upfitter switch install HOW TO - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Power Stroke Nation! > The Library > [6.4L - Technical Info]
Closed Thread
Thread Tools Display Modes
  #1
Old 03-06-2010, 06:58 PM
norris's Avatar
norris
Offline
It$ only money
Member's Gallery
i wasnt lucky enough to get the switches so i did them myself. was VERY EASY, took me and my daughter about 15 minutes.
I started by buying the kit from ebay from fordupfitter, cost was about 140 bucks.
http://motors.shop.ebay.com/fordupfi...1&_from=&_ipg=
hes got instructions with the kit, heres picks to go along.
start by popping off the silver trim piece thats got your vent and lights in it. you need to pop the bottom loose, them the rest will follow.
you will have a bracket that sticks out without anything mounted and lots of space around it. That is where the fuse box will bolt in.
once the fuses are in you need to pop the panel off under the wheel. start by poping the bottom loose then slide it up and the rest will follow. if you look straight up into the dash from the floor board by the gas pedal, you will see a grey connector and wire harness and theres nothing but a dead plug on it. that is where the grey connector from the new fuse box connects and gets you power.
once that is in you need to ground the other wire.
then youve got one small wire harness that goes to the switches, similar to a phone jack. you must send it up to the coin/brake controller area. its very tight, i used a piece of wire to fish it up thru the cluster. i poped the little black trey above the gas pedal out to help fish the wire. once u pop the coin tray out(real PITA) you can plug the switches in and pop them in.
now youve got switches. theres a nice little sticker on the wire harness that says what wire goes to each switch. without anything hooked to them they still light up when flipped.
hope this helps guys!!
__________________
Norris Farms- Where the trucks are, and the tractors' Green
'12 F350-KR,H&S,5"pipe,S&B,
'10 F350r-6.4,5in back,SCT/Innovative,Elite tranny,S&B,2.5" level,EGR Delete,Trutrac
'99 F250-7.3,8in on 38s,7in stack,AFe Intake...
Thanks to:
http://www.dpfdeletekits.com
http:/www.elitedieseleng.com
Go to the top
Closed Thread
(View-All Members who have read this thread : 525
02stroked, 03F2506.0, 03ghosthemi, 04blackcrewcab, 05'MURDEREDOUT6.0, 06SuperdutyFX4, 08 powerstroke, 08eylerford, 08Ford, 08HDF350, 08psdbeast, 08silverbullet, 08straightpiped, 08stroker350, 09BigBoyF250SD, 10kingranch, 1995eddie, 1997P-stroke, 1ton4rd4me, 2001-7.3Liter, 2008 f350, 2010stoker, 24Vford, 300savage, 350KngRnchOn22s, 350sd14, 411pit, 6.0dieseltech, 6.4power, 6.4power!, 64Diesel, 64folyfe, 69800, 75cj5, 7powerstroke3, 85yota350, 87jumpy, 907superduty, 92fordcummins, 97F-250HD4x4, 99FORDTUFF, Agjake11, alldaysports, AllGo'N'Show, AMB, AngryLepercon, ant250, Ar_hunter, augustus89, Austin_Bennett, Av8tor, az94yj, azleflyer, Bagged85s10, baldwinc, Bates, bbmxandfmx, BCB, Bci99, bckcx2, bebarney, beemc, Ben328is, Big Jim 54, big jon, big white7.3, bigbadford01, bigisland6.4, bigraymo, bigsix300, BillyBob427, bk1977, bkhd30, Black086.4, BlackFord350, Blackharleyf250, Bldghosp, blk6.4, Blowby, bluedemon, bluepower, bmwrcs, Bobbyt, bouttime28, bowtie540, bpb424, bretferd, brian350x, brkncly, bts, bturet, buck russell, Buckshot341, BumpRacerX, bynder, Cajundude, Cajunhunter67, CamTom12, CANNONMAN, casey429, cashishift, cattle farmer f550, CCSracer13, cdiesel77, CDUBYA, CGMKCM, chadder, Chainsaw1, ChaseN, Chasin' Tail, cheprice, chodifer, chris d, CJR, CL301, cnote1115, ColaMac, collins590, coryjones, cowboyengel, Crack85, Craig@MPD, cscotted, cudaguy, Cumminsatya, Curry10, CutThroat, cypher0807, d432ejh, d99, Da Oops, daddystoy, danbonzo, Dave, dave75002, dbark, Deal80013, DenisTheMenace, Dennis64, DieselDZ, Dieselgeek, dieselman64, Dieseltron, Diesel_N_Blood, diggie, DivingDriver, dnabrillhart, Dorito, Dozer600, drdiesel, Drew2010, drunk on diesel, dstryr, dtrain, duddy, Dudley Glass, DZL JIM, DzlNut, eagles231, Earl Elwood, Easyrider6, Edroe, elcaminoman, emmysdad, Enmerdeur, eric.davis, erikclaw, Evil Diesel, ewagner05, f3501011, farmallw4, farmman57, farsell, festus17, fhanrahan, Fireball57, firedog23, FLcruzin, flier32, Fluff, fordgasm69, fordowner4life, fordtough97, fordtuff08, foureyed, frkjr_2580, FST HD, Ft.Mac.F350, Fudge0514, FullerF250, Garage_Biitz, garybrock, Gefell, geoffry87, gespur, Gibrid4x4, glamisrhino, gman, Gman92587, Gnarkle, Goatro, gomer pyle, gomileshifi, graffittticoupe, Greenshield, griz700rocket, Grn99gt, GROSSpolluter, GTOKILLER, HAMMER!, harleysdontbitc, harrymank, Hawgleg, hawkeye, HB-DELUX, HD-tech-NH, hdemacy, headviking, heavytF, hendricksbus, HillBros, hill_billiez, hinesks, hirollin87, Hogpauls, Humvette, hzepeda07, ibkchatton, ilmathewspro, ilovetards, indiana lineman, ISUsuperduty, JAd2752, jaderderr1, Jason84, jawsfx4, Jaydog, JaymesNelsonF250, jeenyus73, jeepdo81, jefhuf, jeremyleggett07, jgerdes2005, jgos929, jhaddox, jjjblanc, jmeng, jmhirshorn, jmsmith76, Jmswrd, jockeyboy, joey d, John Martens, Johnny77Mutt, Jonbones, jones17, journeydog, Jp743, JRackATTACK, Jritola, jrobpowerstroke08, JrStroker, jruthe82, jsturki, jt720, jticp, Jtpappy6.4, Jughead361, juiced250, jumorris, Junior_r, jwzimmer, keets HD, kelley350x, KeninAZ, KingRanch1341, kleake, klm2307, kmack2010, KnobHill, knoxville, kolombiakali, KR69IDI, krc0864, Krlajwvater, ktmrider, KTP\MW, kudzu, kylebryan, ldds12, Levitc88, LILGSX, lkn4snow2, logo88, lordnorth, lowbedriver, luckydog, LuckyFlyinROUSH, Luther's 2008, lwcwb08, MADMAN36, madmaxracing, mar1nedoc, Marine13, Markgask, matted2thefloor, mattldegollado, mhkremer, michaels86svo, MississippiJoe, MoonMan432, moorea, moosey42, moses320, Moyerboy, Mpoage, MR.KITTEN, MrBill1, mrfandango, mrstacyr, mtcrss546, Mudlight, Mudslinger08, Munkey, murr3061, mxz6001, Nadler, narcco, nastystroke04, NathanScott, Nickg9785, Nightshift, Nixon, norris, northernfriend, Nos_GTSR, Nowatay, nspock, nukemF350, nutsnboltsjp, nvrsatisfied84, o4ep3civ, oconnors17, oh-ate6.4PSD, Oh8stroker, olddixie, Oliver, om3ga, one2nine, OnlyPolaris, orlyc, Otto-farms, OUSOONERS, p8ntballn2, pafirearmowner, pat123, pieperz06, Pipewhiner, pooter, powdersmoke4700, Power Smoker, Powerstoke_Fan, Powerstokin22s, powerstroke6.4, powerstroke95, powerstrokeshane, powr2stroke, ppmcevoy, preppypyro, Prhartley, pullinstroker97, pwrstrkr, pyromaniak001, qcfarmer, QuickSilver74, r1ramjet, racrguy, radio flyer, raybass, Razzer, rbowen9895, rbro7752, rcfarm, Rebel350Ford, rebelchevy02, redhawk19, Redman08, redneckcorvette, redx, REGULATOR, rhoade667, ricg, Rick59, Ride On Joe, ridered99, ridiculous_einstein, riemer, roceatr, Rodriguez62991, Roger Wilco, Rook, roosting you, RoughNeck7x, RoughReady86, RRandal, rustygrind, RWRandal, sbl1961, Scales, scbolt, scnd2none, scott2001, scottKP99, scottylov, SD08, SDBG, semmens21, Semperfidoordie, senorlechero, seriousdiesel, Seth Wilson, Shaunvk651, shell_guy, skooter, Skyd Ram, slightlycrazy, slowmans, smokem08, SmokeWithEveryStroke, Smokin_Powerstroke, snbm97, snopro_69, SonicDiesel99, SoTexRancher, Spearman86, spiff, srmurphy, sschwindt, ssduck30, Stallion Forward, Stan M, Stang07, steele6599, stonecoldrn, street591, Strictly Diesel, StrokeB4Cummin, strokethis08, strokin'_tatsch, strokin20, ststt, superbad, SUPERSTROKED, T-Roy, Tabcheck, TAYLORPOLARIS, Tecubana2, Tex33#, texas4x4, texaspipeliner00, texaswhimp, texretvet, tgdameron, ThaStroke, the only Qualk, The Rock, The Silverback, the7.3dude, themudgician, The_Badge, thornton5127, tight, timberwolf, tjbrowder, Tknox, TLedbetter, TODDXDC, tommyboy#1, Tony808R1, tonymontanna1983, toodldoo, TriggerHappy, truckin87, TSizemore, ttwndoc, Tuckerdog11, twank11, Tweek, twisted twins, TXsmoker, Tygen1, tyoung, Ubermoose, underaltec, Vermonter, vet60, wamel, Ward, wbwright, webb06, widieseltech, william351, winkfab, witzke08, Wizzard of Odds, wolfejeremy24, WoodBoy, wp3223, Wreckedwolf, yamanub, yell0jaket, yohe, you smoke, youngjTX, youngstroker, zabeard, zeigler86, Zmann, _INDY_
You may not post new threads
You may not post replies
Forum Jump
