it works fine but sometimes when i hit my brakes my left turn signal light on my dash will light up and go out when i release them i have no idea what would cause this...i do have LED front turn signal bulbs and recon LED tailights but any idea what would cause it to come on when i hit the brakes it dont blink it just will light up and stay on till i release them??
Do the bulbs for your blinker, light up when you apply the brake or is it just the light on the dash? Sounds like a short somewhere, maybe in the trailer harness..:shrug:
yea the front left marker light does light up when i hit the brakes, it doesnt do this all the time just sometimes, since i put the LEDS in for the front markers soo im wondering if it has something to do with that..i talk to PUTCO bulbs and they said i need to put load resistors since the LEDS draws real low power that would fix the hyper flash but im wondering if it has anything to do with the braking problem??
check that the wires on you're trailer wiring harness arent touchin or shorted out,this problem only usually happens when two wires are touching each other and when you hit the brakes it sends power to the brake lights and also to the signal light turning the light in the dash on,or maybe its somewhere else along the frame.
it was the LED fron turn signal bulbs causing the problem i guess because they draw soo little voltage it was messing everything up
107.5K members
