99-03 7.3L Powerstroke Exhaust Backpressure Valve Terminator - PowerStrokeNation : Ford Powerstroke Diesel Forum
Thread Tools Display Modes
  #1
Old 05-16-2010, 10:13 PM
SyN
Offline
Lubrication Addict!!
Member's Gallery
After doing some searching around... I came across this small mod.. Can someone please explain to me exactly what the Exhaust Backpressure Valve does? and exactly what this terminator does? After I had bought my 7.3L I did take my sensor out and ran some very thick weedeater string down through the tube to make sure it was not plugged with soot... But I really never thought about what this senor or valve was for.
Thanks Lonnie
99-03 Ford 7.3L Powerstroke Exhaust Backpressure Valve Terminator
__________________
2001 F250 XLT CC 4X4 AUTO SWB
{295K miles}.
Donaldson AIS Intake w/ZooDad
4" MBRP Turbo Back Exhaust.
DieselSite By-Pass Coolant Filter/{ELC}&RMI-25
DieselSite By-Pass Transmission Filter/Lg Magnet
Delete Mods-->{Foil & AIH}
203*{T-Stat}w/Billet Housing
SS HPX line-CCV{to atmosphere}
Marinco Heater Plug
Oil-->T6 5W-40 w/Amsoil Filter
Old 05-16-2010, 10:22 PM
countryboyrob
Offline
Member's Gallery
Re: 99-03 7.3L Powerstroke Exhaust Backpressure Valve Terminator
the ebpv is used to help aid with warmup when the truck is cold.
most people just gut it.
__________________
02 f250
  #3
Old 05-16-2010, 10:45 PM
SyN
Offline
Member's Gallery
How would a fella, go about gutting the sensor?
  #4
Old 05-16-2010, 10:47 PM
countryboyrob
Offline
Member's Gallery
not gutting the sensor, they gut the valve out of the exhaust side on the turbo.
  #5
Old 05-16-2010, 10:55 PM
SyN
Offline
Member's Gallery
ah--Hmmm-ok--Thanks
  #6
Old 05-16-2010, 11:00 PM
countryboyrob
Offline
Member's Gallery
or you can just unplug it so it will stay open.
  #7
Old 05-16-2010, 11:18 PM
SyN
Offline
Member's Gallery
pardon my ignorance to this matter... does anyone have a pic of this valve that is on the exhaust side of the turbo. I have left my 7.3L basically stock for reliability issues... I'm slowly getting more brave and doing more myself.
  #8
Old 05-16-2010, 11:20 PM
countryboyrob
Offline
Member's Gallery
the valve is inside all you would see is like a rod coming off the turbo pedistal that controls it.
  #9
Old 05-16-2010, 11:26 PM
whitjo's Avatar
whitjo
Offline
TennesseeHillbilly
Member's Gallery
__________________
Early '99 F250, 4X4, SuperCab, "PowerStroke", Auto,
PMT1 PCM, DP 80 tow
ISSPRO gauges
BDS front leveling kit
4" straight piped
Sinister pre-pump mod w/filter
Dick Cepek DC1 w/ Nitto Terra Grappler 325/65R18,
Annoy A Liberal....... Work Hard and Be Happy!
Please dont call me white or Caucasian. It offends me.
  #10
Old 05-16-2010, 11:44 PM
SyN
Offline
Member's Gallery
Ok---Thanks guys. So Basically this terminator is for those who want to disable the sensor? And still the senor will not send a code to pcm? I'm not reading between the lines to well tonight?
  #11
Old 05-17-2010, 03:18 PM
Arisley's Avatar
Arisley
Offline
All done now
Member's Gallery
Correct. Without it, it will throw a code, but not a light.
__________________
  #12
Old 05-17-2010, 08:57 PM
aklim's Avatar
aklim
Offline
Member's Gallery
I wouldn't be so sure. Excursions and CA trucks have thrown a code AND a light even when the air temp sensor in the air box is unplugged.
__________________
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U front and A Rear.
  #13
Old 05-18-2010, 12:08 PM
Arisley's Avatar
Arisley
Offline
All done now
Member's Gallery
CA trucks don't count. And Excursions are pretty much CA trucks.
  #14
Old 05-18-2010, 03:02 PM
444-4D's Avatar
444-4D
Offline
Caption This
Member's Gallery
I see no reason to disable it if you don't remove the shaft and flapper. And if you remove the shaft and flapper there is no reason to unplug anything.
__________________
If only those who knew what they were talking about replied, this thread would still be on page one.
2000 F-250 CC 4x4 PSD Auto
  #15
Old 05-18-2010, 03:54 PM
aklim's Avatar
aklim
Offline
Member's Gallery
But even if you do remove the shaft and flapper, should you disable it? Doesn't the ECM use it for some processing? Or so I have been told?
  #16
Old 05-18-2010, 03:58 PM
texaspowerstroker's Avatar
texaspowerstroker
Offline
King of my own world
Member's Gallery
did anyone question the fact that is a plug for $38????
__________________
97 F250 5 speed w/homemade flatbed, diy intake muffler delete, empty emissions device, 10k, 3" dp, 5" tip.
more to come.
  #17
Old 05-18-2010, 04:31 PM
aklim's Avatar
aklim
Offline
Member's Gallery
Who sells that? AFAIK, SP Diesel sells them for $59
  #18
Old 05-18-2010, 04:34 PM
NorCalDiesel's Avatar
NorCalDiesel
Offline
Member's Gallery
The OP mentioned the EBPV and the Exhaust Back Pressure Sensor in the same question. These are two different things entirely. The EBPV is used to control the butterfly valve on the the turbine side of the exhaust outlet. This is used to increase back pressure and consequently cylinder temps when the engine is cold. It is driven off several reference points such as engine temp, ambient temp, etc. If you disable this like many others you will see a DTC show up indicating the sensor is open. If you disable the actual valve and leave the EBPV solenoid plugged in you may see a large oil leak at the valve cylinder on the pedestal. The best way to get rid of this valve is to buy a non-ebpv pedestal and exhaust housing for the turbo. Then get the pigtail sold by dfuser or others that fakes the circuit at the EBPV solenoid. Or if you had to you could wire the valve open and gut the pedestal. Search for "Gutting EBPV". There is no real reason to do this. I did mine when I replaced my entire turbo and only had to buy the Ped since my turbo did not have an EBPV housing. Eliminating this solenoid using the pigtail has no effect on engine performance or drivability. Leaving it open has no effect other than setting a DTC indicating the solenoid is open.
The Exhaust Back Pressure Sensor is mounted on the front of the engine and is fed by a 1/4 inch hard line the runs from the rear of the rear pass side exhaust manifold, over the top pass side of the motor and into this sensor. This is the tube you originally ran some Weedeater string through. This sensor feeds the amount of exhaust back pressure to the PCM and is used to trim fuel delivery and will have an effect on fuel economy. Don't disable this sensor.
Not all the mods here and elsewhere are beneficial. Disabling the EBPV will not have a negative affect on cold weather performance unless you live in sub zero temps. Otherwise it is a bit costly to just do it for no real reason. Good reasons are:
Leaking EBPV valve
Installing and aftermarket turbo without the EBPV housing.
__________________
2002 X PSD, Billy Boat 4", AirRaid, 38R,HO Outlet, IH Up-pipes, Gauges: Boost, EGT, Trans Temp, Fuel Pressure and Water Temp, Oil PSI at Turbo Pedestal
DP-Tuner 6 pos No Start - 140
Super Heavy Duty 4R100 / triple disc from ATO
Transmissions in Sacramento
ICON 5" Spring Pack Lift
PSC Ram Assist Steering
  #19
Old 05-18-2010, 06:33 PM
SyN
Offline
Member's Gallery
NorCal: Thank U! Thats the answers I was looking for... I guess when my stock turbo chooses to retire, I will look into replacing it with a turbo, without the EBPV housing. Until then, I will just remove the sensor and roto rooter the tube out... I took about 25min the first time, no really big deal.
Thanks again
  #20
Old 05-18-2010, 07:22 PM
NorCalDiesel
Offline
Member's Gallery
Thanks again
Like I said. The sensor you're "roto-rootering" and the EBPV are two separate things. If you already cleaned out the Exhaust Back Pressure tubing that feeds the Exhaust Back Pressure sensor then you should be good. The EBPV is entirely different and will have no effect on performance unless the EBPV is stuck closed or partially closed in which case you will see your EGT's skyrocket.
  #21
Old 05-19-2010, 01:08 AM
SyN
Offline
Member's Gallery
I see and understand what you are saying. And understand, the 2 are totally separate items. Thank U!
  #22
Old 05-19-2010, 03:18 AM
Arisley's Avatar
Arisley
Offline
All done now
Member's Gallery
Rehooking up Exhaust back pressure sensor in the morning. Thanks for the info. Never really thought about it before.
(View-All Members who have read this thread : 297
01 SmokeChoke, 01REDSTROKER, 02 CCSB, 02stroker89, 1999F350Lariat, 2000Censtroker, 2000XLifted, 250turbo, 2dedge, 302bullitt, 444-4D, 4duggan, 6.0cj7, 7.3pow3rstrok3, 760 psd, 79kawi, 82crawler, 89s15, 89xj, 91turbogsx, 94strokeher, 99F250Smitty, 99fordcoalroller, AaronL, AK EC-29, aklim, All Stroked OUT, amont22, andrewv_24, Arisley, Barnbuilder, bfog99, bgieselman, Big Head, bigpete73, BigRed97, bigrngyj, bigshawn, birdog, blackedoutsd, blk mk8, blue99sd, BRAVO, brick, broncbeast, bryan rittenhouse, Buford-61, Bushwakd, bw350stroker, cadd, CANNONMAN, captivahach, cavitation, celltech, Chad Edwards, chassross2003, Cherrold, CHevDog1, chief055, Chillin, Chip, Choupique108, Clouse2411, Cloverleaffarm, cmns2500, cody342b, Colorado7.3, coolbreezabq, copperdog, corbin9191, cota, coxral, crabbelle, cracklin'stroker, CSIPSD, CTFFEMT, cvdenson, Dantheman, DHTD, ding1968, ditch_dawg, Diverhardhat, dixieland-diesels, donj1977, Doodah, Duam, Dustin F2504x4, e.nickkk, EastEndLou, elev8ted, ericyr6, Ethan218, f250towrig, farm boy, farmboy930, fbilly420, firedude26, firefighterbam, Firehunter, floorx4, Fordguy26, fordguy64, fordman2121, fr0stbytten, fyrehose, Gaius, gary02psd, genuineford, george german, Glen87, golfer, Got4wd, Granby, Greg373, greyford1979, Griz, gstang408, ham444, harperc, Hassler Diesel, haulin99sdp, hawkeye, HeritageFarmboy, Highstyles_john, HillbillyDeluxe39, HMBUILDER4U2004, huntdog12, Hutch, hyrk, ibleeddiesel, IL7.3 Powerstroker, Invermerepsd, isak, isky1843, Ithumpwheniwalk, j440, jake2far, JCart, JDH, JerseyJim, jhatcher288, Jimmyb4000, JJEEPYJOHN, jlermann, JoesEX, johnrhodes, jopes, Jordy53, joshman3131, joshua.a.rackley, JSchuricht, jsmith, jtjohn, JustDiesel, jvencius, Kampy, kc5grw, KCDAXFACTOR, Kdriscoll, kywildcat, longbowhntr, madmaxz, MagKarl, Mamps, Matty, Mauger, meflamout, Mercracing, Mini-Stroke..., mkf350, mlewis_486, Monstar, moore20017.3, Mooseposse, mrgto, muddynoll, Myles_S, NE-STROKE, NevrKnow, newpowertroker, NH OIL BURNER, nine54, njjeep, nm5roper, Nomad1671, NorCalDiesel, Nuzzlenut, nymn003, OBSWIZ, Ole, otis_301, outlaw 4017, OUTLAW101, paperman, ParkerFly, PeteTx, petik, Phiber Optik, pickit, Pocket, Posjr, Powderking121, powerstrokerrr, Prhartley, PSD POWER007, Purpleslug, r00ster, racer993, rb69, rdnek247, recordbreaker5, Redline7.3, reggie9101, rfrostick, Richie, RichWT, rickvm, rideracelivemx7, rocketron, Rockyardjo, Ron's power stroke, RonB54, roughneck0913, rpm-inc, SBR_GUY, SD70M, sdwi, seg_97, shmober, Shortdrive10, shvlhead78, six8, SKIRK, slayton93, slowleak, slufkin, smoke'n7.3, smokin dually, sniper_101, SouthJerseyStroker, speeddemon31176, spittin dip, sstec, Stewart, stoney126, stroke60, stroke77450, stroke99, stroked, stroked2000, Stroken7.3, strokin_early_99, Stump-puller, stylepointzz, SyN, techteacher, Temecula50, TerminatorEngineering, texaspowerstroker, texasredneckjae, the1laf, TheDirt, Thomas A, thompson238, TIGO-540, Tom S, towsurfer, travis182008, TRX370r, turborangerdude, TxFire, tyewood79@gmail.com, Tygen1, UNCOOL, vafire810, ved0303, Vinno, VW_Factor, whitestang1987, WhiteTrash7.3L, Whiteyf250, whitjo, widieseltech, wildmanben, woo11018, wsigo, xbrandonleighx, zak283, ZBrooks, ZCMiller, zrizzit, zts5026, zx800x, z_racing14
You may not post new threads
You may not post replies
Forum Jump
