911 EGR block off - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.0L Power Stroke Technical Info
Thread Tools Display Modes
  #1
Old 08-05-2007, 10:10 PM
quick26's Avatar
quick26
Offline
Carolina Kracker
Member's Gallery
911 EGR block off
I have the truck apart in the front yard trying to install the EGR block off plate. i loosened up the down pipe, got it out the way, loosened up the band clamp from the cooler to the up pipe and i loosened up the band clamp on the up pipes where they go to the trubo. i got the plate in but the up pipe and cooler seating surface are not mating up too well now. i dont know that the v clamp will pull them back. is it normal to have a small gap between the 2 after installing the plate?
__________________
I am not post whoring, I am providing an over abundance of useless opinion.
www.fireblades.biz
www.myspace.com/quick_26
03 F-350 Lariat CC SB with 6.0
Zoodad, K&N intake, Acufab elbow, MBRP 4" 409 turbo back, SCT tuned by Innovative Diesel, Dual front shock mounts, front add a leaf, eagle wheels with nitto 305 70 16s. 5% tint, linex liner and upgraded audio and video inside
Old 08-06-2007, 08:51 PM
npccpartsman
Offline
Member's Gallery
Re: 911 EGR block off
If you have a gap it's gonna leak exhaust. Have you tried loosening the y-pipe bolts at the exhaust manifolds and giving the whole system a chance to relax? That might help you get it all back together flush as you do have some forgivness at the manifold joints. Just be sure and hit the bolts with some penetrating oil and let them soak for a bit. 10mm flex head gear wrench for the bolt heads on top and 13mm socket for the nuts on bottom. Hope this helps ya out.
  #3
Old 08-07-2007, 02:34 AM
quick26's Avatar
quick26
Offline
Carolina Kracker
Member's Gallery
i wound up getting it. the disc was not all the way in. i got a mirror and looked. took a screw driver and a hammer and when it fell in it poped back shut. i will check for leaks tomorrow. its at the body shop right now
(View-All Members who have read this thread : 61
!!!PainTrain!!!, 123rday68, 1SickHarley, 69W900A, B18B1LS1, BamaSixGun, bigdjvp, bluovldeezl, cager24, CATdiezel, ChaseN, desertwheeler, DIRTBIKEZ, dmdiesel, eabrust, East County stroker, gerrythecowboy, gjoski515, GotRox, HeavyAssault, hillbilly123, Hoss350, JAd2752, jason mondy, jminardi, JR44, kenk, kingranch6.0, Logan21SV, lownslow, Luda25, m7162monster, mini9288, Mooring Product, nhf250, npccpartsman, outlaw5.0, Patrick@DPP, Proud American, PSD Trav, quick26, r83rb, RescueF250, Robts, Roush4_6, rvstroker, Sean, Snowman269, strokethis7.3, The Oiler, THEDIESELMAN, total chaos, toverbey21, tucan, UNBROKEN, waxin, weweld
You may not post new threads
You may not post replies
Forum Jump
