| Register | Members List | Timeslips | Calendar | Sponsors | Becoming a Sponsor | Mark Forums Read | Auto Escrow | Auto Loans | Insurance |
Thread Tools | Display Modes |
#1
VGT-SS vs. NON-VGT
I have been introduced to both for my 06 F250 and I can't figure out which would be better. I have heard good things about both but what I really want to find out is the negative things. Anyone got any details? Thanks
| Sponsored Links | |
Advertisement |
#2
Re: VGT-SS vs. NON-VGT
It all depends on what other upgrades you are wanting to do. What size injectors are u looking to run. What are u using the truck for?
__________________
CenTexDiesel.com Logan Schneider 830-885-6500
#3
I want to run 180 injectors and 66mm turbo. It is a street truck but I plan on running the strip and pulls too
#4
The 66 will be very laggy with 180s, I have put a 62 with stage IIs from Elite and they truck ran great. I have also installed a VGT-SS with the same Sticks and it preformed equally as well, but the Egts were higher with the VGT
#5
If youre sticking with 180 injectors, id most likely stick with a VGT-SS. I ran a Silver Bullett 66 on a 6.0 and it was laggy. around 2100-2200 it would start to light. with a high stall converter youd light it, but the vgt-ss would do a decent job of cleaning things up and have great spool. Youd have to ask logan what kind of temps hes seen with 180s-190s and a VGT-SS. Id imagine a 62 such as a phat shaft 62 would be a better match to those injectors than a 66, as you could still push in the 500 horse range and temps would probably be somewhat managable and spool wouldnt be terrible.
apparently we were posting at the same time.
#6
With the Phat Shaft 62 the Egts never exceeded 1500* at WOT, and were in the same range at 70MPH. Phat shaft 62= Hair of lag on the bottom end. Vgt-ss = Quick spool both would produce rite at 40 psi. |
#7
i know DJ sells a package deal for around 4500..fuel system, 190cc, VGT-SS upgrade, and studs. which is a bargin and seems right up your alley. DJ claims to see in excess of 500 with this set up.
Innovative can do something similiar. Elite tends to be a little pricey, tadd does do good work but you can get comparable power else where and save 1k..imo |
#8
Logan, could you tell a difference in power at all between the 62 and vgt-ss on the truck with stage IIs? Did either turbo seeem to clean up the fuel any more than the other?
#9
Personally I would Run the Phat Shaft 62, I cleaned up almost all the smoke on the top end, and power wise I think the phat shaft felt like it had more power on the bottom end once it spooled.
The VGT-SS was just more of a consistant power from start to finish. It also was vary close to no smoke aswell. Both operate well, and Its depending what u are going to do with the truck, daily driver in houston, VGT-SS. Open road towing PS62. |
#10
Anyone no what size turbo they would run with 250cc injectors?
| Thread Tools | |
| Display Modes | |
