Oil Leak - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > F-250 & F-350 1986-1997 & Other Ford Trucks > 1994-1997 Power Stroke Technical Info
Thread Tools Display Modes
  #1
Old 10-16-2010, 04:04 AM
jmsmith76
Offline
Member's Gallery
Oil Leak
I've had an oil leak for awhile now, been progressively getting worse. I probably go through a quart a week at the moment. It looks to be leaking into the valley, and through the drain hole at the back of the valley. I may not know what I am talking about here, as I don't know a whole lot about the HPO system, just how it works. But it looks to me that the HPO line connects to the oil rail on top of the head and there are 3-4 plugs up there as well. My leak appears to be coming from one of these plugs. Here is a crappy cell phone picture:
Now what exactly is this, and i can't imagine it'd be too hard to fix, but as mentioned above, I don't know much about the HPO system, lol. Any help on this would be greatly appreciated
__________________
-John-
1996 F-250 Ext Cab Long Bed 4x4
K&N intake with a 6637 Filter
3" MBRP DP, 4" straight pipe
RDS Stage 1's
Adrenaline HPOP
Boost, trans, EGT gauges
Aeroforce scan gauge
6-pos chip with PHP tunes
4" Rough Country Lift
315/75/16 Good Year Wrangler Duratrac
Old 10-16-2010, 07:58 AM
JCart
Offline
Member's Gallery
Re: Oil Leak
That looks to be a high pressure oil plug iirc there are 4 per oil rail per head. Not uncommon to leak there, just need to get replacement o-ring for that plug. Go to your local international dealer and buy replacement high pressure oil rail plug o-rings should be able to buy individually.
jrc
__________________
97 F250 CC Dick Cepek FCII 315, 3:55, D60 Air Locker front, TW files, Tymar in, SD I/C, 140cc 'jectors 17degree HPOP, 6.0 fan, E-air compressor, E-Fuel, SRK, SD springs front/rear, Velvet rides, 145 litre rear tank (now ZF-5 ).97 Red Crew Cab and write-ups
  #3
Old 10-16-2010, 05:06 PM
jmsmith76
Offline
Member's Gallery
Re: Oil Leak
Sweet, that is exactly what I thought it was. Sounds like an easy fix.
  #4
Old 10-17-2010, 01:21 AM
speeddemon31176's Avatar
speeddemon31176
Offline
Demon Dually
Member's Gallery
Re: Oil Leak
That looks to me like you have blowby oil coming out of the boot on the y off the turbo causing that mess.
__________________
  #5
Old 10-17-2010, 03:23 AM
Patrick Feeley's Avatar
Patrick Feeley
Offline
Member's Gallery
Re: Oil Leak
Here the part number for the o-ring: (Ford) F4TZ-9N693-A, (International) 1815874C1 (o-ring for HPOP hose to head joint)
There are ports for each cylinder on the HP oil rail, but only one on each side is used for the HP Oil Supply hoses. Cheers!
__________________
SOLD: 94 F350 CC DRW PSD, 5 Speed, 4.10 LS, SBC Con-O, Baldwin Filter, Tymar HPX Hose, 3” DP, Bilsteins, $12 AIC, Coolant Filter, Explorer O/H Console, Trans Temp, Boost, and Pyro, Pedestal Mod, Gutted EBPV
  #6
Old 10-18-2010, 05:01 PM
jmsmith76
Offline
Member's Gallery
Re: Oil Leak
The boots seemed to be in good shape and all looked good when I reinstalled everything after rebuilding the turbo. I don't think that blowby oil from the boot would cause the amount of oil leak that I have. lol. There is a definite trail of oil around where that plug is, and a good puddle in the valley. Got the new o-rings this morning and hopefully will be able to replace them this weekend. Is there anything I need to know about before replacing them? Just take the plugs out, change the o-rings, and reinstall plugs? Anybody got a clue what the torque spec is on those plugs? Thanks!
  #7
Old 10-18-2010, 05:04 PM
jmsmith76
Offline
Member's Gallery
Re: Oil Leak
Thanks for those part numbers! Got the ones from Ford as there is no International dealer nearby. $3.54 apiece But if it fixes my oil leak, then overpriced o-rings are well worth the money. lol
  #8
Old 10-18-2010, 07:34 PM
StrokinAces1973's Avatar
StrokinAces1973
Offline
Rookie Stroker
Member's Gallery
Thumbs up Re: Oil Leak
I don't know what the torque specs are but make sure and lube them a lil before you install them. If they are dry seated you might just rip them from the get go.
__________________
1997 F250 XLT 4x4 CCSB 7.3L Power Stroke, Full Force Stage I 160cc Injectors, E40D, 3:55's, 342,000 milles, Uniroyal 285/75/16 AT's all 4 corners
1968 RS/SS Camaro Mouse Motor Turbo 350 Built Trans Soon to be converted to 468C.I. of Bowtie Big Block
1958 David Brown with front end loader
(View-All Members who have read this thread : 48
02 CCSB, barney1, Bartlett99, bfr44, bftank, big nasty, blubyu02, Bushwakd, chris@mpd, danielzink, Dieselnut7.3, fordman060, ford_guy_t444e, JCart, jmsmith76, jonnydiesel, jsnyder7.3, Kampy, kvn555, macgyver5150, madpogue, majwild1, markt, Michael, MOTO7.3, MUDDIN95, NutFarmer97, Patrick Feeley, Patrolman, PLATO-350, powerjoker97, powerstroke02, powerstroke742008, PowerStrokingMachine, PSDEng, psdmike, REDPOWERSMOKER, rolsmojave3, samoht517, speeddemon31176, square1, stroke931, StrokinAces1973, ToddM715, toolmangary, wadeclinton, xstrokinx
You may not post new threads
You may not post replies
Forum Jump
