Zf5 mushy shifting - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > F-250 & F-350 1986-1997 & Other Ford Trucks > 1994-1997 Power Stroke Technical Info
Register Members List Timeslips Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 08-11-2010, 07:13 PM
bjc
Offline
Member's Gallery
Zf5 mushy shifting
Seems like my shifter went from tight and precise to loose, sloppy, and mushy overnight.
Noy sure why. I checked to see if the shifter housing is loose and it's nice and tight.
Anyone have any insight?
Thanks.
Bj
__________________
1997 F250 SCLB 4x4. 35" tires, ZF5/valair clutch, tymar intake, Diamond/Tymar 3/4" SS exhaust, all stock otherwise.
Old 08-11-2010, 11:53 PM
Patrick Feeley's Avatar
Patrick Feeley
Offline
Member's Gallery
Re: Zf5 mushy shifting
The only thing I can think of is the little white rectangular bushings under the top cover of the shifter. Here are part numbers for the bushings if that's the problem:
Shifter Bushings, ZF 5-Speed
ZF Part #: 1307 306 154
Ford Part #: E7TZ-7C371-A
Cheers!
__________________
  #3
Old 08-12-2010, 12:29 AM
bjc
Offline
Member's Gallery
i guess more investigating this weekend....
i just don't understand how this happens overnight...literally.
either way...something isn't right. even looking at a replacement trans already...mines already making all kinds of grumbling noises...
bj
  #4
Old 08-12-2010, 01:06 AM
rolsmojave3's Avatar
rolsmojave3
Offline
Member's Gallery
If every gear is being mushy all of the sudden it's in the shift lever housing. Pull it and check the detent.
__________________
97' F-350 7.3 5 speed, K&N intake, stacks, some sort of tune.
  #5
Old 08-13-2010, 07:37 PM
bjc
Offline
Member's Gallery
will check that...yup...all gears are loosy goosy...so much so that sometimes, i have a hard time finding 3rd from second.
getting worse and worse...just need to make through sunday...then i can pull it apart.
thanks for the tips.
also, what am i looking for when checking the "detent"? is it pin?
bj
  #6
Old 08-13-2010, 09:10 PM
rolsmojave3
Offline
Member's Gallery
It's in the shifter housing...If you take off the top cover of the trans you issue is in that...You're shifter pivot and detent are on that.
  #7
Old 08-13-2010, 10:03 PM
bjc
Offline
Member's Gallery
ok. hopefully there's something obvious in there... :-).
when i took it off to change the clutch, there didn't seem to be much to it all.
bj
  #8
Old 08-14-2010, 06:47 PM
Talyn
Offline
Banned
Member's Gallery
Midnight Mods: MidWest Trans Short Throw Shifter Kit Install for ZF5
My article will give you an idea of the different parts in the shift tower.
(View-All Members who have read this thread : 63
79jasper, 94Matt, 97 flatbed f-350, 97_redstroke, bigjake34452, billmoody1, bjc, Bradbilt, Bushwakd, carbo96, co04cobra, Derailed, dspowerstroke, ETaylor0056, glovemeister, hag000, icemann650, iowacornfarmer, J'S 97 F-350, jakeloney, JCart, JDOliver, kawamatt2, Ken Newman, Magnum PD, maverik2711, merlinnilrem, Mini-Stroke..., MN_MountainMan, mojoman, morefuel, Nitro41, olsmokey, opieg01, Patrick Feeley, Patrolman, Pops, portlandareae28, powerstroke742008, Powerstrokin444, prostreet67, pstroke96, PWRstroke_smoke, Rayjay25, Redman84, rjustman, rolsmojave3, salprofish, slick_fork, smokey7.3, spectreblazer, Speedracer7c, square1, SS496, Super_Hauler, Talyn, tank23, topshelf7.3l, tughill283, Tylerjm7.3, washingtoncoastie, yzdude250f, zpilgeram
You may not post new threads
You may not post replies
Forum Jump
