06 F250 HEATER NO HEAT - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.0L Power Stroke Technical Info
Register Members List Timeslips Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 03-11-2010, 05:23 PM
trw123
Offline
Member's Gallery
Has anyone ever had the heat not get warm, just blow cold air? I have the auto climate control. If you set the temp to 80, it will just blow cool air. Any thoughts on this ?
Thanks
Old 03-11-2010, 08:09 PM
Stroker67's Avatar
Stroker67
Offline
Member's Gallery
Re: 06 F250 HEATER NO HEAT
Low Coolant, whats your coolant level in your Degass bottle. Oh and theres a search feature at the top of the page, i believe if you would use it and type in your issue, i think theres quite a few threads on this problem.
__________________
  #3
Old 03-11-2010, 09:13 PM
06powerstroke's Avatar
06powerstroke
Offline
Member's Gallery
Low coolant could be the issue, but you usually still get heat while moving. Does your truck have the heater bypass valve? I would check and see if that is working. Here is a pic of it. It is the black thing with the grey line going into it.
__________________
2006 F250 CC LB FX4 Lariat
ARP studs, SCT X3 IDP & Gearhead tuned, S&B CAI, straight pipe, FASS 150/180, FCDP solid uppipe, Dieselsite coolant filter
2.5" BTS leveling kit, 35" Xtreme A/T's on XD Hoss 18's, N-Fab prerunner bar w/ 3 9" Hellas
Pioneer double din, JL components, 3 10" Pioneer subs
  #4
Old 03-11-2010, 11:52 PM
SKIRK's Avatar
SKIRK
Offline
Member's Gallery
This sounds dumb but do you have auto locking hubs? If so you may have a vac leak wich will cause the heater to switch to defrost. Could be the seals in the hubs or the vac lines themselves.
  #5
Old 03-12-2010, 12:37 AM
Stroker67's Avatar
Stroker67
Offline
Member's Gallery
Hey travis is it bad that mine doesn't stay on the little thing that it's supposed to?
  #6
Old 03-12-2010, 12:48 AM
Mpoage's Avatar
Mpoage
Offline
Member's Gallery
My moms 05 excursion had the same problem. Just put some coolant in it.
__________________
2007 Ford F-250 Lariat Outlaw 4X4
SCT X3 Tuned By Innovative Diesel
Straight Piped
Edge Insight
  #7
Old 03-12-2010, 01:32 AM
trw123
Offline
Member's Gallery
Thank's for all the suggestions, after looking into this problem, it seems that there is a problem with some sort of direct door that directs warm air in. not sure of the correct name for it. It all happened right after I dropped the temp control all the way down to 60. The next day I had it up to 80 and no heat, just cool air. It is an 06 and is still under warranty. I am going to take it in next week to have it fixed. Thank's for all the suggestion's I am new to the diesel world, and this forum really is a big help.
  #8
Old 03-12-2010, 04:17 AM
06powerstroke
Offline
Member's Gallery
You mean the grey line? I think if it is unhooked you will get a vacuum leak with your A/C on MAX A/C mode. Plus coolant will still flow through your heater core on MAX mode and it will not be as cool as it could.
(View-All Members who have read this thread : 34
06amarillo, 494doug, 6liternole, big-country, BlueDesertBeast, Calvert, captainharley6.0, Carbonmatrix21, clbaker32611, Dano244, Dirt Floor Poor, Dirtyryder, Dustin F2504x4, hotrodsoul, jimmyb, jumbojim90, kyle, leed, Mofugra, morepower02, Mr. Elite, NickMo12, PowerSub, REGUN, Rick G, rickinnakusp, Rob D, Roush4_6, shreyshah1120, SMOKESHOW60, stroke60, stuckinarut, The_Carli_Suspension, xsfpns
You may not post new threads
You may not post replies
Forum Jump
