removing the exhaust back pressure valve??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 7.3L Power Stroke - Aftermarket & Performance
Thread Tools Display Modes
  #1
Old 03-27-2010, 09:37 PM
DIESEL DAN's Avatar
DIESEL DAN
Offline
Member's Gallery
is their any advantage by removal of the exhaust back pressure valve?
doing 4" upgrade, since i'll have it all apart, figured i'd ask.
thanks guys!
it's for my early 99!
Old 03-27-2010, 11:31 PM
outlaw5.0
Offline
Member's Gallery
Re: removing the exhaust back pressure valve???
Drop in EGT and backpressure. I grind the rivets down, remove the butterfly and shaft, then put a core plug in the one shaft hole. I then bore the exhaust adaptor to 3.00", stock its 2.830" or so.
__________________
2001 F-350 CC Drw, GT-4294/1.01, 200cc splits, AFE stage 2, custom fuel system, Rickson 19.5's, many more mods.
  #3
Old 03-27-2010, 11:46 PM
li'l tugger's Avatar
li'l tugger
Offline
Catfish Mafia
Member's Gallery
Send a message via Yahoo to li'l tugger
i did it on my early 99 when i changed my turbo a while back. works good unless you live in a cold climate.
__________________
early 99 cc 4X4.. 4" exhaust, cushtom tunes, DI hybrids, DI tranny, GQSSB turbo and 3" plenums from WOP,
13.94 @ 96.9mph.. on stock turbo
  #4
Old 03-28-2010, 12:06 AM
DIESEL DAN's Avatar
DIESEL DAN
Offline
Member's Gallery
what about the cold weather? i don't drive the truck in winter. as for cold, temps i drive in here are around 40*
  #5
Old 03-28-2010, 12:14 AM
DIESEL DAN's Avatar
DIESEL DAN
Offline
Member's Gallery
do i have to disconnect any harness?
  #6
Old 03-28-2010, 02:15 AM
outlaw5.0
Offline
Member's Gallery
It never affected my truck in the winter time.
  #7
Old 03-28-2010, 05:56 AM
TARM's Avatar
TARM
Offline
Member's Gallery
In cold weather lack of a EVBP causes it to take longer to warm up as you loose that restriction. Some also use them as a poor man exhaust brake.
  #8
Old 03-28-2010, 06:21 AM
davey99ps's Avatar
davey99ps
Offline
Davey B
Member's Gallery
I got rid of my ebpv last year and havent had any problems with it warming up, im from WI also.
__________________
95 CCLB- 238/100s, H2E, termy t500, wipe out pushrods, comp 910s, mbrp exhaust, bdp tunes, and 8" lift
99 ex cab - Rolled 3/10/10
  #9
Old 03-28-2010, 07:37 AM
TARM's Avatar
TARM
Offline
Member's Gallery
It would be interesting to manually control one and see the effects it has on time to get to the temp it normally fully opens at, on a idling engine, at outside temps of 32 F and 0 F. It would be interesting to see how much of an effect it has. It sure no question it kills the power of an already sluggish engine when cold. Not to mention they do seem to stick at times and even when fully open impair exhaust flow.
  #10
Old 03-28-2010, 10:11 AM
Ron's power stroke's Avatar
Ron's power stroke
Offline
FORD..THE ROCK CRUSHER
Member's Gallery
no EBPV or fuel bowl in my truck for 2 years now..where i live it get damn cold quite often but the ole girl starts every morning with out a problem..i let her idle for 5 to 10 minutes in the am...15 minutes when its 20 bellow..then driver easy to the out side of town,,by then she is good to go..
__________________
(View-All Members who have read this thread : 511
'99 stroker, 00f250psd, 00PSD, 01platinum, 01REDSTROKER, 01stroked, 02BigD, 02POWERSTROKE7.3, 02strokinhauler, 0373, 04stroker, 06-f350, 07f450, 16yrenthusiest, 1997stroker!, 1craneguy, 20007.3stroker, 2000XLifted, 2006nytro, 2dedge, 2wd_sled_puller, 444-4D, 5290, 6.0beau, 69800, 7.3 superior duty, 7.3boys, 7.3LStrokeR, 7.3pokesfan, 7.3SuperDuty, 710_burner, 89xj, 92fordcummins, 94psd5speed, 95ef2fiddy, 96stacked&smoken, 96stroke957, 97-BIG RED, 9755, 97obs, 97powerstrokety12, 97rattlebox, 97WhiteFlatty, 99.5crewstroke, 99Towbeast, aCab, AK1, aklim, amscontr, andrewz, Andytheman24, ant250, aquadreamin, Arisley, asalm36, Balthasar, Bamboo, Barnbuilder, bazdog1, BB540C2, BDP Tuner, Big Calo, Big-Stroke, BIG-T, bigbadford01, bigern515, Biggin'ZRT, bigred2001, bigred3/4, bigrngyj, BigTXForddiesel, bill4d, billguns1, birdog, black7.3, blackmagic, blacksmoke.r.us, blair, blk mk8, bls, blueoval95, bluovldeezl, BNissen205, bolt_bucket, brahum, BRAVO, brick, bruce51d, bryan.d, bryan213, BT500, budd, Buford-61, bulldog01, c con, c.salt, Calico5, cardiac, CARR, caspower, Cat00, cchoptank11, Cessnakid, Cgate86, chris1978, chrisstewart36, ChunderDownUnder, chunkdunker, cj45lc, CLIFORD3, Cmonster, CMPNS8N, cobrabc1993, cody342b, COFG-28, CompOrangeCobra, cool_hand_luke, copracr, cota, cowboyengel, Cowboyup, cowboy_dan, crawlake, Crazzy8, cretedogg, Critical, crowz, ctch1, CumminsTrader, CUMMINS_KILLA99, Cutty72, cvdenson, cwprosser, danielzink, Dantheman, darkside708, darkstar, darrell401, darren.corbin@gmail.com, davewild, dave_k96, David Kennedy, David N, deathwishracer, DEEREPULLER, deerhuntr, deiter5262, Delta161, Denver, DHTD, DIESEL DAN, Diesel Mack, DieselBrad, dietoremain, dirtboy25, ditch_dawg, dixieland-diesels, dixokai, DJM, dlnw98, dltnjarrel, DMOSE10, dmstrucks02, Doodah, doubledoor, dpski, dpwilson, Driles85, Duane l, Duanesz, duncan351, Dustin F2504x4, dusty9, e.nickkk, e99pstroke73, EastTexasF250, eleventhtruck, ElkBowHuntR, endonoz, enenuenue, Erle385, ExtremeFord4x4, f250Towpig, f250towrig, F350_7.3, factorydefect, farm boy, farmall99, Fast&Strong, fastbarryracing, fbm1344t, fergus, ferociousfish, firefighterbam, firefighterwp1, Fischer, fordguy19761994, Fordguy26, fordguy64, fordman2121, FordPower, FordRacer, forrest7roughneck, FourByFord, Franken-stroke, Freshmeat, friskyjake, fst2000, fyn409, fyrehose, Gaius, GavinRiepe, genuineford, Gnathv, Goatwrangler, goodintentions, GotPayment?, Gotti2k7, gstang408, Gutierrez9287, hammer249, Hater04, haulin2000, Hawker, hawkeye, Haz-Matt, Hco4x4, hdchopfather, Headcase98002, Highbeam, HMBUILDER4U2004, hofiveo, Homesteader, Hoofbeat, hopperwagonbob, hotrodtodd, HotRodTractor, houtxfdcapt, HubrisHCC, huck31, icacalive, icanski2, ImpactDiesel, iron butterfly, isky1843, itburns, itsallinthestroke, J HO 22, j440, jababson, jacmurr, jakepolly, jawsfx4, jaybuller, Jcbemer, jcc01, Jchappy12, Jdg41, jerryjust, JerseyJim, Jesse Lambert, JHill, Jimmyb4000, jlau6888, joediesle, joezex, johnday, JonFord, jopes, Jordy53, Joshuastroke2000, jpowerstroke, jsmith, jtbowen31, jtsparks2, ju015dd, junkman306, JustDiesel, jvencius, Kampy, kawie400, kbragg430, kfluke, kickinupmud, kilapapipa, Kingcobrav9, KingCrabb, KingRanchSick.0, knoxville, krc0864, Ks94.5powerstroke, Lab Rat, LaJ10, lizready13, lkroeger, lubeowner, lwcwb08, mannscustommotors, MARKIS, markt, Marty, Mat J, mattk9, maverick5.0, mbg75, MDRhoads360587, meandog06, metalnova, mgeod, mike61, minerz, Mink, mitch7.3, mjones, MLR80, MN_MountainMan, Monstar, monsterfords95, montana350, Moose475, MOTO7.3, Mpoage, mrgto, mspowerstroke, mstadler13, mstng85514, Mtack, mtmod50, myloyambag, naa60512, nastystroke04, nation1979, needalaugh, newpowertroker, NH OIL BURNER, nicholsjason4, Nomad1671, Northcountrywood, np205, npen, Nuzzlenut, old man dave, old Smokey, oldschool, olsmokey, onebad97, opieg01, otis_301, Ottomatic, OUTLAW-OFFROAD, OUTLAW101, outlaw5.0, PAbowhunter, PahStroke, Papaq, Peterbiltman79, Phiber Optik, PHPDiesel, pilot4life, PJB, porkchop, Posjr, Powerstoke_Fan, powerstroke02, powerstroke742008, PowerstrokeR00, prostreet67, pscooter6, psd kid, pstk5088, pstroker73, Pubsmack, Pure Evil, purple_heart_350, PWRstroke_smoke, rake18, RC4WD, rcsteelman, rdlewis, rebel6.0, ReconDieselPerformance, RichWT, rickvm, riverjet, Roanie, Robles4242, rockdog, RockinJW, rogers250, rollingthunder, Ron's power stroke, ronark, Roots, ross3031, roughneck0913, rpm-inc, rsbhunter, ruffneck7.3, rusty1161, Ryan444, sanocafire20, savvy1, Scerb, Schneider 86, scott2001, Scottapher, scrapperdude, sdjohnny, Sea97Stroker, SeeYa, seg_97, Selectcmpr, seven.3psd, sgleshot, shawnberrier, shaynep, shmokenpstroke, silverhoss99, simpleman, six8, skav, SKWERL, Slated4Greatness, sling, slippydaman, SLO DZL, smith7.3, Smokediver3, smokeuout09, SmokeWithEveryStroke, smokindiesel2, smokinstroker92, sniper_101, snookmanaaron, snowball, solrac06, SouthJerseyStroker, southmike, spdmpo, squeak12, sslong, Staggs02, stalyon, steinberger4, StockBeast, stolennitrous, stroke77450, Stroked PSD, Stroken7.3, Strokin450, sunny644, sunstroke, Super_Hauler, SyN, SZYD, t444epsd, tank, TARM, tbutera2112, tch.280, ten speed, terrye, texans, texasredneckjae, thecabinetguy, theCOYfish, thinmint, tholt34, Thomas A, TimberPro, tneibling, tomato76, Toms014x4, TomzToyz2, tonka350, Toymachine, tpull3, tree trimmer, treyloco, TRUBBS, truckpullin_75, tvmechanic21, twelch3, twoicebergs, Tyson42, UNCOOL, van2002, vegasfmf, vintage way, waltenbach, wcpresley, WelchyBoy833, WhiteTrash7.3L, wildstang3, WishinIwerFishin, wolfmanfpd, workrig2000, worm5932, wsigo, xstrokinx, youngPSD, zvovchik
You may not post new threads
You may not post replies
Forum Jump
