12 MPG???? with a 1996 7.3 - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Other Diesel Topics > MPG - Fuel Economy Discussion
Thread Tools Display Modes
  #1
Old 06-19-2010, 03:26 AM
Big Red F350
Offline
Member's Gallery
I have a 96 f350 crew cab long bed. Built e4od. 3.5" straight thru exhaust. Tymar intake. Tony Wildman tunes. 4.10 rear end. New 315/75/16 AT tires. I dont drive it very hard and I average 12 MPG and thats mostly highway. I cruise at 2200 rpm. When I pull my 6500 lbs trailer I get 8 MPG. Any ideas on what to check? It seems llike most guys are getting 15 -16. I would love that. Thanks
Old 06-19-2010, 03:33 AM
countryboyrob
Offline
Member's Gallery
Re: 12 MPG???? with a 1996 7.3
up-pipes leaking? when was your last oil change? what psi are the tires at? any brakes dragging?
__________________
02 f250
  #3
Old 06-19-2010, 03:40 AM
olsmokey's Avatar
olsmokey
Offline
redneck engineer
Member's Gallery
swap to 3.55 gears
__________________
97 f-250 hd solid axle cold air 4in dp 3in body lift 4in exhaust rollin on 36 12.50 swampers hopfully have 46's under it this fall http://www.dieselpowerproducts.com/
  #4
Old 06-19-2010, 03:48 AM
Big Red F350
Offline
Member's Gallery
oil changed about 8 months ago and used a motorcraft filter. I dont think the up pipes are leaking. Tires are aired to 44psi. Also forgot to mention i have a 3" downpipe. I havent checked the brakes.
  #5
Old 06-19-2010, 03:53 AM
Big Green's Avatar
Big Green
Offline
What Fire?
Member's Gallery
Have you changed out the injectors?
__________________
96 F350 Crew Cab 4X4
Tymar Intake, 4" Chino Valley Muffler Exhaust, Custom Uncool Intercooler, 3 Guage Pillar, Stage 2's, BTS Transmission,
Neck Snapping Power.
  #6
Old 06-19-2010, 04:26 AM
tughill283's Avatar
tughill283
Offline
oil burner
Member's Gallery
too many rpms,get bigger tires or higher gears,or go slower.keep it under 2000 rpms for best fuel mileage.
__________________
96 f250, ZF5,160cc,
300k miles
96 f350 plow truck
  #7
Old 06-19-2010, 05:25 PM
Big Red F350
Offline
Member's Gallery
It has stock injectors with 140k. Does everyone else just drive their trucks between 55 mph and 60 mph?
  #8
Old 06-19-2010, 07:06 PM
Dave Whitmer's Avatar
Dave Whitmer
Offline
MPG Moderator
Member's Gallery
Nope. I drive 60 and 70 MPH.
You have a low-MPG configuration.
The automatic is killing you. The 4x4 costs you 2-3 MPG. The CC is heavy.
The big wheels are kickin' your butt.
You didn't mention a tonneau, so I assume your are running open bed.
Wildman tunes may improve your acceleration, but in that draggy configuration that just means a faster fuel burn rate.
If you can't change the configuration, your choice is stark: Slow down or eat the poor fuel economy.
__________________
2000 F-350 SC 4x2 6 speed
Slammed 4"
A.R.E. Hard Tonneau and Rugged Air Dam
MPG Pending
  #9
Old 06-19-2010, 10:12 PM
countryboyrob
Offline
Member's Gallery
8 months ago = how many miles? also is your firewall covered in soot?
44psi is a little low, I would sir them up to atleast 50psi
  #10
Old 06-19-2010, 11:11 PM
Big Red F350
Offline
Member's Gallery
No soot on the firewall. I have only put on 800 miles since the oil change. The truck usually only gets about 1200 miles a year on it.
(View-All Members who have read this thread : 343
0373, 1950gmcelc, 1995stroker, 1996timemachine, 2006nytro, 302man, 6.0beau, 6.0Dually, 6.0strokin, 6.9turbocharged, 7.3 superior duty, 700,000 powerstroke, 88 gtu, 94.5stroker, 94idi, 94strokeher, 95 Stroker, 95gasser, 96 stroker, 96'BigBlue, 96extccabsb, 96Powerstrokin, 96PSD, 96strokerbp, 97crewcab, 97f3504x4green, 97powerstroke7.3, 97whiteobs, 97XLT7.3, 97_f250_7.3L, 99redf350, 9sixstroker, abrooks63, acrabb, addison, Airstreamer67, ajordan193, alcyinarmy, All Jacked Up, Aminator, AMMO STROKER, andrewmp6, backyardkustoms, badams321, BadDEZL, BadDogPSD, baggedbug, Bair, bazdog1, bcangelo, Bergy1, bhfarms, Big Green, Big Red F350, bigdawg69, BigDiesel, biggreen96, bigstroke, biostroke1, birddog55, Black04Ram, black7.3, black_pstroke, blaineiford, blckwdw, blubyu02, blueoval95, bmorervns20, bobsaggett2007, brahum, brooksbronco17, Bulldog, bulletproof7.3, bustedbinder7.3IH, camd94234, cantrellc123, Caster, Cat00, catch22, Centxdiesel, Chad Edwards, Chadahootchie, chestnut193641, CMWORLEY, co04cobra, Cocaptianfork, Coltaine, conman365, coryneedham, Coueshunter, crowz, ctch1, CumminsTrader, Customs&Color, Cutty72, dalejrfan88, Dave Whitmer, dave186, davey99ps, dbd181, Deerslayer42694, DennisT, Diesel Mack, DieselFreak92, dieselman, Dieseltron, Diesel_Dust, DNSPSD, Donald Becknel, Doodah, DRIOTT, dritter, Dustball8504, dwall, dwbierbach, F-127, fanninator, fcjarrett, firemncw, firstdiesel, fixithud, forddieselkicksass, fordfamily, fordman2121, fordnut, Fordtrucks07, FordXtreme, freddie, friskyjake, fwbkent, geared_low550, golfer, Goose1995, greyf350, halo, Hambanator, hazardiz, hehman250, hendricksbus, Highbeam, highfive, hillbilly123, HOLMES, hughball65, ibestrokin97, IEBahner, Ignorant1, intense134, INTPSTROKE96, Ithumpwheniwalk, J HO 22, jablair, jacmurr, JAKE, Jake Swint, jakeloney, jamessabb, JCart, jcav97psd, JD3020, jeremiahmercier, Jerodl, jhedemark, jhes160, joediesle, JoesEX, jones184, JonFord, josh1.123, JoshuaaT, jrbrock, JRod, jrstang473, JSchuricht, jtsparks2, Kampy, Karbman, Khemosabe, klacasse, knuckleduster271, konzkustomz, kracker055, kramarj, ktownstroker89, KWT2000, kypowerstroke, LawnRanger, Lee, Lifted250, littlewoody, lockdnloaded, lords88, lossscause, loudmouth, louisvanwilker, lv64nova, MADMAN36, MadMax'97PSD, MadMaxwell87, madpogue, mental floss, metrojd, mgraveman, MJBSEVENTHREE, mondosteve, mopowa, morbeeeus, MoStrokinIt, Mpoage, Mudbrother, Mudder_Trucker, MustangMatt96GT, mxredneck, nashvillebill, ncovey, NEBR99.5 OIL BURNER, Nodge, Northcountrywood, np205, NWPAStroker, OBS F350, OBSdan, Obspsd7.3, OBSpstroke97, oldbluef250, oldfordisbetter, oldman, olsmokey, opieg01, Owengilpin6, PahStroke, paretf350, Patrolman, pipewelder1, PJB, pontiac, poon, powerjoker97, Powerstroke newb, Powerstrokin444, powerstrokin97, powertrip, PredatorF250, PSD-BLACK-CLOUD, PSDfan99, psdguy08, psdmike, PsRumors, pstroke96, quicksilver, rabbit_dog91, Racecarhauler, racefan68, RazorbackF350x2, red95psd, redneckabbott, redpower, RiverRat, RMSE, rob72, Robert_H, rsfvscott1, rusty1161, salprofish, SCRAPY250, SD08, SD26, secondarychaos, seven.3psd, sg465, sgh, Shaun Lindmark, shvlhead78, SinnerRacing52, sinnful_46534, sirnunya, slick_fork, smokin99stroke, smokindiesel2, snoblade82, SootRoller, SouthJerseyStroker, spoiled450boy, square1, SS496, Stang07, steve burris, stoker04, strokefreak, Strokersace, StrokerTurbo7.3, Strokin87, Suns_PSD, swamp_ratt, SWFL, tallpaul, TARM, tecster, tfast250, tgf, The Red Monster, thewolf, tholt34, Throwback 7.3, toolmangary, Toxin, toycrawler, Truck4, TruckeePSD, tsedsell, tt500owner, tughill283, turboaz2, turbom700, TylerDurden, UNCOOL, USAF_EOD, village idiot, voodoomaker, waltenbach, washingtoncoastie, wells267, wfstell, Wheels, whitten1, whytry, wildjon, wildstang3, winkfab, wint, woodduck97, woody96, Young-SC-Owner, yybroncoyy, zaairman, zappattack18, ZCMiller, zilla68, Zrock, ~NASTYSTROKER96~
You may not post new threads
You may not post replies
Forum Jump
