Lack of power 2002 F350 7.3 powerstroke - PowerStrokeNation : Ford Powerstroke Diesel Forum
Thread Tools Display Modes
  #1
Old 01-22-2008, 12:29 AM
kenworth
Offline
tbear01
Member's Gallery
Question Lack of power 2002 F350 7.3 powerstroke
I have a severe lack of power in my truck I don't think i'm getting all my turbo psi. The turbo works but not like it use to. I've checked all the piping all good now there is no vacum going to the waste gate is there supposed to be vacum in that line if anyone has any suggestions let me know please thank you.
Old 01-22-2008, 12:34 AM
gregrob's Avatar
gregrob
Offline
Member's Gallery
Re: Lack of power 2002 F350 7.3 powerstroke
No, there is not supposed to be a vacum going to the wastegate, it is a pressure line. Boost makes the wastegate actuator control the wastegate.
You really need to make sure there are no boost leaks (perhaps with a boost leak detector you make yourself or buy from www.dieselsite.com).
Make sure you don't have up pipe leaks.
Make sure your turbo isn't shot. Indicated by excessive shaft play side/side in/out
  #3
Old 01-22-2008, 01:47 AM
00PSD1's Avatar
00PSD1
Offline
Member's Gallery
Fill out your signature so we know what mods you got.
__________________
2000 F250 EX LB 4x4 XLT
  #4
Old 01-22-2008, 12:49 PM
IDPisan's Avatar
IDPisan
Offline
Member's Gallery
Does your truck do this all the time ? If it only happens before truck is up to temp it may be your EBPV doing its job. You mention that all your piping is good. Did you check your boots, up-pipes. When was your last fuel filter change, how is your fuel pressure?
Just a few thing to ponder.
__________________
My two cents, Jeff
Early 99 F350 4X4 CC DRW 6spd. 6637, MKO 4" turbo back 5" straight piped exhaust 6" tip, ISSPro Gauges, Pyro, Boost, Water temp, DP Tuner Stock, 40tow, 60tow,80econo, 120race, KCM S.S. HPX line, ITP Overboost Annihilator, Auto Enginuity,LED GPR Indicator, CCV Mod, 6.0 Intercooler, EPBV delete, Wastegate mod.
  #5
Old 01-22-2008, 06:18 PM
Dieselgeek's Avatar
Dieselgeek
Offline
Member's Gallery
Does the truck make a hissing sound from the exhaust? If so, it is your EBPV, and you won't have any power.
__________________
2002 F350 Reg Cab,4x4,7.3,6Spd.
  #6
Old 01-22-2008, 06:49 PM
Radarman
Offline
power junkie
Member's Gallery
lack of fuel pressure == lack of boost.
Last time I had similar problems, it was my pressure regulator. I had virtually no fuel pressure and the result was no boost.
__________________
'95 F250 XLT 4X4 Ext Cab LB, 5 sp, LuK kevlar clutch, 3.55 LSD, 88 D60, Sky RSK with SD V codes, ATS BB turbo, Non WG 1.15, BDP 200cc A codes, Stealth HPOP, BDP fuel system, 120V IDM, ARP studs, Spearco IC, 3" intakes, 6-pos TS chip, guages, Tymar, EBPS bypass mod, IH bellowed uppipes, 4" DP.
450HP/1000TQ
94 and 95 HPOP anti bleed down mod
  #7
Old 01-23-2008, 06:59 PM
kenworth
Offline
tbear01
Member's Gallery
yes it does his out the exhaust it vary's certain days depending on temp it seems to have a little more power. But it is really hard on fuel since this all started 345km/90 litres.The truck is bone stock just a plow truck but still need power.
  #8
Old 01-23-2008, 07:57 PM
jshank's Avatar
jshank
Offline
Member's Gallery
how many miles and how are you at the matiance stuff?
__________________
2003 f250 crew traded for higher education
new ride 2004 wrx wagon
  #9
Old 01-24-2008, 09:16 PM
KAC1023
Offline
New Guy
Member's Gallery
Send a message via AIM to KAC1023
My 200 was having low power issues as well. I just replaced my ICP sensor with a new one, it was also more updated then the old one. The POS one that was in there was "sweating" through the sensor so I figured it was time for a new one 90 bucks VIA eBay. Truck runs a million times better. Next I might update the IPR after I check the high oil pressure.
__________________
2007 STS-V for sale, looking to get back into a Super Duty. Cars on eBay, user name KAC1023
  #10
Old 03-04-2008, 04:54 PM
kenworth
Offline
tbear01
Member's Gallery
Yes it was the EBPV it was seized shut thank you for all your help I apprieciate it.
__________________
2002 Ford F350 super duty
Bone stock Plow Truck
(View-All Members who have read this thread : 104
00PSD1, 02f350toy, 02stroker89, 1snotrocket, 99F250Smitty, Alan Hicks, andyj, Arisley, B18B1LS1, badluck_early99, banshee01, Barnbuilder, Bartman, BIGLARRYS03, Blake Williford, Blowby, bluetech151, BMac, boggerr, Bonecrusher, brocanic, Bushwakd, cantrellc123, Countryboy07, crowz, darth powerchip, dblamp, dbweaver82, Dieselboy, Dieselgeek, Diezel Dawg, DIRTBIKEZ, Dirt_99, drftsub, fbilly420, firestroke, fordboy424, godofdew11, Got Diesel, Haul_n_horses2, helvis, he_likes_truck_more, iaff284, IDPisan, jakef250, Jim Watson, joediesle, Jrgunn5150, JSC, jsf350, jshank, jtjohn, jun_turbo, jvencius, KAC1023, kenworth, makaveli200369, mandkole, Martin #6, matthewd11, mattrac, mattymx, nchappy, OldschoolPSD, ONEBADARIES, outlaw 4017, platinum01, Ponyboychris, Powersmoker, powertrip, psims20, qcfarmer, Radarman, raptor, RichWT, Ripsaw, rpm-inc, ryno00, scheidt27, SeeYa, shaddaddi, sheboyganjohn, shinsho, skylinedan, smerleau, smorris, spectre, sshelo1, stroke77450, Stroker96, stroker_1999, stroketeck, strokethis7.3, SuperDutyDave, tkdbf350, tmunoz, Tom S, TomzToyz2, toypuller, trailerdoc, Tucker1092, UNCOOL
You may not post new threads
You may not post replies
Forum Jump
