| Register | Members List | Timeslips | Calendar | Sponsors | Becoming a Sponsor | Mark Forums Read | Auto Escrow | Auto Loans | Insurance |
Thread Tools | Display Modes |
#1
help! factory lid on my 7.3 amost twisted off (plastic & o.e) now I replaced the filter seal and it leaks. Is there a update or replacement for this
| Sponsored Links | |
Advertisement |
#2
Re: 97 fuel lid problem
is the gasket square cut, or is it beveled? if its beveled it goes flat against the cap, bevel down at the bowl, or they leak. and yes, when they are upside down, you can twist the cap past the stopping point and cap will jump the threads and leak, i have done this once.
__________________
02 dmax cc dually 4wd "miss piggy" tow bitch 00 f350 srw rc=6100lbs ats comp housing,bdp 1.0 exhaust,afe pr7,4in turbo back magnaflow,hx cross,di regulated return,bbha,dp hi,40,80e,120r,6.oh no cooler autometer gauges
#3
If you need a new lid you can get it form here http://catalog.powerstrokeshop.com/p...&subcat2=86786 or I believe that NAPA also carrier aftermarket lids for the housing.
Jim
__________________
96 F250 XLT 4x4, 4:10 gears, 5 speed, Tymar intake and HX hose, downpipe, pyro and boost guages, coolant filter, Luc clutch |
#4
Check Deiselsite. They have the baldwin with the built in cap. I have been happy for 50k miles (4 filters so far).
__________________
[SIGPIC][/SIGPIC]"TATONKA BLANCA" White 1997 F250HD CC PSD7.3l 4.10s 152k New E4OD, K&N (w/ sock!), 3" DP & delete, Guages x3, Edge Evo, 10k, HPX 2.5" Lift, 285/75 Toyo ATs, Line-X, Shell & Rack Coming Soon... 140v IDM,CCV Mod, Rear Air Springs, and a set of MTs for snow! |
#5
![]() Flat side on bowl with bevel facing up towards cap. Lube with fuel. Bill
__________________
97 Quigley 4X4 PSD |
#6
X 2 what said.
__________________
F-250 PSD 1996 ext.cab 2WD, Short bed, E4OD.
(View-All)
Members who have read this thread : 37
| 250turbo, bbaumann, bigd4me2, BigRed97, BlindViper, Bugman, cemeyer, chaunbot, colliechaser, Cratos, Deerezilla, dennis11, EverettWV, forddieseltweek, genuineford, Got4wd, HossPSD, Jeepermc, John_DeereGreen, Madvan, mandkole, mekdok, merg06, mtnwoody, ono_55, Racecarhauler, racehauler, Riley250, silverslug, smokyred, STROKER #1, StrokerTurbo7.3, Tom S, turboculosis, vaquero |
| Thread Tools | |
| Display Modes | |
