96 obs has abs light on, why? - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > F-250 & F-350 1986-1997 & Other Ford Trucks > 1994-1997 Power Stroke Technical Info
Register Members List Timeslips Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 09-19-2010, 02:23 AM
montster
Offline
Member's Gallery
My 96 Ford f250 has a abs brake light on, when I start it. Shorty after starting the truck it turns off and with in a 5-10 sec it turns back on and stays on. The brake are working fine and have had no brake work done with in last year. Has any see this before or have any sugestions what it could be. Thanks Monte
__________________
"STAY TO THE RIGHT AND GAS IT"
Old 09-19-2010, 04:55 AM
Patrick Feeley's Avatar
Patrick Feeley
Offline
Member's Gallery
Re: 96 obs has abs light on, why?
When mine did that it was the Vehicle Speed Sensor (VSS) in the rear end pumpkin (even though my speedometer was still functioning normally). I could be something else too (such as wiring harness problems). Cheers!
__________________
  #3
Old 09-19-2010, 12:00 PM
toolmangary's Avatar
toolmangary
Offline
Fixing Broken Stuff
Member's Gallery
When you turn your key on the lights light up to show you that they work, when you start and drive a vehicle with ABS or RWAL it does a self test every time and if it fails then it turns on the light. You can pull a code and see why it is turning on the light when the light is on, usually the dump valve on the frame in the rear brake line is bad, could be VSS on the rear axle. You really need to pull the code or you are just guessing.
__________________
1997 F350 4X4 CCLB PSD
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
$ 1 7 , 5 1 4 , 8 2 2 , 6 4 8 , 0 8 7 is our National Dept
The estimated population of the United States is 317,825,127
so each citizen's share of this debt is $55,108.36.
  #4
Old 09-19-2010, 12:53 PM
johnday's Avatar
johnday
Offline
Olde gear jammer
Member's Gallery
Location: Barton City Mi, under a rock or a log, where the skies are sometimes cloudy all day.
Mine is an SD, but maybe I could give a suggestion. Do you have any squeaking from either front corner when turning? I do, and got playing around with my left front sensor, wiggled it around a couple times, and the squeak got worse. And yes, my ABS light is in solid. I had that wheel bearing changed out, and new brakes done around 3k ago, so naturally I suspected that corner.
Question, if your VSS on the rear axle is bad, wouldn't the speedo and cruise both be inoperable?
__________________
Another nonaligned spokesperson.
Good stuff, trucks bring it!
I don't care if my thread goes off topic, it's all BS anyway!!!
  #5
Old 09-19-2010, 03:23 PM
biggreen96's Avatar
biggreen96
Offline
Member's Gallery
check your fluid level also . if comes on when the level gets to low. or it could possible be your vaccum pump starting to go bad.
__________________
96 cclb f350.
idm mod,
gauges-boost/pyro/trans temp
afe stage 2 intake
dp to 4" straight pipe
studs, springs, pushrods
srp1
intercooler
electric fuel convertion
238/100
dp-tuner f6
T-4 mount and s470.
  #6
Old 09-20-2010, 01:44 AM
Patrick Feeley
Offline
Member's Gallery
The "red" Brake warning light will illuminate when the vacuum is low or if the fluid level is low. The "ABS" light is a different indicator. Cheers!
  #7
Old 09-20-2010, 11:13 PM
aussie powerstroke's Avatar
aussie powerstroke
Offline
From the LAND DOWNUNDER
Member's Gallery
Have you replaced any lights or bulbs with LED recently? This will cause the problems you talking about. There is not enough resistance with LED's to current. If you have a simple inline resistor from any good auto shop will solve problem
__________________
2005 (Aussie)
7.3 6spd
straight piped, moded air intake,
Driven Diesel reg return system & bowl delete, CAT filters,
Autometer, HPOP, Fuel Pressure, Boost,Pyro
Southbend clutch (stock couldn't handle power )
Tunes by Tony Wildman:thumbsup:.
  #8
Old 09-23-2010, 02:40 AM
MN_MountainMan's Avatar
MN_MountainMan
Offline
Smart A$$
Member's Gallery
Once my ABS light came on and stayed on. Fuse kept blowing. Couldn't figure it out until I fixed the wire that went to the third brake light for the topper. Fixed the wire, replaced the fuse, ABS light went out. Go figure!
Dang ABS don't work anyhow.
__________________
'97 F-350 CC 5-spd, Pyro, fuel and boost gauges, Banks intercooler, H2E turbo, Adrenaline HPOP, huge clutch, custom ADII regulated fuel system. Should be about 500 hp at the rear, don't know about torque. THIS IS MY BATTLE TANK- Project in Process
4XMayhem.com
(View-All Members who have read this thread : 148
1978psd, 1996pstroke, 323powerstroke, 4duggan, 6.9turbocharged, 60POWERSTROKE73, 94.5stroker, 95dieselsmoke, 96'BigBlue, 96BlackOBS, 96P_Stroke4x4, 96strokerbp, 97supercab, ANDREW82007, ashworthdb, aussie powerstroke, AzPsd55, AZStang, Barr7.3l, Bergy1, biggreen96, birdco85, birddog55, blackbetty13, blackngray96, bmxanrchy127, Boost96, brooksfruge, BTDESTROYER350, Bugman, caseyk, CAV64, Centxdiesel, CFiss, charbro, Clatterindiesel, cobrabc1993, Colorado, Coltaine, cowBOYER, Crazy97, Critical, dag4566, Darkhollow, dcsnowman169, Delox, Diesel Avenger, dieselboyf350, ding1968, Drew2010, drwoodchopper, dunnc89, Epd444, ericlouie1, farmboy93, fourwheeldrive9, friskyjake, ghohouston, glovemeister, Goldknight, GreatLakesGearHead, HAAS, hehman250, HILL631, Holleran, iadiesel, ibestrokin97, jake9458, JCart, Jeep1947, jeremiahmercier, JesterPgh, JGod, johnday, JRod, jwatkins, Kampy, KARL LAMBERT, knuckleduster271, kramarj, louisvanwilker, Lutz'96, macbanner, macgyver5150, madpogue, maverik2711, mck7916, mikecd, Mini-Stroke..., MN_MountainMan, montster, morepower02, nards_13, ngtstk3r, ntgd1, NutFarmer97, OBS F350, ol' blue 7.3, OLD'SCOOL, Otter70, Patrick Feeley, pff250hd, PJB, PLast, Pops, powerjoker97, Powerstroke newb, POWERSTROKE2311, procomp, PSDEng, pstroke96, racehauler, Redman84, robr1970, Roenicke95stroker, rolsmojave3, rv7, salprofish, scottfedex, Seawatch, sg465, shaynep, silent64, skbaker, sparksf250, speeddemon31176, Spraguee, ssebird, strokefreak, TECH51, Tedzz, TheBeast7.3, timfinnegan, tjl, TOM PERRARD, toolmangary, tughill283, urbanwheeler, village idiot, washingtoncoastie, WidowMaker, wils2527, xbrotherx, xstrokinx, ZCMiller, zilla68, ~NASTYSTROKER96~
You may not post new threads
You may not post replies
Forum Jump
