Changing the rear differential gear oil - PowerStrokeNation : Ford Powerstroke Diesel Forum
Thread Tools Display Modes
  #1
Old 09-17-2010, 11:41 PM
NCStrokin's Avatar
NCStrokin
Offline
Knar Tar Pirate Captain
Member's Gallery
I am thinking about changing my rear axle gear oil in my 2003 F250 i was wondering if anybody had a good way to put the oil back in the differential. I have an aftermarket diff cover and it doesnt have any plugs on it to put the oil back in, im a little stumped on how to go about it. Any suggestions would be great.
Also how can i tell which rear axle i have in my truck, i dont have the axle tag because of the aftermarket diff cover?
Old 09-17-2010, 11:43 PM
Super_Hauler's Avatar
Super_Hauler
Offline
Super Hauler!
Member's Gallery
Re: Changing the rear differential gear oil
you dont have a fill plug? That doesnt seem possible!
__________________
MINE:08 F-250 CCSB king ranch erics tunes livewire
99: sclb 6 speed, 4" lift,4" exhaust, EB
99 F-450: ccfb Boss v plow. 6 speed 5" ex,EB
HERS:2001 F-350 ccsb notta stock!
  #3
Old 09-17-2010, 11:44 PM
PSDfan99's Avatar
PSDfan99
Offline
Member's Gallery
There is a plug in the side of the pumpkin on the drivers side. It's a 3/8" ratchet square plug. pull it out, fill it up until gear oil starts to come out, put the plug back in.
__________________
Early 99 F-350
4" lift on 33's. Daily Driver/ Plow truck.
Swamp's Gen3, 300/200's, Tuning, 76mm Sledgehammer. BTS. Fuel system, ARP's, P-Rods, 910's, and a few other things. Stock Block.
SOLD
New truck:
2009 F-350, 5.4L, 4" lift on 35's
  #4
Old 09-19-2010, 03:33 AM
'99 stroker's Avatar
'99 stroker
Offline
<--501cc,should b 540 : /
Member's Gallery
you can fill them through the speedo sensor hole as well. My flatbed has a goose-neck ball under a 14" or so square door in the bed, so that works real well for me
__________________
Early '99 ccsb 7.3l 4x4 6spd
All Stock Except
Air tank rear bumper
Brush guard w/ fog and driving lights
seat covers
after market floor mats
Fancy Halogen headlight bulbs
Rear license plate light is out
Originally Posted by erikclaw View Post
Those hairy bastards are scary up close!
with all the smoke, power and wheelie popping you might accidently park on a honda
  #5
Old 09-21-2010, 08:05 PM
Highbeam
Offline
Member's Gallery
The OEM diff cover has no fill plug, drain plug, or magnet attached. To drain you remove the cover. To fill, you use the fill plug on the front of the case near the pinion.
__________________
2000 F350 SRW, 4wd, CCSB, PSD
Lowered rear end to F250 height, 4" exhaust w/ muff, foil delete, AIH delete, Ford AIS intake, tru-cool trans cooler, autometer under dash pod and gauges, Mile Marker hubs, 04 headlights, soft tonneau
18' 10k rated PJ car hauler
26' 7500# Creekside RV Trailer
Kioti CK30 tractor
(View-All Members who have read this thread : 113
'99 stroker, 01REDSTROKER, 0373, 1BadF350, 2000XLifted, 4duggan, 6.4power, 97F250 HD, abbottfarms, AJF, AllanB, apollyon9515, Arisley, Bamboo, bfreezy, Big Calo, BIG01RIG, Bill R, bill4d, billmoody1, birdog, blackqball, brunnels, Bushwakd, CARR, cavitation, chopper, cimarron13, cj45lc, ckurtz, cop-out, cota, davetree1, deisel 04 X, dfulcher, Diesel X, DieselBrad, ditch_dawg, DJM, eleventhtruck, eric96ford, erskine_e, fastring, firedude26, gary02psd, Gotti2k7, Greg373, Griz, hdchopfather, Highbeam, Hodadd, hofiveo, Hooch, IL7.3 Powerstroker, jarhead, jayrunner, Jeff H, jello, Jerrybizzle, Jnalaplace, Jordy53, KenV, kramarj, leoneo01, loner1, LOOSEWHEEL, machete31, NCStrokin, Neverdone03, nine54, Ohnny101, overthehillbill, passntime, Phiber Optik, pilot4life, pro350hydro, prplpowerranger, PSDEng, PSDfan99, Putzer, RedSmokey, RichardSATX, RichieRich, riverjet, Robert_H, Rockcrusher, rocketron, rooster, sargentdan, scott2001, shadow6.0, Shep, shock, shreyshah1120, smokeuout09, sniper_101, stick6, stoney126, Super_Hauler, suprhlr, swanfrd, SyN, Tampa450, tbolt, Tipher, TonyW121, toolmangary, Towinearly99, tree trimmer, tsanjose, tubular031, zilla68
You may not post new threads
You may not post replies
Forum Jump
