DT 466 - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Other Diesel Topics > Engine & Transmission Conversion
Thread Tools Display Modes
  #1
Old 03-02-2008, 05:09 PM
blk99
Offline
Banned
Member's Gallery
Send a message via Yahoo to blk99
DT 466
what could I do to a 1990 DT 466 to make some serious power???
I can get one for $200 that is complete but needs a "Wet Sleeve" rebuild.... WTF is that????
would it fit in my SD??? similar footprint to a cummins???
what kinda power is possible for the cheapest amount of money?? say..... around.... $5K....
Thanks
~Jim
Old 03-02-2008, 05:21 PM
Stroked550's Avatar
Stroked550
Offline
Power by IH
Member's Gallery
Send a message via Yahoo to Stroked550
Re: DT 466
Hypermax, Scheid's, Columbus Diesel and a few more all build 466's. They are very popular in tractor pulling. I think a 1990 466 would have the inline inj. pump, so pretty much all the same things as you would do to a 12v cummins to make power. They will fit in a SD but it is a lot of work, the engine is longer than a cummins so you would have to move the firewall, ect. When i wear out my powerstroke there will a inline pumped 466 in my truck, got most of it worked out, just gonna be a big project.
__________________
2000 F-550 CC, 2wd, 6 speed. Homemade bed, 5" exhaust, DP chip, water inj, intake, gauges, ect
Pics
  #3
Old 03-02-2008, 05:24 PM
Cat_Rebel's Avatar
Cat_Rebel
Offline
OBS junkie
Member's Gallery
Re: DT 466
It "could" fit in your truck but some serious mods will have to be considered before hand. It's bigger than a B series Cummins & weighs more too. It has been done before but it's ALOT of work. You can turn up the stock pump alittle or you can find a P pump & throw it on there & really crank out the juice. I know 69W will be in here shortly to fill in the blanks.
__________________
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
  #4
Old 03-02-2008, 06:33 PM
blk99
Offline
Banned
Member's Gallery
Re: DT 466
ok... maybe I will leave it out of the SD but I think for the $200 it would be fun to mess around with...maybe fab some twins, then someday find a rig to put it in....hmmmm.....
but what is a "Wet Sleeve Rebuild".... I dont know tooo much about the bigger engines....
Thanks
~Jim
  #5
Old 03-02-2008, 09:40 PM
jshank's Avatar
jshank
Offline
Member's Gallery
Re: DT 466
wet sleeve means the sleeves are against the water jackets so to get the old ones out ive seen a few beads of weld run down the inside to get them out and then the new one get soaked in dry ice before you put them in. I did it once in high school to a JD engine. That is my geuss as to what you mean by a wet sleeve rebuild.
__________________
2003 f250 crew traded for higher education
new ride 2004 wrx wagon
  #6
Old 03-02-2008, 09:58 PM
blk99
Offline
Banned
Member's Gallery
Re: DT 466
hmmm....so would it be a pretty inexpensive rebuild if everything else was in good shape???
  #7
Old 03-03-2008, 12:47 AM
Cat_Rebel's Avatar
Cat_Rebel
Offline
OBS junkie
Member's Gallery
Re: DT 466
Genuineford know's a guy that has a DT466 in an older chevy like your Perkins setup. I guess it's a DD tow rig & works great.
  #8
Old 03-03-2008, 02:13 AM
69W900A's Avatar
69W900A
Offline
69W900A
Member's Gallery
Re: DT 466
The DT466 is a wet sleeve engine. So you need an inframe kit or an overhaul kit if you want to go all the way. You don't need to mess around with dry ice and all that BS. You just get a standard liner puller and yard them out, stuff the new liners in and your done. A DT466 inframe kit ranges from around 900 - 1,500 depending on what generation that engine is for an aftermarket inframe kit. Add another 500-800 for an overhaul kit.
A DT466 will kit in a SD but you will have to relocate the cooling stack to the bed as the DT466 is longer than a 7.3 or a 6B Cummins. A DT466 only weighs around 350-450lbs more than a 7.3.
For a hotrod build you want a late model 466 with a P-pump. Ideally the last few years before they switched to electronic since they had much better rods and blocks. You can build enough power in a DT466 to scatter every pickup drive-train part in that truck. If you really get serious about putting a 466 in you are gonna need to start looking at getting a real trans and diff as well.
__________________
TAG II, Exhaust Air Guide, K&N FIPK, Hood insulation delete, foil delete, SX and A1000 pumps, door dinger delete, COMPOUND trans coolers and a Banks Stinger+++ with the Banks TransCommand and Chrome curb Feelers.
248.9HP 4ft/lbs @ 3,400 RPM (don't forget to divide by 1,002 and carry the 5).
Nothing worse than a good idea that doesn't work.
  #9
Old 03-06-2008, 02:02 AM
smokyred's Avatar
smokyred
Offline
What else?
Member's Gallery
Re: DT 466
What are the dimensions of a DT466 versus an L series 8.9L Cummins? Because we have an L series in a SD, my Boss' truck. It's been in there since '01. We re-used the factory radiator, works just fine even when grossing 50k+.
As for a trans, you would prolly want an Allison MD3060 or 3000 series. We run the MD3060 behind the L series in the aforementioned '01 SD.
I personally want to put a DT466 in an F-series or a SD, but where I work the only talk is always Ford/Cummins swaps, my Boss has been doing them since 1991, almost as long as Dodge!
Dave
__________________
My Pictures
  #10
Old 03-09-2008, 03:40 PM
powerstrokenstang's Avatar
powerstrokenstang
Offline
Crazy Talk
Member's Gallery
Send a message via AIM to powerstrokenstang
Re: DT 466
yes i agree i have decided 466 is the way to go. p-pumped heavy tranny and rockwells and it could be nasty
__________________
1996 F-250 ex-cab -D60- Motor,fire hoses-Nate,Tuning,Cam-Matt R,P-rods,dummy plugs-Wipe Out,Huffer-Engineered diesel,Carson,Gen3,Idm-Swamps,Rods,studs,fire rings-WOP,Clutch-Valair
455/400's in,S475 T-6 mounted
'84 f-350 2wd, 6.9l, 4spd, drw, flatbed. For Sale
http://community.webshots.com/user/machdriver69
  #11
Old 03-09-2008, 07:09 PM
Cat_Rebel's Avatar
Cat_Rebel
Offline
OBS junkie
Member's Gallery
Re: DT 466
Yes that would be an awesome truck to see.
  #12
Old 03-09-2008, 09:05 PM
Dieselfever's Avatar
Dieselfever
Offline
2010 BOB Points Runner up
Member's Gallery
Send a message via AIM to Dieselfever Send a message via Yahoo to Dieselfever Send a message via Skype™ to Dieselfever
Re: DT 466
You can forget about pulling anywhere also, unless you want to run an exhibition pull
-Michael
__________________
Michael
1997 F350: Regular cab XLT, 7.3L PSD, 5 speed, 4x4, 3.55 - Some Stuff
2000 F350: Crew Cab, Lariat, 7.3L PSD, 6 speed, 4x4, 3.73 - More Stuff
2001 VW Golf: 4 door, GLS, 1.9L TDi, 5 speed - Darn near makes fuel!
  #13
Old 03-09-2008, 09:08 PM
Cat_Rebel's Avatar
Cat_Rebel
Offline
OBS junkie
Member's Gallery
Re: DT 466
-Michael
What if you showed up with a F650-750?
  #14
Old 03-09-2008, 09:48 PM
Dieselfever
Offline
Member's Gallery
Re: DT 466
Most class rules state "One Ton or Less" pertaining to everything(parts) in the class.
-Michael
  #15
Old 03-09-2008, 10:54 PM
Cat_Rebel's Avatar
Cat_Rebel
Offline
OBS junkie
Member's Gallery
Re: DT 466
-Michael
What if there is an F250 cab on it?
  #16
Old 03-10-2008, 12:16 AM
powerstrokenstang
Offline
Crazy Talk
Member's Gallery
Re: DT 466
-Michael
o ill just run in the street class they never pop the hood around here. i know of a guy in PA. thats got a puller w/ a 466, but he pulls like outlaw or something
(View-All Members who have read this thread : 110
02BigD, 03f3507.3, 389SixPack, 444-4D, 505yam, 69W900A, 94ttss, 97psd4x4, 99 7.3, AlanB, AMB, Astnpwr, BFD99, BikeMaker, BikePilot, BlueOvalDiesel, BMac, brahum, caspower, Charles, clayc_989, crowz, danf250, darkstar, Dieselboy, Dieselfever, Dieselgeek, dieselpuller444, dlonno, DMDP, Doakster, fastbarryracing, firestroke, forddieseltweek, fordtrucksrule7, genuineford, greenbeast, honeyshucks, IH_deere_slayer, ironworker25, jdc753, jelk151, Jeremy, Jet Fuel, JHill, joebob3093, joediesle, josesimoes2, jshank, kainers, kts532, lownslow, mad_matt, Mark Kovalsky, mattgw86, matthewd11, mattymx, mbruce, mech2161, mehaffey, mflores, Moulder, mtthwvn73, NCT, northshoredr, okiebindernut, OldschoolPSD, ole_blu, olyaee, Pdt1081, Phatbulldog, Pipewhiner, ponch37300, Powersmoker, PowerstrokeJunkie, powerstrokenstang, rcarroll, RCpullerdude, redimix08, redneckabbott, repower, Riley250, Ripsaw, Rogue1970, scheidt27, SeeYa, silverhoss99, skylinedan, smokyred, smorris, sniperonhigh, Snowman269, squeeks, star73, Stroked550, superf350, TerminatorEngineering, tholt34, tkdbf350, TrailerHauler, tylan, UNCOOL, UNLIMITED_DIESEL, urbandiesel, vapstroke, Vegascrew
You may not post new threads
You may not post replies
Forum Jump
