How do you know if your carrier bearing is wearing out? - PowerStrokeNation : Ford Powerstroke Diesel Forum
Thread Tools Display Modes
  #1
Old 08-05-2007, 05:29 PM
sandnut's Avatar
sandnut
Offline
Member's Gallery
Title pretty much says it all. Does it typically wear out slowly & is there a way to test it to see if it's good or bad?
__________________
02 CC 4x4. AFE stage 2, Magnaflow 4" exhaust, BTS tranny, live-tuned by Jody, AC singles, DI regulated return, Terminator HPOP, DR 4.5" lift & some other stuff...
Southern Nevada PowerStrokes
Old 08-05-2007, 05:47 PM
CATdiezel's Avatar
CATdiezel
Offline
Body Type: MULE
Member's Gallery
Re: How do you know if your carrier bearing is wearing out?
The only real way to know is to drop the carrier down and spin it around your self and closely check it for play in the bearing itself and not the rubber junk around it.
I have found more than not that the rubber gets old and gets alot of slop in it before the bearing ever thinks about going out.
__________________
2011- F250 PSD CCSB 4x4 HS PERFORMANCE Tuning DPF OFF EGR OFF TRUCK HAPPY DRIVER HAPPY
your #1 NON-Cult member of the USA Government JustinM.
  #3
Old 08-12-2007, 05:23 PM
Diezel Dawg's Avatar
Diezel Dawg
Offline
I make no power
Member's Gallery
there are times when you have a vibration in your driveline, and it very well coould be your carrier bearing if you dont have any play in your u-joints. The carrier bearing is pretty durable, they dont go out as often as u-joints. We have had a few carrier bearings go out in some of our trucks at work here in the Air Force, and they are a PITA to replace
__________________
99.5 PSD 4x4, GTP38R BB TURBO, DP-Tuner, AFE Stage 2, 6.0L IC, MBRP 4" Turbo Back w/6" tip,
Future mods-- AirDog/ITP Reg Ret. Fuel sys. w/fuel bowl del, Stage 2/3 Injectors or B-codes, Big Oil, BTS or JW tranny
http://www.myspace.com/diezeldawg
  #4
Old 08-12-2007, 06:00 PM
THEDIESELMAN's Avatar
THEDIESELMAN
Offline
Corona Killa
Member's Gallery
get under your truck and push it up and down and see if you have any play but like what was said before the rubber will wear out before the bearing will.
__________________
2007 DODGE 2500 CREW CAB 4X4 5.9 LITER CUMMINS
2002 FORD F-250 CREW CAB 4X4 POWERSTROKE
  #5
Old 08-15-2007, 03:54 AM
slowleak
Offline
Member's Gallery
it sucks when your rubber breaks.....
  #6
Old 08-15-2007, 04:44 AM
THEDIESELMAN
Offline
Corona Killa
Member's Gallery
When you have a full load.
  #7
Old 08-16-2007, 04:30 AM
freddyfast9
Offline
Member's Gallery
You will get vibration when slowing down with you foot off the pedal or coasting if the carrier bearing is going bad, while accelerating it won't vibrate since there is a load on it. I had mine go bad on me and I asked the service manager a million questions about how and why and it killed some time on our test ride. I had quite a bit of play in mine too and he said that they all have a little play in them after using the truck and it's hard to tell that way but the vibration never lies. I solved the problem by switching to a one piece driveshaft and never looked back.
  #8
Old 08-02-2008, 03:33 AM
wrs916's Avatar
wrs916
Offline
Member's Gallery
I am having this very problem as I type this.
01 PSD 4X4 CC w/119,000 miles.
It's been lifted 6.5" since the dealer had 4 Wheel Parts install it back at around 35,000 miles. The driveline is shimmed properly. I pulled the rubber around the carrier bearing and it did not seem to be tore up per se. There is some play at the carrier bearing location. Not a ton but definately noticable. I get the heaviest vibration upon takeoff between 5 and 25mph and then after that it seems to smooth itself out until I stomp on it around 65mph it will make some higher pitched whining noise. Any thoughts?
__________________
  #9
Old 08-03-2008, 01:09 PM
ditch_dawg's Avatar
ditch_dawg
Offline
Genius, when I drink
Member's Gallery
If my truck was lifted I would seriously consider getting a single piece driveshaft from Jesse at High Angle Driveline. As long as you don't have a crew cab long bed he can make on for you.
I had one go bad in my truck.....stock no lift. Ford had an updated on them and replaced it for free. Might want to check into that. I didn't have any vibration just a chirping noise at low speed.
__________________
'03 F250 CC
Truck Pics
"Beer is proof God loves us and wants us to be happy" Benjamin Franklin
Originally Posted by golfer View Post
blip the throttle, and you just changed your "HPOP" oil
put that on youtube
(View-All Members who have read this thread : 170
$and$hark, 00f250, 01Danny, 027.3, 03f250fx4, 04 f350, 04fatboy, 289cobra, 7.3 King Ranch, 94strokeher, 99lariatsd, ackdog, AGV2006PSD, Alan Hicks, Alpine6, Arisley, badluck_early99, bazdog1, Bdickey, Beewoody, bfdiesel, bigjas, billc, Blacksmoke7.3, Blowby, Boomer5, Bushwakd, CATdiezel, Cornraker, crack_7.3, dblaked, dblamp, Deerezilla, Deputydog, Derek2001, DHTD, Dieselgeek, Diezel Dawg, displacedtexan, ditch_dawg, DNTTRY, DSALF250, ELKHUNTER, emtff7959, F-DuceFifty, Fast_Ashley, Firehunter, fishinfool98, Ford_Forgotton, freddyfast9, fxdwgi, glovemeister, gpeyton, greenbeast, grimF350, gtndrty, Harley Strokin', Haul_n_horses2, hawkeye, highboost, humbucker311, indyF-350psd, J-ROCK, jacob.mowrer, jakef250, JayZ, Ja_cain, JCBargholz, Jerrybizzle, JHill, jinco, Jingoist, Jngreen, joediesle, Joedog, jtharvey, ju015dd, JuststrokeIT, kainers, Kanman, kb1, Kickin Y2K, kickstand, Krisco, lincolnlocker, loc712, LongGun_LeRoy, LOOSEWHEEL, maddogmcd, Marty, Miffsudd, Mooseposse, Mr. Elite, MrBill1, mudracer, Muley, NjCj, NWSUPRD, OlBigRed7.3, ole_blu, opieg01, orthopod, PAbowhunter, Pipewhiner, pitbull62, pje, powerstroke1979, powerstrokin247, PowerStrokingMachine, preith, prox445, psd kid, psdexcursion, PSDfan99, PsRumors, radio flyer, RallyGTI, recon250, RedHorseFarm, Ripsaw, rob10970, Rogue1970, Rustler, ryandamo, sandnut, sandpic, satchley, SD01WD, Shep, silverslug, sirnunya, Six Liter, slowleak, sly10, Smokin_KingRanch, smorris, Snowman269, snowman600, Soaggydogg, Stites02psd, strokin_early_99, sttstroke, SWVa, tch.280, Tedzz, Testiclease, theBAT, thedieselkid, THEDIESELMAN, theGreenHornet, Tom S, TomzToyz2, Torque37, TurboDiezel, TxFire, txpsdcrwchf, WarrenF250, Willy, woodtrucker, workstroke, wrs916, X-MAN, XTrmXJ, Zane-03 King Ranch
You may not post new threads
You may not post replies
Forum Jump
