7.3 white smoke - PowerStrokeNation : Ford Powerstroke Diesel Forum
Register Members List Timeslips Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 06-12-2010, 09:40 PM
KSC350's Avatar
KSC350
Offline
Member's Gallery
7.3 white smoke
i have a 2003 f350 with a 7.3 and it just started blowing white smoke under acceleration..I checked the compressor wheel and the turbo is fine no oil in the fuel bowl and its not missing or blowing white smoke all the time..All gauges and temps are good.. Any ideas??
Old 06-12-2010, 10:10 PM
Arisley's Avatar
Arisley
Offline
All done now
Member's Gallery
Re: 7.3 white smoke
Take a whiff of your exhaust, let us know what it smells like.
__________________
  #3
Old 06-15-2010, 04:15 AM
KSC350's Avatar
KSC350
Offline
Member's Gallery
Re: 7.3 white smoke
Took a quick smell...didnt really notice anything different?
__________________
2003 F350 7.3 single cab long bed dually manuel fx4. Stage 2 afe intake, stage 1 160 beans injectors, forged rods, dp tuner, 4" straight pipe, wicked wheel turbo upgrade with 1.0 non-wastegated, itp overboost inhilitaor, isspro gauges, southbend clutch.
2003 F250 CCSB 6.0, 4" mbrp turbo back with cat delete.
  #4
Old 06-18-2010, 01:03 AM
KSC350's Avatar
KSC350
Offline
Member's Gallery
Re: 7.3 white smoke
Any ideas guys?
  #5
Old 06-18-2010, 01:11 AM
powerstrokedan96
Offline
Member's Gallery
Re: 7.3 white smoke
does it run rough? any other symptoms?
__________________
96 Stroker, Tymar , 4" Straight pipe, Banks 1.0 housing, Mod. comp wheel, IDM Mod., Edge Evo, 35's
  #6
Marty's Avatar
Marty
Offline
Busy Busy
Member's Gallery
Re: 7.3 white smoke
Fuel pressure?
__________________
443.553.9234 - 410.392.3262
Elkton, Maryland
2001 F250 - 11.62 @ 115.76
S475, Irate Gated T4, H11, Crower Springs, Smith Bros, My Fuel, Swamps Tuning, Gen3, 400/400's, Forged Rods.
2003 F350 CCLB DRW
Converted to F450 stuff, EGR Delete, stockish...
  #7
Old 06-18-2010, 01:49 AM
All Stroked OUT
Offline
HAMMER DOWN
Member's Gallery
Re: 7.3 white smoke
check fuel pressure guarentee its either clogged injectors fuel line or filter had my 2001 do the samething got a bad batch of fuel had to pull the fuel bowl clean that the lines going to each head and the screen in the ports...
  #8
Old 06-19-2010, 01:59 AM
KSC350's Avatar
KSC350
Offline
Member's Gallery
Re: 7.3 white smoke
Okay thanks for the imput guys..Symptons: Runs fine, doesent sound any different and no loss in power. Under hard accell it blows white mixed with black and when its in neutral if i rev it a puff of white comes out with some black. Fuel bowl was clean and so was the filter. I did notice this was only on the higher tuner setting..When i was on stock setting since it doesent blow any black smoke, doesent blow any white either
  #9
Old 06-19-2010, 02:44 AM
golfer's Avatar
golfer
Offline
fueled by Colecovision
Member's Gallery
Re: 7.3 white smoke
with the truck running, at full operating temperature...
unscrew the oil fill cap from the passenger side valve cover...if it has a steady haze (oily mist) then you're in not bad shape...
however...if there is a puff, puff, puff. (as if there is moderate pressure behind it)...then I'm afraid that you've probably lost a cylinder (rings, cylinder walls or cracked piston)...
any oil consumption (or "making" oil?)
when compression is gone in a cylinder...the fuel that the injector is injecting into that cylinder can increase the oil level in the crankcase.
take care~
Dave
__________________
swampsdiesel.com
toll free 866-595-8724
click to send email
  #10
Old 08-07-2010, 02:49 AM
99STROKINSMOKIN
Offline
Member's Gallery
Re: 7.3 white smoke
My truck does the exact same thing. It blows some white smoke sometimes just like yours. I cant figure it out but I may replace injectors.
__________________
1999.5 FORD F250 SUPERDUTY 4X4 EXT CAB
7.3L POWERSTROKE DIESEL
6 SPEED
SWAMPS STAGE 1 SINGLE SHOT INJECTORS
SWAMPS TUNING
6" AUSSIE STACKS
AFE INTAKE W/ PRO GUARD 7 FILTER
VAN TURBO
4" SUSPENSION LIFT
315/75/16 BUCKSHOT MAXXIS MUDDER TIRES ON STOCK WHEELS (WINTER TIRES)
16X9 MOTO METAL 951 BLACK WHEELS (SUMMER)
COWL HOOD
(View-All Members who have read this thread : 512
$and$hark, '99 stroker, 00PSD, 00Rich, 01REDSTROKER, 01_F350-SD, 02 CCSB, 02black7.3, 02f300, 02POWERSTROKE7.3, 0373, 03_PSD, 04popo700, 08ford4me, 20007.3stroker, 2006nytro, 2CAN, 350factor, 35thls1ss19, 393stroker, 4duggan, 5superduty, 6diesel6fuel6only, 7.3 millwright, 7.3 superior duty, 7.3-StRoKeR, 7.3bogger, 7.3psd1999, 7.3_STROKE, 700,000 powerstroke, 73stroke99, 84crewcab, 88 gtu, 93 idi 2WD, 94powerstroke, 95F250, 96PSD, 96strokerbp, 97F250 HD, 99f-250, 99STROKINSMOKIN, 99whitestroker, abrooks63, All Stroked OUT, all-stroke-no-joke, Alvapowerchoke, Amberjax, AnFcowboy, apollyon9515, Arisley, armyman24, badford350, Barnbuilder, Baseball25, bdavidsontexas, Big Bill in Tn, Big Black Truck, big nasty, Big Red 96, bigbadford01, bigblue96, BigJake, bigjake34452, bigpete73, bigred2001, BigRed97, Bigs88, bigwheel, billguns1, birdog, bithead08, black truck, Black04Ram, blackbetty13, blacksmoke.r.us, blacksport03, Blowby, bm1962, boostaddict, borostroker, BowHuntinFever, Boydog, br9050, Brad Johnson, brandon1997, bryan213, Bubba22, Buckeye Rich, budman, Bulldog, bulldog01, bulletproof7.3, Bushwakd, bustedbinder7.3IH, Bustedknuckles, camss10, carbo96, cardiac, CARR, carrj66, Cass, CATnappin, cclb865, Cclinton, ccmac, cdwood388, celltech, Centxdiesel, chach3835, Chad Edwards, cheysays7.3!, Chip, choots, Choupique108, chris1978, chugluglug, chunkdunker, cjsobas, clayhill21, clydesdale, CMWORLEY, Coalroller, codykthekilla, COFG-28, Cok_Diesel, Coltaine, CompOrangeCobra, copperhead99, corbin9191, cota, Country, countylaw, Cratos, Crazzy8, crewcab7.3, crossent, Crosswired, CTFFEMT, Cundiff, Cutty72, cvdenson, damonty94, dan94powerstroke, Dantheman, darkstar, darrell401, davey99ps, dave_k96, dburress, DcMoore999, ddracing, deiter5262, Detox, DEVIANT, devster55, Dieselgeek, DieselPower1966, Dieseltron, djbonsu, dlorence, DMDP, dmoffat, DMOSE10, dmr22, dmstrucks02, Doakster, dpski, dswindell1230, duallyman, Duanesz, duel, Dunbar, duncan351, duner405, Dustin F2504x4, dustinz85, eib, endonoz, erainwater, Ewilly, F350pastor, factorydefect, Fanning7.3, farmall99, farmboy93, fast92gsx, fatherof3, fcmedic19, firefighter, Firehunter, FiveOfastback, FL99F250, flip2spin23, Ford850, fordboy424, forddieselkicksass, fordfamily, fordman25, fordpower2008, forkspear, foxf250, FPKites, Freshmeat, Fuzz, fyrehose, Glock 20, glovemeister, gman1200hd, Gobstopper909, golfer, goodstktbo, gottagofast, grizzly178, hag000, harold_spencer@yahoo.com, hdchopfather, HeadHunter, heavyhauler, heep70, HOLMES, hondaracer315, Houser04LLY, hrc200x, Hughbie2002, iamnonstop, icanski2, iowacornfarmer, j440, jablair, JasonM, jawaner, Jays02F250, jaywiz, jchilcot, jdiesel11, jeenyus73, Jeff Severe, jeffie864, jefsred350, Jetfxr, jgmood050, jhedemark, jlau6888, Jnalaplace, joediesle, Joedog, JoesEX, johnday, johnnie, JohnPShoe, Jolo170, Jomull55, Jonboy215, JSchuricht, jth7708, jtlease, ju015dd, JumpMan92, juniort444e, junkyardyota, jurquhart, JustEZNAlong, Justin@DP-Tuner, k-bmiller, kainers, kempe's repair, Kenneth L. Kilby, KenV, Kevinwatts, KIMMER, klrscoob, krankin, KSC350, KYcopespitter7.3, Laird_73, leakingdieselturbo, Lee, leoneo01, lildevil02, lincolnlocker, livnlrn, locrwln, loner1, longrange223, LOOSEWHEEL, loys95powy, Lt. Dan, lukiss, mack1, MADMAN36, madmaxz, majors, Mark J., markfuga, marksauto, markyt, Marty, matts, mbruce, mdr3crane, meltdown122, merican, metalphd, mfont66, mhfarmboy, middlemanjw, MidwestOBS, Mike96ZJ, Mikes7.3, Miller08, mkeenan, montana350, morefuel, Morning wood, Mpoage, mprobst, Mr.Will, Mr.Wright, mrbleegs, Mtack, mtray, mudslinger02, Mustangranch22, mwb93, mx929racer, mxtwo50r, my66coupe, Myles_S, n20, nadekeys, nasty96, nation1979, ncrandell, neverkickn, NevrKnow, newmexicocrawler, newpowertroker, nielsencod, no-tel-in, np205, NWPAStroker, OBS F350, Obspsd7.3, OBSpstroke97, old Smokey, ONE BAD EXCURSION, opieg01, orangecrush1, outridin, P-nut, ParkerFly, Pequannock, Petro, phastback67, piercy, pilot4life, Pinkpolarbear, podirtfarmer, powdersmoke4700, powerstroke00, powerstroke02, powerstroke3, powerstroke727, powerstroke7396, powerstroke95, powerstrokedan96, powerstrokedub, powerstrokeracing, powerstrokin02, powr2stroke, powwerstroke, procomp, proton, psd kid, PSDEng, PSDfan99, psduser1, pwerstroker, quiznos_69, rabbit_dog91, racefan68, racing11, radcustoms, ralph, RamAirZ, ramassin99, rancher76, randyo156, rb69, rebel4x4, redfordpsd, Renegade7.3, renyren, Repper, reyn7.3, RichWT, rideracelivemx7, Rmartin-97, Rob02F350, Robert6401, Rockyardjo, rogerm311, rollin_smoke, Roots, Ross01, roughneck0913, rpm-inc, rsbhunter, RTJ1S, Rustler, Rusty-Ford, RustyHighboy, rv7, Ryan444, sambosque90, savvy1, sceaston, Scooterg1, SD70M, sdwi, sethc24, Shaolin Crane, shaynep, sheleyco53, shock, silverstomper2, Sinisalo425, Skew12, slammed83mazda, slimer691, Sluther, smitty302, smokie07, Smokin Strokin, Smokin444, smoman, sniper_101, speeddemon31176, st1speed, steinberger4, steve426, str00ker, Stringer Driver, stroked2000, Stroken7.3, STROKER33BC, stroker93, StrokerSmoker01, Stroke_This, strokin'patty, strokin'_it, suprdzlduty, swamp_ratt, sweet97, symbols, tallpaul, tank, tank23, TARM, TD2024, tecatehubbs, texasredneckjae, TexasStroke01, tgf, TheDirt, theoldgirl1990, thomas hendrickson, thorp, tkdbf350, Tmac21, tmurray, TNScrambler, TN_COAL_ROLLERS.00-F250, Tom S, tommylong01, tonka350, tree trimmer, tughill283, TXsmoker, tyler731, Uncle Meat, Utah7.3, Va7.3L, vader's fury, van2002, vapstroke, vegginpsd, voodoomaker, water_junky, whitjo, wick07, wickedx, wildjon, wildstang3, willw, Winmon, WishinIwerFishin, wolfie64, wsigo, wsmit, xrcris, xtreme radial, yogi7615, zaairman, zs6.0
You may not post new threads
You may not post replies
Forum Jump
