DIY LF777 Oil Bypass Installed. - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Other Diesel Topics > Fluids Discussion
Thread Tools Display Modes
  #1
Old 09-29-2010, 12:52 AM
Sea97Stroker
Offline
Member's Gallery
I installed my DIY LF777 oil bypass filter today. The filters get down to 3-5 micron and are 15.00 at Napa when they are on sale. This filter added 2 qts to the system. One of the fittings on the return side I tapped and installed a set screw in and then drilled a hole in the set screw with a 1/16 drill bit to serve as a oriface. I used 5/16 tranny hose that is rated at 400 psi and push lock fittings. I think I have about 75.00 in this setup.
Old 09-30-2010, 01:26 AM
rufushusky's Avatar
rufushusky
Offline
Exploding the magma
Member's Gallery
Re: DIY LF777 Oil Bypass Installed.
Mind me asking what is the part number of filter head? TIA!
__________________
2002 F-350 ECLB SRW 7.3 4R100
6637 203* t-stat 08 diff cover Stancor HPX 6.0 trans cooler
Sold: 2004.5 Ram 2500 w/ 5.9 CTD, Reg Cab 48re
  #3
Old 09-30-2010, 07:52 AM
Sea97Stroker
Offline
Member's Gallery
I will get it for ya..it is a fleetgaurd number, I will post it friday.
  #4
Old 10-01-2010, 12:42 AM
rufushusky's Avatar
rufushusky
Offline
Exploding the magma
Member's Gallery
Found it!
Cummins 3304173S
Baldwin OB1308
  #5
Old 10-01-2010, 02:09 AM
LORDDiESEL's Avatar
LORDDiESEL
Offline
Coal Blower
Member's Gallery
awesome!! Any more detailed pictures?
nice work!
  #6
Old 10-01-2010, 07:35 AM
Sea97Stroker
Offline
Member's Gallery
That is all the pictures i took. Feed line comes off of the 1/8 plug on the oil filter header, return was hooked up to one of the plugs on the side of the engine.
  #7
Old 10-02-2010, 06:19 AM
nation1979
Offline
rollin coal in norcal.
Member's Gallery
did you just come up with this or did you follow a writeup?
__________________
2000 f250 6" lift,37" muds,mbrp,tdp chip,diy intake,built tranny,
2006 stiblouch turbo,injectors,E85 and everything needed to be reliable.
  #8
Old 10-02-2010, 02:38 PM
Sea97Stroker
Offline
Member's Gallery
I did a bunch of reading and come up with this contraption, I did another years ago with info I got on TDS, people have been using this filter for a long time.
  #9
Old 10-03-2010, 04:23 AM
rufushusky's Avatar
rufushusky
Offline
Exploding the magma
Member's Gallery
Different filter but good write up....I am going to replace my Amsoil bypass with this set up(B164) when I change me oil. 15 absolute, 1-2 nominal and like 8 bucks a pop.
  #10
Old 10-06-2010, 08:22 AM
TARM's Avatar
TARM
Offline
Member's Gallery
Great job. I really love seeing people make their own stuff. I think you always take more pride in something when you have had a hand in building it. "Built Not Bought" as they say.
I have installed one bypass based on the Luber Finer ZGard and am installing one with their largest one on my current Xcursion. Between the Luber Finer bypass and the primary full flow filter I use total capacity will be 20 quarts or 5 gallons +25% over stock. With the bypass lines and dual stealths HPOP and extend res etc it will likely be closer to 21-22 quarts I am thinking. We will see. The primary full flow filters down to 10 mic@99.99% and 4 mics @ 75% first pass. the Luber Finer bypass is 2-3 absolute and even lower at nominal.
(View-All Members who have read this thread : 256
02POWERSTROKE7.3, 03-blue-Powerstroke, 03_PSD, 04 f350, 04psdexcursion, 05harley, 07_powerstroke, 08psdbeast, 2004Stroker6.0, 2006oilburner, 444-4D, 450ciPSD, 4wydnr, 661excursion, 7.3FisherFord, 7.3pokesfan, 88automan, 8luggin, 93whitese-r, 97PowerJoker250HD, a5t1, ajholt7, AK Diesel, akcopterman, Alberta 7.3, AllanB, apollyon9515, Arctic Fox, ayrn, BBowden73, biggreen96, bigjas, birdog, black dawg, blownpickup, bm1962, Boczech, boobin, bowhunter71, brandon_7, Brian P. Strickland, brooksbronco17, bryan.d, buc1096, C5dad, Cadmo, capcalvin, Caster, ccrowd, Chad Edwards, chappy, CLAC, Coltaine, compgun, Coueshunter, cp30, craig031600, cummins kid, Cuttintracks82, Cutty72, dave186, Denver, Diesel Mack, Dieselfoot, dieselman, Dieslnevan2009, ditch_dawg, Donnief, Double D's, Dsycutter, duece, DZL JIM, evo45, F-127, f-450coalroller, fastbee, firebolt12r, firedriver19, flightmeck, flyboy41, fordguy64, FordSuperDuty05, FPO, FSJPat, G-Sqrd, Galaxie406, GB's6.0, Gibrid4x4, Greger96obs, halo, harley-kid, hill_billiez, hrc200x, infantry032003, isimar, JAKE, jason812, JCart, jcstroker, JD F350, jelvine1, jeric1, JerseyJim, jetdok2r, jff987, Jjona5, JNORTON, joe22790, joeyc_07, johnday, Johnny77Mutt, jong1969, JonnyB, Jordy53, jr4452, juniort444e, justan03, jvest, K9-K141, kade625, kbmkviii, KCDAXFACTOR, knoxville, lbeinks, Local851ff, LORDDiESEL, losfinch, lowbedriver, ltljoe22, mack7.3, MADMAN36, Martin #6, mbg75, mbruce, menofiron, michcowboy35, micky_blue, Motownfire, mrgto, MustangMatt96GT, Myles_S, myloyambag, narcco, nation1979, ndixie, New6.0PSOwner, Newman, newmexicocrawler, njjeep, Nodge, Northcountrywood, NoSlow6.0, np205, ono_55, opywan5, orrwhat, osumrall, owenmcrae, patrickke, Patrolman, pdizzleinmt, pizza pig, plainjane, POORBOY1964, powertrip, psdmike, psduser1, PsRumors, QtrHorse, R-Bone, redwing2, Relentless1, riverdog, Rlj223, robertc68, roberth58, Rocket Pig, rocketron, rockyandbuddy, roddy, Rodknocker, Roxanne_97, rpenner54, rtkjadams, rusty1161, Sahrens0202, scott2001, scottylov, SDRiverRat, Sea97Stroker, Seabee08FX4, sga6.0l, sgleshot, Shaw, shvlhead78, simpleman, SKWERL, smokey05, Snowman66, SNR, southernsmoke, spruill242, squarebale19, Steamfighter, Stephenallday, Stlyidklr, stoney126, Stroken7.3, strokerta, strokingkid1392, sunny644, Super_Hauler, SyN, TARM, TECH51, Tedzz, The Red Monster, therabbittree, thompson238, Tim @ P.I.S., tmars51, TomzToyz2, totalpower, TrainWreck, tuckman, turbie, turboaz2, TX-4-NRA, TxFire, txgp17, UM Canes, UNCOOL, vatejf, washingtoncoastie, wasted wages, waterhead99, Weatherlite, Wekiwa, wetnsloppy4x, White Buffalo, white250, white7.3, WichitaF250, WideGauge, wjamesm, wranglerjmb, wyoradcat, Xphobe, YoungMT Hick, yzstroker11, zvovchik
You may not post new threads
You may not post replies
Forum Jump
