| Register | Members List | Timeslips | Calendar | Sponsors | Becoming a Sponsor | Mark Forums Read | Auto Escrow | Auto Loans | Insurance |
Thread Tools | Display Modes |
#11
Re: Michigan Dyno Day May 1st 2010
I'm game
__________________
| Sponsored Links | |
Advertisement |
#12
For what? Does that mean you are strapping down the trucks?
__________________
White 01 Superduty, Ex-Cab SB, 4x4, Built 12V Cummins, HTS Billet 47RH, 8" Stack, 796 HP 1300 ft/lbs #2, 1374 HP 2500+ ft/lb on the gas. What you don't measure, you can't control. What you can't control-you can't improve. |
#13
If I get there early I'll lend a hand.
#14
ok so the liner is out as it weighs close to 19k lbs.... i guess the dually will have to do... your lucky Adam.... i was gonna go home with the highest torque number
__________________
Will 2002 F-350 CC LB 4x4 DRW 3 other PSDs, Low-Pro Freightliner, and 12 other diesel trucks Random pics http://s255.photobucket.com/albums/hh153/iottw/ |
#15
__________________
'07 F350 3" lvl, fndrs trmd, 37" M16's Ultra lites ECT,EGT,EOT Oil and top fuel billet caps banjo bolts drilled cautiously, ccv, zoodad mods Dieselsite coolant filter SCT SF3 can tunes Mike's Diesel Performance KT Performance DieselPowerProducts.com Dieselsite |
#16
Since this is for diesels can I put my CUT on it to make sure it's rated for 37hp?
![]() CUT(compact utility tractor) |
#17
Im in let me know if you need an hand with anything. 810 300 9250 Luke
__________________
1997 F 250 cc sb, 250cc hybrids, Modded H2e, Arp Head Studs, Swamps Valve springs and P rods, 17* hpop,Beans E fuel, Modded idm, 6.0 IC, DP Tuner, Built Trans, Intake, 5" Exhaust, D 60, 10 ft Western Unimount 488 hp/905 tq 1996 F350 std cab, 6637, Muffler & Cat Delete, 9.5 Western Unimount 1997 F350 std cab, stock, 8 Western Unimount |
#18
Adam i can probably give you a hand strapping down the trucks. Ill be in harrison that weekend turkey hunting so ill be able to make it. Just let me know when i should be there.
#19
I'll lend a hand if ya need me to
#20
Cool thanks guys I will keep you informed as we get closer. If we are thinking we are going to have more than 25 to 30 trucks we may start at 9am, at least the dyno anyways.
(View-All)
Members who have read this thread : 10
| 06Harley350, 99dieselsmoke, Blacklung, lazerf250, lincolnlocker, powerstroke742008, Richter415, StrokinNsmokin, suprhlr |
| Thread Tools | |
| Display Modes | |
