Wont start after taking out Hpop - PowerStrokeNation : Ford Powerstroke Diesel Forum
Thread Tools Display Modes
  #1
Old 08-09-2010, 09:42 PM
TimmyNiewald11's Avatar
TimmyNiewald11
Offline
Member's Gallery
i took out my hpop to replace the seal on the drive gear and put it all back together from the hpop up with new seals. but now it wont start i purged all the air out of the lines and put more oil in the rail below the icp and on the passenger side. but it still wont run i checked all my connections and they are all clean and snug besides the one to heat my fuel bowl. does that one matter??? the truck runs on either(i know big no no) but it wont start on its own i also replaced the cps. anymore ideas?
Old 08-09-2010, 09:50 PM
Fordfreak4life's Avatar
Fordfreak4life
Offline
Haters Gonna Hate
Member's Gallery
Re: Wont start after taking out Hpop
unhook that fuel bowl heater then check your fuse 22 i believe, w/e the fuse is for the cig lighter
__________________
  #3
Old 08-09-2010, 09:53 PM
Super_Hauler's Avatar
Super_Hauler
Offline
Super Hauler!
Member's Gallery
It may take a while of cranking to get her to fire over, did you fill the reservior? If not it will take even longer for the lpop to fill the hpop and fire up. Keep cranking
__________________
MINE:08 F-250 CCSB king ranch erics tunes livewire
99: sclb 6 speed, 4" lift,4" exhaust, EB
99 F-450: ccfb Boss v plow. 6 speed 5" ex,EB
HERS:2001 F-350 ccsb notta stock!
  #4
Old 08-09-2010, 10:10 PM
TimmyNiewald11
Offline
Member's Gallery
yes, i filled the reservior. and have cranked for about an hour all together
  #5
Old 08-10-2010, 12:27 AM
Arisley's Avatar
Arisley
Offline
All done now
Member's Gallery
Charge your batteries. It takes hot batts to bust these things off. Even if it sounds like it is spinning over planty fast enough.
__________________
  #6
Old 08-10-2010, 12:47 AM
joedaddy's Avatar
joedaddy
Offline
I know nothing...
Member's Gallery
Are you getting any smoke?
__________________
Doesn't roll with anyone or tag along to be cool...
  #7
Old 08-10-2010, 03:38 AM
TimmyNiewald11
Offline
Member's Gallery
i have been putting the battery charger on it after everytime i crank so the batterys are fully charged everytime i try. But no there is no smoke when cranking.
  #8
Old 08-10-2010, 05:03 AM
mbg75's Avatar
mbg75
Offline
Member's Gallery
try the old cos
__________________
2002 F-250 ccsb, 7.3, Auto, 4x4, BDP Tunes, Stealth Drop In, 4" MBRP, 6637, Van turbo WW ATS, Frantz Bypass,Drilled & Slotted Rotors
  #9
Old 08-10-2010, 05:11 AM
Marty's Avatar
Marty
Offline
Busy Busy
Member's Gallery
Check your ICP/IPR duty cycle while cranking.
Might have got debris in the IPR. It seems I have that issue on every motor I build.
__________________
443.553.9234 - 410.392.3262
Elkton, Maryland
2001 F250 - 11.62 @ 115.76
S475, Irate Gated T4, H11, Crower Springs, Smith Bros, My Fuel, Swamps Tuning, Gen3, 400/400's, Forged Rods.
2003 F350 CCLB DRW
Converted to F450 stuff, EGR Delete, stockish...
  #10
Old 08-10-2010, 08:52 PM
TimmyNiewald11
Offline
Member's Gallery
Im still in the process of learning, so could ya please tell me how to check ICP/IPR duty cycle thanks for all the help everyone
(View-All Members who have read this thread : 144
$and$hark, '99 stroker, -Diesel-, -XX-, 02 CCSB, 02-jeeper, 14fan77, 2000f350v10, 2000XLifted, 95f350, 97WhiteFlatty, 997.3superduty, ADubDiesel, Arisley, bcangelo, bigbadford01, bigdawg69, birdog, bkerr, BlackGold, blacksmoke.r.us, bluedge8, BoomerL37, Boost96, Bushwakd, bw350stroker, CALADASH, captivahach, CGMKCM, Chad Edwards, chiefelec, Chillin, chunkdunker, cmns2500, Cmonster, co04cobra, COFG-28, Cok_Diesel, Coltaine, cop-out, copperhead99, cracklin'stroker, CSIPSD, dfulcher, DieselBrad, diesel_84, dmd, dmstrucks02, doubledoor, dutchymount2, eleventhtruck, flynnardspub, Fordfreak4life, FordXtreme, fstasvr4, ftrav, genuineford, greenbeast, Greenman01, HaysKSFirefighter, hienergy557, internationalpsd, Ithumpwheniwalk, J HO 22, jarhead, JByrdWend, joedaddy, JohnDeere9610, JonSmith, jsmith, juvenile9, Kampy, kypowerstroke, lariat7.3, leer, lincolnlocker, Longdrive, MadMaxwell87, Maroon Harpoon, Martin #6, Marty, maverik2711, mbg75, Mercracing, Micah99PSD, Millerfarms, mnstroker, mojo25sxt, morefuel, Mudwizer, NEBR99.5 OIL BURNER, neverkickn, nine54, Nitrousjunkie347, old Smokey, olsmokey, Ottomatic, Phiber Optik, poon, pstk5088, r00ster, Rhino16, richyrich, riverboy460, Rubenk, Rusty-Ford, RyanG85, salprofish, sdwi, sgleshot, silverf250, silverslug, SKWERL, SledDogg, slowngreen, smokey bronco, SootRoller, southmike, Specializeddieselnw, Ssg MAJ, stackedstroker, steinberger4, Strokin2006, Super_Hauler, swamp_ratt, SyN, Tampa450, tbolt, TerminatorEngineering, tfast250, Thebigeazy, TimmyNiewald11, toddg, Tom S, tree trimmer, twelch3, TxFire, UNCOOL, vapstroke, Wackerjr, wampaku, zx800x
You may not post new threads
You may not post replies
Forum Jump
