glowshift gauges ( fuel pressure, boost, trans temp, pyrometer ) Dp tuner ( no start, stock, 80hp econo, 60hp tow)
Cobra 29 classic w/nightwatch, Wilson 1000 magnet mount, weather guard backrack, code 3 lightbar.
Reply With Quote Quick reply to this message Go to the top
Old 10-26-2010, 05:35 PM
BigStroker's Avatar
BigStroker
Offline
The Original
Member's Gallery
Re: Rear disc brake converson?
'85-'98 Ford Sterling
__________________
[CENTER]1994 F350 4x4 5spd, 1995 F250 4x4 5spd, 1996 F250 4x2 auto, 1997 F350 4x4 auto, 1997 F250 4x2 auto
#27
  #3
Old 10-26-2010, 05:36 PM
HAAS's Avatar
HAAS
Offline
On the Darkside!!!
Member's Gallery
Check Test, they have the bolt-on brackets that use 3/4 ton Chevy calipers and E-350 rotors.
__________________
1997 F-350 4X4 CREW-CAB LONG BED
4 INCH SUPERLIFT, EAGLE 058'S
315/75/16 DICK CEPEK FCII
1997 P-PUMPED CUMMINS, STUDDED TOP
HX40W
TIMING DONE
CUSTOM FUEL PLATE
KDP FIXED
NV4500 SB CLUTCH
DIVORCED NP 205 T-CASE 1410's In and Out
DANA 80 W/DISC BRAKE CONVERSION
HOME FABBED TRACTION BARS
AUTO METER PYRO,BOOST GUAGES
5" MITERED STACKS
  #4
Old 10-26-2010, 05:43 PM
psdguy08's Avatar
psdguy08
Offline
psdguy97
Member's Gallery
Thanks guys!
  #5
Old 10-26-2010, 07:34 PM
Big K's Avatar
Big K
Offline
THE ONE AND ONLY!
Member's Gallery
Send a message via AIM to Big K Send a message via MSN to Big K Send a message via Yahoo to Big K
I have a Blackbird Rear Brake Kit for sale
Ford Rear Disc Brake Kits for 9", Dana 60, Dana 70 and Sterling
I got pics of the kit somewhere if interested...
__________________
Kevin "Big K" Neal
President and Webmaster
North Texas Power Stroke Association
kevin@northtexaspowerstrokes.com
www.northtexaspowerstrokes.com
972-768-7252
  #6
Old 10-27-2010, 03:34 AM
Greger96obs
Offline
Member's Gallery
How much you want for it?E-brake?Thanks
  #7
Old 10-27-2010, 03:40 AM
Darth_Stroker's Avatar
Darth_Stroker
Offline
Elmo needs a big kiss
Member's Gallery
tech51 and I are working on a hub conversion that will allow the use of SD axles while keeping the 8x6.5 bolt pattern of the OBS and you'll have brakes made for 8000lb trucks not 4000lb cadillacs. Should have the first axle in next week.
__________________
[SIGPIC][/SIGPIC]
97F350 CC 4x4, DIY intake,4"exhaust,5 pos chip from Cale,BTS Tranny,Beans Stage II's, D66, Beans fuel, Comp 910s, ,Hypermax IC...etc...etc
#59
  #8
Old 10-27-2010, 09:43 AM
PsRumors's Avatar
PsRumors
Offline
Moderator
Member's Gallery
This will be the way to go....
__________________
'97 SCLB 4x4, 3.55, D60 w/ TrueTrac, 6637, Banks Techni-cooler, BTS Trans, Tru-Cool 4921 Trans Cooler, 1.0 exhaust housing, no ebv, 3" DP, Straight Exhaust, E-Fuel, TW tunes, International WP, 203*, Isspro Gauges
  #9
Old 10-27-2010, 02:00 PM
Cratos's Avatar
Cratos
Offline
Member's Gallery
TSM has a kit too
__________________
Blue 2012 XLT SCLB 4X4 , 15,000 miles, 3:55's & 18's Camper and Tow packages. Edge insight, Airlift Wireless compressor & Air Bag set-up, Dieslesite filter kit, ccv mod, deleted :)
  #10
Old 10-27-2010, 11:11 PM
bud48fla's Avatar
bud48fla
Offline
Member's Gallery
fordmann.com | F-350: Sterling Rear Disc Conversion Here is a option also, I used this.
__________________
97' F250 7.3 AT,CC,3"SD intakes,17'HPOP,electric fuel pump system,intercooled, Rosewood Stage 2,TW chip,pillar gauges & overhead console gauges,140 IDM,4"exhaust,315x17 BFG's,RSK with 2in SD Pro Comp springs,10.5 SD rear Diff. 3.55 r&p. 2001 F250 Ext Cab SB. AT V10, Cummins 12v being built.
If you do not want to register, fill this field only and the name will be used as user name for your post.
Human Verification
(View-All Members who have read this thread : 324
'94IDITurbo7.3, 00powersmoke, 02-jeeper, 02POWERSTROKE7.3, 03sub4wstr, 04yfzkid, 1995eddie, 1997F350powerstroke, 1baddually, 1SLO GT, 220Swift, 250turbo, 25toliferacing, 4duggan, 505yam, 76FUMMINS, 79broncoidi, 79jasper, 85yota350, 94.5 Stroker, 94Lightning311, 94powerstroke, 95dieselsmoke, 95f250psd, 95onetonRigRide, 95powersmoker, 95tutone444, 96 stroker, 96kbstroker, 96powerstroker, 96P_Stroke4x4, 96strokerbp, 97 flatbed f-350, 97-7.3powerstroke, 97ccsb, 97f3504x4green, 97obs, 97powerstroke7.3, acer, ajd.., AKclackclack, Alberta 7.3, AMB, Ausm7499, aussie powerstroke, baggedbug, Barnbuilder, BartZ32tt, BBottoms, Bergy1, bhfarms, Big K, bigblack06, bigblock_ford1969, bigdawg69, biggreen96, billmoody1, biostroke1, birddog55, black974door, blackbetty13, BlackFrd, blm510, blown smoke, bobvillaoftn, bored4long, bpa658, br9050, Bradbilt, brads96 stroker, Brain's 97 Diesel, brock96stroker, bud48fla, Buddy B, Bulldog, Burton7.3, CanadianPS, CAT, ccarrier, ccf350stroker, cclb865, Chimera, clackster, clutchkick512, co04cobra, CoastieMike, Cocaptianfork, colbev57, colombo97, Commonrailkiller, Copperhead, copperhead99, cowboy_dan, cp3504x4, crasherdude3, Cratos, crewcab7.3, d-selpowereddiebauer, dalejrfan88, danielzink, Darth_Stroker, dave186, DaveBey, ddrupp, Denver, dfghgfhj, dglenn1969, diesel dane, Dirty D 444, DMDP, DNSPSD, Drew2010, driveline, dsinderson, dswhite, dt466E, dukedrummer89, dutchymount2, ellisfl09, Elog91, estrada5.9, EverettWV, f250towrig, f350jim, farmboy17, fatkid58, fixithud, Flippincgfighter, FordFever, fordnut, foxman, Freeze Plug, GENIUSLOERTS, genuineford, ghostang93, glovemeister, gnxtc2, Goldknight, Goose1995, Got4wd, greaseballcreeper, Greger96obs, gstang408, HAAS, haddixj, halo, Harl, Haztanker, Hijo202, Htownstroker, iadiesel, idahostroker, iluv83vettes, intense134, Jagshred, jake2far, Jamie5714, jasperrandy, JCart, JD3020, jeremymux, JGod, joemx611, John-Boy, jrcoogs, jschildm, JSchuricht, jtlane, Junior, Jwagoner15, K5383, kade625, Kampy, kip4234, konzkustomz, kramarj, LawnRanger, long_n_white, lossscause, loudmouth, M8xpld, marc15663, mattman90, matt_m73, Mav3rick, MB97PSD, Mbarrett, mean matt, Meisner, merlinnilrem, mezz2006, mjonesjr, moDetox, montster, morefuel, mxredneck, nards_13, NastyCracker, Nelson2011, nickeagle, Nodge, not enoughsmoke, novakid69, np205, ns751, NutFarmer97, NWPAStroker, o'red, OBS F350, OBSWIZ, old man dave, Ole, ole red, oneofakindSD, oneton, OUTLAW-OFFROAD, pennsylvaniabo, Peroni, philzman, pontiacross, poon, power73, Power97Stroke, powerstroke095, POWERSTROKE2311, powerstrokemike, powertrip, predator86, prstrk025, psd444, PSDEng, psdguy08, PSDMurph, PsRumors, pstroke96, pullinitdown, quartershot, radcustoms, ramrod7373, Ranger50, ranthom, rat49f6, rd2boys!, ready81, Red 93 L1 #3383, red95psd, redneckabbott, redneckboarder, Rhbass, Rkidd121209, Roenicke95stroker, rolsmojave3, rsfvscott1, Russo2, rusty1161, rustyescott, salprofish, Sea97Stroker, seven.3psd, sg465, Shaolin Crane, Shiryas, shmober, ShogunRider, sick97psd1, silent64, Skew12, Skpph, slammed83mazda, slayer7712, slinga, SLOW STROKIN, snoblade82, SNR, Sodbuster Jr., spanky88, speeddemon31176, spstactical, square1, StandAlone, Stang07, stroke7.3this, strokeorcroak, strokerlahov, Strokersace, StrokinAces1973, Super_Hauler, tbutera2112, TECH51, the great white, TheBeast7.3, thorin, threestud, Tiff, tjbeggs, tjohnny62, TNScrambler, Tom S, toolmangary, Traveler, turbovanman, tyler886, UNCOOL, vanderchevy18, Wackerjr, wadeclinton, wanagofaster73, welderman2008, WichitaF250, wildstang, wint, WolfTraxx, woodtrucker, xrcris, yankstrap, ytee, zabeard, zappattack18, zilla68
Forum Jump
