7 pin blade style plug wiring help! - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Other Diesel Topics > Towing and Hauling - The Work Horse Forum
Thread Tools Display Modes
  #1
Old 02-25-2010, 11:09 PM
jaybuller's Avatar
jaybuller
Offline
Member's Gallery
so i need a 7 pin blade style conector for my truck so i can plug in my new rv. all i have is the 4 pin flat style. so i bought the plug i need but dont know how to wire it all up... id didnt include instructions... well here is a pic. if some one could tell me what to hook the 3 wires too..( i know the white is ground ) but what about the other three? thanks yall/
__________________
2000 f250 ECSB, 4x4 7.3 zf6, 150k miles
Php hydra chip PHP tuned! 4" exhaust, stock turbo(ww2, turbomaster wastage actuator, gutted ebpv), FRX, unlimited 160/30 sticks SB 1939-CB single clutch, home brew water setup for when i'm pulling 15k through the mountains.
Old 02-25-2010, 11:31 PM
TANK'S 250's Avatar
TANK'S 250
Offline
King Dingaling
Member's Gallery
Re: 7 pin blade style plug wiring help!
This might help
Try this site
Trailer Wiring Diagrams
  #3
Old 02-26-2010, 12:17 AM
jaybuller's Avatar
jaybuller
Offline
Member's Gallery
thank you thats exactly what i needed.
  #4
Old 02-26-2010, 12:27 AM
TANK'S 250's Avatar
TANK'S 250
Offline
King Dingaling
Member's Gallery
no prob...glad I could help...
  #5
Old 02-28-2010, 03:36 AM
tbolt's Avatar
tbolt
Offline
Member's Gallery
If it's an RV they are different than a reg 7 blade. The plug you bought doesn't seem to have enough wires. Seems to be missing the Red aux power to power the convertor in the RV. The rest of it might work but it's nice having that one to charge the RV batt while the truck is running. Example. While hunting in the mtns @ 7000' in temps in the teens I hear some noise in the middle of the night. My buddies trailer batteries took a dump and he had no heat. He backed up his truck, plugged it in and got the furnace going. He couldn't start the gen so he had to use the truck. Just something to think about.
__________________
Glen
early99 f350 cc, lb, 2wd, drw, A pillar autometer guages, CTS monitor, AIS intake, 4" turbo back cat delete diamondeye exhaust, dptuner, pmt1, jw vb, Swamps ab inj, Adrenaline oil, Coolingmist, 180*T, Trucool cooler, spin on trans filter, Firestone air bags, 2" frt leveling kit, now chased by a 34' toyhauler
  #6
Old 03-01-2010, 12:05 AM
jaybuller's Avatar
jaybuller
Offline
Member's Gallery
naw, on this one the black wire goes to the convertor on the rv, and on the truck side it goes strait to the battery. i been chacin down a wiring problem. so ive been through all the wires two or three times now on the truck and the rv. i cant get the brake running lights to come on at all and the blinkers and brake lights are some how showing up on the dim side of the two way bulb.. the running light side... i think it may be a ground issue on the trailer side but still not 100% sure.
  #7
Old 03-03-2010, 03:29 AM
tbolt's Avatar
tbolt
Offline
Member's Gallery
on my fact plug the aux going to the convertor is only hot when the engine is running so as not to run down the batt in the truck while camping for days. if it's wired to your truck batt the conv is on all the time it's plugged in.
  #8
Old 03-04-2010, 01:29 AM
jaybuller's Avatar
jaybuller
Offline
Member's Gallery
yeah, its an easy fix just unplug when you park to camp. im usally using my truck for other activities when i camp anyways like fishing or hunting.
  #9
Old 03-04-2010, 04:07 AM
tbolt's Avatar
tbolt
Offline
Member's Gallery
Just wanted to point that out. Sounds like you have got it together. My memory is so bad I would forget. I always have my arctic cat prowler to run around in so the trailer stays hooked up. I'm lazy about things like that.
(View-All Members who have read this thread : 16
Bleedgreen, headleyj, honda313, jeremiahmercier, Lrsteger, Matt-F350, morefuel, papamac, pappa b's powerstroke, pilot4life, tomspear, Tre Strokes, twstmup, whitjo, willxm
You may not post new threads
You may not post replies
Forum Jump
