Fuel Filter Replacement Write Up... - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Power Stroke Nation! > The Library > [6.4L - Technical Info]
Closed Thread
Thread Tools Display Modes
  #1
Old 08-12-2010, 02:30 AM
NathanScott's Avatar
NathanScott
Offline
Member's Gallery
I thought I would do a write up since I didn't see it in the forums...so if it has been done before...sorry.
Here is the parts (I used 2 more 12" extensions for the filter on the rail)...
I let the fuel drain from the valve on the rail filter (about 16oz) I loosened the top filter cap to make sure there was no pressure...
I then started with the rail filter using the 36mm socket...
I moved some of the wire out of the way to make it easier. The designer for this should have his nuts removed with a butter knife!!!!
Attached the 36mm socket...
With a few extensions...
All the way back to get some room to turn...
Once it was loose I found it easier to seperate filter from the cap while it was still in the rail and pull them out.
Replace the seal on the cap and insall the cap in the rail first, then attach the filter to the cap and then install the whole assembly in the pump and torque to 20 lb-ft.
Top was much easier. Remove cap...
Replace filter in cap. Replace and lube seal on cap.
Install assembly and torque to 20 lb-ft.
Purge air by turning key from off to on for 30 seconds. Do this 6 times.
__________________
How many letters of the alphabet do I have installed on my truck???
HS, KEM, MBRP, BDS, PMF, ION, SB
Go to the top
Closed Thread
(View-All Members who have read this thread : 552
'01STROKER250, 03ghosthemi, 03sixspeed, 03torchcobra, 05_PSD_Erik, 06250, 08 king ranch 6.4, 08 powerstroke, 086.4xcab, 08azsuperdutyf350, 08Black6.4, 08Ford, 08ford4me, 08psdbeast, 08redone, 08silverbullet, 08straightpiped, 09BigBoyF250SD, 10kingranch, 1bad4x4, 1fatboy, 1Quik46, 1tontuna, 2001-7.3Liter, 2008 f350, 2008power, 2good2Btru, 300savage, 6.0psd916, 6.4kingranch, 64Diesel, 64folyfe, 64Strokin08, 6L strokin, 6spdcr, 72Lester, 74bronco, 7powerstroke3, 87jumpy, 89notch, 8urzo6, 907superduty, 95onetonRigRide, 99350sd, ad40434, AK Diesel, AllGo'N'Show, Amcnielly, AndyG, AngryLepercon, Antman, aomoore, AR Aggie, ARCTICCAT, arhawkeye, ARU, Ar_hunter, ashby1, AT&F1, Atoy, Atypical Sarge, azblazor, azleflyer, baarrk, Badasssapper67, BajaOrBust, BAR-6.4, Bare26, bbarnett, bbmxandfmx, BCB, bebarney, beemc, Benito, Big Jim 54, BIGCSS, bigdaddy67, bigharleyb, bigisland6.4, BigNiner19, bkdhdd, Blackbullet73, Blackharleyf250, Blk04Snake, Blk350on20s, BLUEBYU, bmaxwell8686, bmwrcs, bnmccoy, Bob63, bodidly, bodidskey, boli714, bradleyscott, BRAVO, brianb7.3, Brichmond, bridgesb51, brkncly, brooksbronco17, bscooter99, bts, bturet, buckcgs, Buford93, BumpRacerX, bw350stroker, bwyche, c-money, Cajun Bear, Cajundude, Cajunhunter67, Canttchtht, ccarrsuperstar, ccarter@philips, CCSracer13, cglenn, Chainsaw1, ChaseN, chodifer, chris d, Chris.V, CLB 2010 6.4, CLIFORD3, cmestrokin, cntryusmc, Cobra23, colombo97, Corey08FX4, countryboy73703, Cppr_Busa, Crack85, cscotted, CTC DEEZUL, cudaguy, cummins kid, curtis1, CURTIS250, customsound, CutThroat, cypher0807, Da Oops, daddystoy, daguirre, danzdiesel, DarrenKrueger, daryls377, david212acu, dblamp, Delta161, Devon_344, Dguts08, DI Sales, diesel71, DieselDZ, Dieselfoot, dieselfreek26, dieselstoke99, dieselvrgn, Dirty Curry Racing, DMAXsmoke, dnabrillhart, DOHC, Drdiesel101, DReese, drunk on diesel, dubious6.4, duddy, Dudley Glass, dueller, Duffie112, duncan351, dweber2, Dzchey21, DzlNut, Earl Elwood, Easyrider6, EBBCLA, edy0way, eleventhtruck, Elite, emmysdad, eric.davis, ewagner05, f-450coalroller, f18man, farmman57, fatboy456, fencegod, festus17, fine69, Fireguy24709, fireresource, firerider5, firetater, flashover1969, FLcruzin, flier32, flightmeck, FordFalcon, fordguy1715, fordktpjoe, fordman4286, fordpowerf450, fordtuff08, foureyed, FTG-05, FullerF250, G-Man, GAMBLINMAN, garybrock, gcsb771wea, Geereed, george german, georgerosen06, gfaststroker, gilly, gman, GMAN1, golfingnut, GooseNorth, graffittticoupe, graywolf, greenday3437, GREGW, griz700rocket, Grossranch, gsxrjason, gtakamoto, GTOKILLER, GWCON, HAMMER!, Happy Camper, harrymank, headviking, HeavyBarrel1812, Heavyhaul, Heavyhaul422, heavytF, herzog, highmtnstrokin, HillBros, hill_billiez, hoehand, Humvette, hzepeda07, IDRich, ilmathewspro, independentreb12, iron butterfly, isistwinteryet, itsallinthestroke, izzybird, J Levine, jacmurr, JAd2752, jaderderr1, Jaydog, jayps5, jaywebguy, jcmoyer2004, jdabnabe, jdgleason, jeconn, jeepnfool, Jeff H, jeff7825, jelvine1, jgerdes2005, jmkeck, joe22790, joestroo, John Mc, Johnny77Mutt, johnnyroastbeef, Jonbones, jordan572, joshua.a.rackley, journeydog, Jritola, JrStroker, jstreet, jt720, jtgf250, Jtpappy6.4, justin202, JuststrokeIT, jvcon, Jwbfx4, Kaufmaniac, Kbryant777, kcavendar, Kedi, keets HD, keithevans, KeninAZ, KingRanch1341, KR69IDI, krc0864, Kris1785, ktmrider, KTP\MW, kylebryan, Lauritsen, ldds12, leer, Leonard Norrid, leonelhag@gmail.com, Levitc88, liftaford6.4, LiftedMoose, LILGSX, lkn4snow2, Loghome Couple, Love2Strokeit, lowen902, Luther's 2008, mabracing, Macguyver, MADMAN36, Martin #6, matt9190, mattldegollado, Matt_P, maxpower, mc204689, Meaty JTizzle, Michael5126, mjc, MobileMiles89, Monstar, Mountainous, MR.KITTEN, mra4x4, MrBill1, mrfandango, MrNiceGuy, Mr_Grumbles, MTStoker, Mugsy, mxz6001, mymudtrk, NathanScott, Nbudinich, Neverforget0722, Nickg9785, nicktb, norris, ntxpowerstroke, number_juan, nutsnboltsjp, o4ep3civ, OBS F350, ogiwalljr, Oh8stroker, okiebindernut, oldskool, Oliver, om3ga, one2nine, OnlyPolaris, OOWeaver68, orlyc, OUSOONERS, OUTLAW101, p8ntballn2, Pan4905, passatdiesel, Pbrr1der, peefrog, Pmac21, pmiller75, pmtren83@optonline.net, pog, Ponesty, pooter, powdersmoke4700, Powerstroke2006, powerstroke6.4, Powerstroker09, Powerstroke_Kid, powrestroke64, ppmcevoy, pqtiii, Preems14, Prew32, PSDfreak, pstroke96, pullinstroker97, pullnit, purple_heart_350, QuickSilver74, r gramling, RacerPuller, racrguy, raptor0690, rbowen9895, rbro7752, Rcdixon76, rcrdav, rdg21, Rebel350Ford, Redneck6.0L, redneckcorvette, redx, ricg, ridered99, rileyrs, RJC2, RJD, Robs94z, RollinCoal, Ronin, Roz, RRandal, RRF985, RRRC, rsopnco1, Rubenk, ruizhernandeztrust, Rwtrower, sallyrun10, salprofish, sandmanfirst, scnd2none, scott2001, SCOUT8ID, SDBG, Seantexastech, Semperfidoordie, seriousdiesel, SGT49, shell_guy, Sher1021, SHERMAN, Shockwave, shootingstar, shvlhead78, sick.osick.4pwrstroke, sideactiondiesel, Silversquirrel, simonmcnasty, sirkdev, Skew12, skobiak, slayer7712, slightlycrazy, Sliver8, slowmans, smitty0255, SmokeMakesMeHorny, SmokinDiesel, SmoKingRanch, SonicDiesel99, SootRoller, SoTexRancher, Sparky351, SPECIAL332, spence_08, Stallion Forward, Stang07, steveo27o, stevepsu, stevestroke08, stik, Stites02psd, Stoked and Strokin', Stoled&Rolled Powerstroke, stonecoldrn, StrokeB4Cummin, stroker62, strokin20, Strokin4life, Strokin6.4, ststt, stumperhead, sucksgashaulsbutt, Super08Duty, superbad, SuperDually08, SUPERSTROKED, supr87gt, svjmd, swedberg311, T-Roy, Tabcheck, TacomaTag, team21racing, TeamChampion12, telarsen, tensixniner, texaspipeliner00, tgdameron, ThaStroke, The Rock, The Silverback, thecrazyhorse, themudgician, tight, Tknox, TLee77, Tmaddox, tnsmoke, tommyboy#1, toodldoo, Tow21, Traction450, tricktom1, TriggerHappy, TripleE44, truckin87, truckshop, TSizemore, Tuckerdog11, Turboeagle15, TX08250, TXStroker97, TXTech11, TX_S, tyoung, ulfan1972, Uncle Buck, UPTHECREEK, usudno, Vader, vawnman, Vermonter, vintage way, WareDat, wargle, wasted wages, western762, WesternWA6.4, wetbike, Whit6996, Will, wjamesm, wolfejeremy24, WoodBoy, wp3223, Wreckedwolf, xtreme01, y0y0, yell0jaket, yosemiddysam, zzaras, _ubeenstroked_
You may not post new threads
You may not post replies
Forum Jump
