7.3 engine removal procedure - PowerStrokeNation : Ford Powerstroke Diesel Forum
Thread Tools Display Modes
  #1
Old 05-12-2010, 03:20 AM
slowleak
Offline
Member's Gallery
I dont see a thread or sticky on this anywhere. Does anyone have a write up on it?
__________________
PMRCM#1
Old 05-12-2010, 03:44 AM
CtG
Offline
Member's Gallery
Re: 7.3 engine removal procedure
Not that I know of... I'd imagine the hardest parts would be exhaust separation and TC bolts? Just properly marking and detaching the electrical goodies and plumbing. And having a cherry picker that can lift 1000lbs safely and high enough.
__________________
Rides-
99.5 F250 PSD SC 4x4 SD: BTS, SS 4" Exh, Tymar, PHP 6-pos w/ Lundstedt custom tunes, 4" lift, Reg. Return, FFD 160CC Single's, GTP38R, Adrenaline, Fuel Bowl Delete- 410HP/828TQ Wheel
02 Excursion 4x4 PSD: 4" DP-back w/ Aero-Turbine, Larry's Black Box
  #3
Old 05-12-2010, 03:48 AM
slowleak
Offline
Member's Gallery
Thats one hell of a lift. I was debating pulling the tranny/tcase out with the motor but no way in hell is that going to happen
  #4
Old 05-12-2010, 04:04 AM
Fordfreak4life's Avatar
Fordfreak4life
Offline
Haters Gonna Hate
Member's Gallery
id remove the grille radiator support, trans, ic, radiator, well pretty much anything in front of the motor and lift it up a couple inchs and slide it out the front
__________________
  #5
Old 05-12-2010, 04:08 AM
slowleak
Offline
Member's Gallery
Im pretty much done at this point, I had just realized there were no write-ups and such anywhere. Figured someone might have a link or something.
  #6
Old 05-12-2010, 05:20 AM
bpcheramie's Avatar
bpcheramie
Offline
Member's Gallery
Send me the truck and you wont have to worry about it.... You can keep the tranny just need the other parts.
__________________
02 F250 All Stock (Project Cheapo)
01 Excursion 4X4 -SOLD
7.3 with Forged Rods (30K) RIP 2/17/2010
7.3 with PMRs (139K) RIP 2/17/2009
01 Excursion 4X4 - RIP 2/22/2008
  #7
Old 05-12-2010, 08:01 PM
genuineford's Avatar
genuineford
Offline
dinnerbooter treasurer
Member's Gallery
Send a message via ICQ to genuineford Send a message via AIM to genuineford Send a message via MSN to genuineford Send a message via Yahoo to genuineford
Remove batteries.
Remove turbo, intercooler pipeing
Unplug main engine wiring harness, When I do it I take the harness completely off the the engine.
Remove the power that feeds the glow plug relay and bring that out with the engine.
Remove cooling fan and shroud.
Drain coolant and remove radiator.
Remove intercooler.
Remove ground wires for starter and one on back of engine by down pipe
remove upper radiator bracket.
Unbolt AC compressor and lay off to the side, do not disconnect hoses
I take off the accessory brackets, the one with the power steering i just lay off to the side.
Remove starter
Remove torque converter shield then torque converter bolts
Remove bell housing bolts
Remove engine mount bolts
Start lifting engine, with jack placed under transmission.
I don't think I missed anything but feel free to add something if it is not there.
__________________
93 F350 Gasser
03 F250 6.0
dinnerbooter #3
  #8
Old 05-12-2010, 08:08 PM
Marty's Avatar
Marty
Offline
Busy Busy
Member's Gallery
No need to remove the batteries or starter
See it right there ->
Just disconnect the batteries.
that is all.
__________________
443.553.9234 - 410.392.3262
Elkton, Maryland
2001 F250 - 11.62 @ 115.76
S475, Irate Gated T4, H11, Crower Springs, Smith Bros, My Fuel, Swamps Tuning, Gen3, 400/400's, Forged Rods.
2003 F350 CCLB DRW
Converted to F450 stuff, EGR Delete, stockish...
  #9
Old 05-12-2010, 08:11 PM
genuineford
Offline
Member's Gallery
Yeah I also dont take the whole front clip off of my truck. It is easy enough to get off so I don't mind.
  #10
Old 05-12-2010, 08:12 PM
Marty's Avatar
Marty
Offline
Busy Busy
Member's Gallery
Oh yeah, flip the A/C condenser off to the side too instead of removing the lines...
(View-All Members who have read this thread : 271
08farmerstroke, 1992ccsbpsd, 2500TD, 2dedge, 3deez, 7.3, 7.3L PowerStroke, 7.3noob, 73stroke99, 887.3DirtyD, 907DAVE, 94.5stroker, 96centurion, 97_f250_7.3L, 997.3ps, 997.3superduty, 99F250Smitty, 99strok3, aaatruckrepair, ads, airfish2011, americandiesel9, apollyon9515, Arisley, Austinj427, BadDogPSD, banshee01, barrakudaman, bbarkley, bcangelo, bhfarms, big adam, bigbadford01, BigRedNewfie, BigTXForddiesel, BlackPearl03, blaze42069, bluedge8, BMF7.3, bmxanrchy127, Boost96, brantheman12, brent, brucem, Bubba22, Bubba609Nj, bulldog01, BURNSY_B_STROKIN, buzzcut265, bw350stroker, CALADASH, CanadianPS, canister, CANNONMAN, Capricious, caseih7010, caseyk, CenCalDually, chassross2003, chief055, Chip, chopper, Choupique108, chris1978, cj45lc, Clatterindiesel, clayc_989, CLIFORD3, clydesdale, cmns2500, co04cobra, cobrabc1993, coondad, cory99, corym, cota, cp30, Crawler374, Critical, CTFFEMT, CtG, cthom388, CUMMINS_KILLA99, cv6446, data_engine, deerepower, deiter5262, dent-techs, dentexpowerstroke, DHTD, Diesel Avenger, Diesel Drinker, Dieselgeek, diesellee, Dieselsvt, Diesel_Jeramy, Disappointedpowerstroke, djriley78, dogmaticus, donj1977, DontPokeTheGriz, double-s-diesel, doubledoor, Driles85, Dustin F2504x4, Dwduggins, F0RR35T, farm boy, Firefighter4hfd, fordboy424, Fordfreak4life, Fordsonly, fourwheeldrive9, foxracing0934, fyrehose, galla35, geargrabbin97, genuineford, gnxtc2, GP0256, gt8249, Gutierrez9287, hanke777, heybuddy25, Hi-psi, hikinginpdx, hog4mee, hondaracer315, HunterD, hwhizbang, icanski2, Ice Mike, ike0321, IL7.3 Powerstroker, indyF-350psd, Ithumpwheniwalk, J HO 22, j440, JAKE, jaredstorer, Jbolen323, JCart, JD3020, Jeremy, jeric1, Jesse_01, jevans73, jlau6888, joedaddy, Jordy53, jpowerstroke, jshwhite, ju015dd, jvencius, k-bmiller, kevin7459, kramarj, kyl1316, lariat7.3, Lildiup, lrazer, LTbrassballs, Luckyb, MahdeyS, markt, Marty, mattscoke, mbg75, mbruce, mcclure518, metalphd, metruis7.3, Mike97f350, mikes95powerstroke, milehighstroker, milleman, mkf350, mnstroker, moco, MoJoe, mojoman, mooseinabox, nadekeys, nasty97, neverkickn, NevrKnow, nickPSD, nine54, No Regrets, Northcountrywood, OBSBoysel, oilburner23, oldwood, ollie218, OSCS, Owengilpin6, pbguy420, Pipewhiner, Power99stroke, powerstroke02, powerstroke155, powerstroke742008, powerstrokehorsehauler, prplpowerranger, PSDEng, PSDfan99, psdmike, Pstroke-early99, quackersf250, R.J., r00ster, recordbreaker5, redrocker, ridnskyhigh, riley1131, RLSCOAL, rocketron, Rockyardjo, Ron's power stroke, schmity, sick97psd1, silverslug, simpleman, sirsofus, Sledge, slowleak, Smoker00, smokyred, SNAFU, southmike, sparksmx450, stackedstroker, stever88, stoney126, stoneykegonsa, str00ker, stroked, Stroke_This, sunny644, swanfrd, T444Stroker, texans, thadru2001, theGREATjL, theSLEEPER, tholt34, Tinker, TomzToyz2, Towhungerford, TrailerHauler, travis182008, trolling2, turfsupdon, Twright, TxFire, tyler731, USMCmudslingers, vintageracer, wampaku, wick07, wildstang, williameub, yavorssj, yyaluff, z0650, zx6rrider, z_racing14
You may not post new threads
You may not post replies
Forum Jump
