| Register | Members List | Timeslips | Calendar | Sponsors | Becoming a Sponsor | Mark Forums Read | Auto Escrow | Auto Loans | Insurance |
Thread Tools | Display Modes |
#1
Hawk LTS or Hawk Super Duty pads??
In the next few weeks I will order pads and rotors. Which ones though? I currently have Wagner severe duty pads and OEM rotors. I want the best stopping power and am not concerned with brake dust. I was thinking Hawk SD's with cryoed Powerslots. Are they worth the coin?
__________________
'02 F350,SRW,CC,OR,SB.BTS Trans,6.0 cooler! 1.00 coated TN BB,DP Tunes HiI-stock-60T-80E-120R,6.0 Spearco,BWD coated pipes,ITP reg.,BFG 35",4.56gears,Fluidampr,AirDog,4" Magnaflow,AFE2,Ultra-Lite Boost,pyro,trans,DiPricol fuel,PML pan,Mag-Hytec,Bilstein,Dieselsite CF,Centramatics,Hawks&Cryo's |
| Sponsored Links | |
Advertisement |
#2
Re: Hawk LTS or Hawk Super Duty pads??
I believe the regular duty is what most people need for Hawk Pads.... I recall reading that the mega heavy duty pads (or whatever they call em) only work if you have a weighed down welding truck...or something that's extremely heavy all the time like that.
__________________
2009 Ford F250 CCSB Lariat. H&S Minimax tuner, AFE 4" dp back exhaust, AFE Stg 2 PG7 |
#3
2 weeks ago I installed the Powerslot Cryo'ed Rotors & Hawk LTS pads. When I looked online & spoke to Garett at pure diesel power the only reason to go with the heavy duty pads is if you tow everyday. I like the rotors & pads combination - huge improvement over stock. I ordered the SS braised lines also to help take the last bit of spongyness out of the stock rubber lines.
__________________
2003 F250, Wildman tunes, Faubion trns, Swamps 175/146 SS,van turbo/WW, DI Intercooler, oilguard bypass, intank & pre-pump, reg return, Firestone air bags, Bilsteins, 350 HP/692 TQ 2000 Excursion- Pwrd by: T Wildman 6 pos chip, CT Performance Suspension, Riffraff Diesel Performance, J&M Tranny, 4" MBRP, 6637 filter, intank/prepump mods |
#4
I would go with LTS pads. The heavy duty ones can cause some crappy around town driving. Another member had gone through a nightmare with them. They caused a lot of pulling and drifting issues. I would stay away.
__________________
2002 f-350 PSD, 4x4, cc short bed, 6spd, ccv mod, airdog, AIS filter, isspro ev and scangauges, detroit TT, ITP boost annihalator, ITP RR, bellowed up-pipes, ats housing, turbomaster, 3.5 dp magnaflow, very happy with ultra smooth and linear PHP 50t, 80DD and "whisper" tunes http://community.webshots.com/user/clydesdale6 |
#5
Yep, go with LTS.
I had the SD's on mine. Stopped ok but wore through them quick and always sounded like a bus stopping. The SD's are for heavy hauling 99% of the time.
__________________
N.E. Terminator Tech 2000 F350 Lariat CC 4x4 LWB Auto DP-Tuner F5, Terminator HPOP, QSSB, ITP's fuel system, BTS trans. http://community.webshots.com/user/b...host=community |
#6
Thanks guys! I don't tow often so I will do the LTS pads,cryo's and braided hoses. Where's the best place for SS hoses?
#7
Agreed - I have the Hawk LTS pads... work great!
__________________
443.553.9234 - 410.392.3262
![]() Elkton, Maryland 2001 F250 - 11.62 @ 115.76 S475, Irate Gated T4, H11, Crower Springs, Smith Bros, My Fuel, Swamps Tuning, Gen3, 400/400's, Forged Rods. |
#8
I got the SS hoses from Pure Diesel Power (www.puredieselpower.com).
http://www.puredieselpower.com/catal...h8sh89hnsur3e3 |
#9
HHHMMMM surprised to hear of so many problems with the SD pads. I have SDs on the fronts and they have worked great for me so far. I have SDs on order for the rear...guess we'll see what happens.
__________________
1999.5 F-250 XLT Crew Cab Short Box 4X4 7.3L Powerstroke |
#10
More than likely the SD pads have a higher temperature operating range. Due to their range being higher the breaking performance at lower temps (like slow around town driving) will suffer.
I would personally go with the standard pads unless you are running at highway speeds with at least 18,000 gross 90% of the time you drive the truck. Otherwise you will probably never have a problem with overheating the standard Hawk pads. Even at 18,000 gross you may not keep enough heat in them to make it necessary to have the SD pads.
__________________
Eric 96 F-350 CC Dually 300/100% B codes, Stealth dual pumps, H2E, BTS trans, ARP head studs, Comp 910 valve springs, Tyrant Tunes
![]() 6.0 IC, Fuelab electric fuel pump, NAPA 6637 air filter, ITP Overboost Annihilator, AeroTurbine 4040XL |
(View-All)
Members who have read this thread : 81
| 00PSD1, 05lariat, 2MCHPWR, 69W900A, 99F250Smitty, ajohansson, AMB, badluck_early99, BamaSixGun, bconn587, bean, Bigtimearcher, Blowby, Bobcat698, boggerr, Bushwakd, cardiac, cemeyer, clydesdale, comfi, coope3, cota, danneffgr, dblamp, DieselBrad, Dieselgeek, DIRTBIKEZ, ditch_dawg, fbilly420, Fever, fishyPSD, Fordpowered, fords4life, godofdew11, greenlion, guzzle, Haul_n_horses2, High PSI, IRNFST, JAKE, JeepPuller, jinco, Jngreen, joediesle, jtharvey, jvencius, KFinn, mad_matt, Marty, mattymx, Mayday, Millheim, mjp, MrBill1, NWPAStroker, NWSUPRD, PSDnate, psims20, racehauler, rebelchevy02, rich in co, rickvm, San Antonio 78, sandnut, savvy1, SD01WD, Shaw, silverslug, sirthomas, southmike, Strokin02, Tenn01PSD350, Tinscout, Tom S, UNCOOL, vapstroke, White Buffalo, yobuda |
| Thread Tools | |
| Display Modes | |
